Yabbadubbadoo Samba Member
Posted: Tue Mar 18, 2014 4:13 pm Post subject: |
Are they in-stock at the moment or is there a wait for the next batch? _________________ Sydney, Australia.
66 Type 3 Fastback |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Tue Mar 18, 2014 5:22 pm Post subject: |
Yabbadubbadoo wrote: |
Are they in-stock at the moment or is there a wait for the next batch? |
I bought one but won't be using it if you're in want of one...send me a PM. |
Posted: Tue Mar 18, 2014 6:24 pm Post subject: |
ataraxia wrote: |
Sure thanks mate. _________________ Sydney, Australia.
68vwfasty Samba Member
Joined: March 26, 2014 Posts: 277 Location: Portland, OR
Posted: Mon Mar 31, 2014 10:34 am Post subject: |
I am very interested in how the first batch is working out. It has been a couple of weeks since the last post.
Any updates??? |
Paul Wilson Samba Member
Posted: Mon Mar 31, 2014 10:46 am Post subject: |
68vwfasty wrote: |
Any updates??? |
X2
Paul |
notchzack Samba Member
Posted: Thu Apr 03, 2014 7:16 pm Post subject: |
I think it's important that the people that are giving their review write what kind of Alternator they have, they look the same but are obviously different. I'm no expert, but isn't there a difference between 12v vs 6v shroud?
I have a 12v shroud and my alternator is a rareelectrical.com denso 60amp.
The bracket that I have, the large bracket, the bend looks to be a little of, it is crooked, or my shroud is to fat.
If you go couple of page back, supersuck did some braket notching to the large braket, I did not have to? I did a little bit of grinding on the shroud under the large braket, like supersuck did.
With my alternator, it doesnt fit like eatacactus way. The pulley placement seems to be different.
To properly fit I will lower the hole on the large braket, to lower the alternator, and also put a elicoil in the hole on the alternator that doesn't have tread because theres is no space for a bolt fit properly with out scratching the paint I'll try to work on this saturday. _________________ 68 Perugruen Notchback |
sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4030 Location: Deep In My Own Psyche
Posted: Thu Apr 03, 2014 8:28 pm Post subject: |
so no more sets at the moment??
Ill definitely keep aware!
Just got another 71 square but haven't decided on engine yet _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote: |
Extremity is relative to how far your willing to jump |
Ward Cleaver wrote: |
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Sat Apr 05, 2014 8:10 am Post subject: |
If the EAC setup is produced again, I am down for a set! _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Thu Apr 10, 2014 8:58 pm Post subject: |
So nobody reported back that they got a second set of brackets they didn't pay for with the first shipment?
I had my alternator out for testing this week so i figured i would install the new brackets. I had to use my Binford hole stretcher to get my Geo alternator to fit.
The holes are stretched to get a little more width from the big bracket side. And the alternator mount hole moved down and out as well.
All in all a pretty simple install compared to the shimming/strap you had to do with the DDB style install.
When they tested the alternator i got these results:
Max output 56amp
Turn on speed 100 rpm
Output @2000rpm 28amp
Output @5000rpm 55amp
From the performance curve it looks to be about 42 amps at 3000rpm.
I'll take some more pictures of them installed later. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
vintage dubs Samba Member
Posted: Fri Apr 11, 2014 9:09 am Post subject: |
I like all the nice brackets. I bought my wife a square at the end of last year and started looking into the conversion. Not many inexpensive choices out there. As luck would have it the generator took a sh** so I was forced to make a move pretty quick. So I found a Geo metro at the pull a part and took off the alternator. I also took both mounting brackets. When I got home I realized that the double ear mounting bracket would work perfectly. I set up everything and redrilled the bottom hole on the the double ear bracket where i needed it to be and I was good to go. Trimmed the engine tin slightly. An alternator shop had the pulley.Long story short $35 and 2 hours of my time and everything works perfectly
Out with the old!!
This is just an alternative. The kits out there are very nice. If you don't want to trim your shroud or have a show car this may not be for you. This is my wife's car for her photography business so she didn't mind she just wanted to get back on the road
http://www.facebook.com/trulyvintagephotography
"Penelope"
http://www.vintagewagens.com/ |
Posted: Sun Apr 13, 2014 8:59 pm Post subject: |
notchzack wrote: |
To properly fit I will lower the hole on the large braket, to lower the alternator, and also put a elicoil in the hole on the alternator that doesn't have tread because theres is no space for a bolt fit properly with out scratching the paint I'll try to work on this saturday. |
I am using the Denso 70 amp. I had the same issue with the large bracket being cocked at an angle. The problem is the bend radius is way too big. This causes the bracket to pull to the side when bolted down. This large radius also allows the bracket. to flex way too much. I also think the metal is way too thin. I ended up making my own bracket from angle iron and modified an old bracket for the adjustment side. I also had to lower the mounting hole on the mounting bracket as it was way too high. No photos yet as I am back in the hospital.
Has anyone used the 11thhour brackets using the alternator that they recommended?
Paul
Redd918 Samba Member
Joined: April 25, 2013 Posts: 7 Location: United States
Posted: Mon Apr 14, 2014 9:42 am Post subject: in |
Sorry I missed the first batch. I'm in on the next round. I'm also very interested in the possibility of higher amp alternators working with these awesome brackets. |
luckystiff Samba Member
Joined: September 28, 2005 Posts: 2252 Location: hickory,nc
Posted: Tue Apr 15, 2014 1:15 pm Post subject: |
for anyone looking i listed my alt and Brent brackets in the classifieds this morning. i gotta lot of wreck damage to deal with before worrying about the alt swap....ken.... _________________ ITMC
Secret Service |
fuhq64 Samba Member
Posted: Tue Apr 29, 2014 11:01 pm Post subject: |
Finally got around to getting my Geo alternator mounted in my engine bay. Hand made the brackets. Still have to finish up the wiring. Can't wait to see how this thing does. There's a few more pics in my gallery if you'd like to check them out _________________ 69 Squareback
Still a n00b
www.instagram.com/fuhq64 |
Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Posted: Wed Apr 30, 2014 12:44 am Post subject: |
fuhq64 wrote: |
Finally got around to getting my Geo alternator mounted in my engine bay. Hand made the brackets. Still have to finish up the wiring. Can't wait to see how this thing does. There's a few more pics in my gallery if you'd like to check them out |
Would you mind posting the part number on the alternator sticker and the belt you used? Also maybe a few more pics of your design? _________________ 69 Fastback Build
Berg5 Build |
Willo357 Samba Member
Joined: August 05, 2010 Posts: 483 Location: Melbourne
Posted: Wed Apr 30, 2014 6:03 am Post subject: |
Ok, so I found that the bracket in this configuration was to flexible and gave alot of vibration.... (belt appered to be running true)
I welded in a gusset as mentioned here
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...;start=220
This subdued the vibration a little but I found that with the belt cover on the vibration subsided to acceptable levels. I have been running the alt for a week now with no issues and loving the 14.5V charging rate.
Please note that Im using the alt with the incorrect B+ pin forcing the alt to be mounted 180deg opposite to the intended design.... _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=4...highlight= |
supersuk Samba Member
Joined: December 20, 2010 Posts: 958 Location: Honolulu, Hawaii
Posted: Wed Apr 30, 2014 11:04 am Post subject: |
Willo357, Your youtube vid is private. I have the same alt design as you so I have mines opposite too. What I find with the brackets I have is that the pivot bracket has the hole drilled approximately 3/8" - 1/2" too high. I'm going to weld the hole up, drill a new one, and finally shave down the fan housing a little to gain adjustment without hitting the belt housing. I'll document with pics exactly what I have done. These mods should be included in the next version of the brackets. I also think the adjustment side could be smaller since there isn't too much range that we can do before the alternator body hits the belt housing. _________________ 68 Fastback Build: http://www.thesamba.com/vw/forum/viewtopic.php?p=5396323#5396323 |
