Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Fri Feb 19, 2010 9:46 pm Post subject: Updated: Convertible top 1971 |
1971 Convertible top question: there are two woven straps inside the convertible top, which somehow are involved with mounting of the combined metal/wooden frame for the rear window. Does anyone KNOW exactly how these go, like under or over that frame or whatever? That would be real helpful to me.
Also, what kind of stapler or staples should one use to tack to the rear window wood frame? Most of the pneumatic staples I've seen are 3/4 inch or longer, too long for use there. Or would a manual or electric-powered staple gun work there. Thanks. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
bnam Samba Member
Joined: July 02, 2006 Posts: 2935 Location: El Dorado Hills CA/ Bangalore, India
Posted: Sat Feb 20, 2010 5:02 am Post subject: |
Just did the top on my '71 about a year ago.
The strap does not go over the top. There are openings on the metal frame at 3 o'clock and 9 o'clock. I put in screws thru the straps and into that opening.
For stapling I used a kangaro ts13-h stapler with 24/8 (8mm) and 23/13 (13mm) staples.
Byas |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32574 Location: Reading Pennsylvania
Cusser Samba Member
Posted: Sat Feb 20, 2010 11:04 am Post subject: |
Thanks, both of you. In Arizona, I'm not sure I need stainless steel staples, and all staples for pneumatic staplers at Ace Hardware and Home Depot were like 1.5 inches long. Here's what I've done so far:
I rebuilt the wood section that fits into the metal rear window frame (sides and bottom, re-used the non-warped top particle board section).
I'll attach those two straps to the frame itself using screws. For staples, I bought a 20 guage pneumatic stapler ($20) and 3/8 depth staples ($ from Harbor Freight Tools (most pneumatic staplers use 1/4 inch staples like 1.5 inches long, too long). So now I need to borrow an air compressor, needs like 4 CFM, too much capacity for the $60 air compressors, and I realize that I won't be continuously shooting staples, there will be a few seconds in between. But that will need to wait, there's liquid water falling from the sky today, think that's the "rain" stuff the old timers talk about here in Arizona....but it was sunny and low 70s all week up until now... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
Posted: Sat Feb 20, 2010 11:16 am Post subject: |
Cusser wrote: |
Thanks, both of you. In arizona, I'm not sure I need stainless steel staples, and all staples for pneumatic staplers at Ace Hardware and Home Depot were like 1.5 inches long. Here's what I've done so far:
I rebuilt wood section to fit into the metal rear window frame (sides and bottom, re-used the non-warped top particle board section). I'll attach those two straps to the frame itself using screws. For staples, I bought a 20 guage pneumatic stapler ($20) and 3/8 depth staples ($ from Harbor Freight Tools (most pneumatic staplers use 1/4 inch staples like 1.5 inches long, too long). So now I need to borrow an air compressor, needs like 4 CFM, too much capacity for the $60 air compressors, and I realize that I won't be continuously shooting staples, there will be a few seconds in between. But that will need to wait, there's liquid water falling from the sky today, think that's the "rain" stuff the old timers talk about here in Arizona....but it was sunny and low 70s all week up until now... |
Yeah, after I wrote that I looked at where you are, do you even have moisture down there?? I've been there in the summer, no hurry to ever return!
Check for flooring staples. They use narrow crown short staples when they do stairs.
they are made, you just need to find an outlet
http://packagingandfastening.com/air_finish_staples_narrow_crown.htm
Ghia
Vanagon
Beetle
Cusser Samba Member
Posted: Sat Feb 20, 2010 6:23 pm Post subject: |
Cusser wrote: |
For staples, I bought a 20 guage pneumatic stapler ($20) and 3/8 depth staples ($ from Harbor Freight Tools (most pneumatic staplers use 1/4 inch staples like 1.5 inches long, too long). So now I need to borrow an air compressor... |
It turns out that this Harbor Freight $20 pneumatic stapler ($25 less 20% coupon) WORKED GREAT, what a find. I borrowed my neighbor's big air compressor, and it never even started up again, so maybe a small air compressor might work fine for it.
Next step is to glue the inside headliner onto the metal of the frame (there's not enough to staple there, and some inner headliner was quite brittle, then try to fit the rear window. I'm able to latch the top, so nothing (yet) is pulling out (I hate pulling out).
Complete new top and repaint is scheduled when the kids get out of college in three years !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Cusser Samba Member
Posted: Tue Mar 16, 2010 7:07 am Post subject: |
Updated: my 19-year-old daughter returned from college for spring break, and helped me install the window, success. I first tried dishwash liquid/water to lube it, then switched to glycerine (helps to work for a soap company). We used 3/16 inch string and some pointy, bent tools to do this, took about a full hour. But it's completed, and I'm happy with the result. My metal rear window frame, and hence the wood I bent to its shape, may have been a tiny bit less-curved due to stretching or warpage of the original particle board frame over the years. But the wooden frame pieces I made apparently dis the trick.
julrich366 Samba Member
Joined: June 05, 2006 Posts: 1306 Location: N.E. Ohio - aka "The Rustbelt"
Posted: Wed Mar 17, 2010 5:34 pm Post subject: |
Very ingenious solution and very good looking result!
I'll be sending my vert frame out to you for
it's needed refurbishing! _________________ - John
'74 Vert ..lot's to still do. |
Cusser Samba Member
Posted: Wed Mar 17, 2010 7:43 pm Post subject: |
julrich366 wrote: |
it's needed refurbishing! |
Like I posted: I wasn't sure I could remount the window frame, so I partly did this for the challenge. I had to get a $20 pneumatic stapler, and it took time to bend/cut/file the wood pieces. If I had known positively that I would be able to complete this, I may have bought the plastic oval insert from West Coast Metric or the squared hard rubber tacking strip sold by Chuck's Convertible Parts. Either way, I would've needed the stapler, electric or manual stapler would not have worked. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bnam Samba Member
Posted: Wed Mar 17, 2010 8:40 pm Post subject: |
Cusser wrote: |
... electric or manual stapler would not have worked. |
Not true... Manual works just fine. That's what I used. No issues even with 13mm deep staples.
B |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Wed Mar 17, 2010 9:28 pm Post subject: |
NICE SAVE!!!!!!!! _________________ Good Luck
Al |
Cusser Samba Member
Posted: Wed Mar 17, 2010 9:58 pm Post subject: |
bnam wrote: |
Cusser wrote: |
B |
Your manual stapler must be considerably more manly than mine. Mine wouldn't drive staples (shorter than 13mm) even half way in. Similar with my electric one (Stanley) which jams up and is a total piece of junk, should have returned it just after a bought it years ago, I will be throwing that away. I also believe that Stanley or no one makes staples for it any longer: great design Stanley, on both fronts. You wanted more profit by having a proprietary sized staple, and you ended up loosing customers for life. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
