AlteWagen Troll
Posted: Wed Mar 03, 2010 4:59 pm Post subject: 1957 rear seat support |
I got this seat support with a lot of other parts in a 57 but have never seen a support with "clamps" before.
They are on the battery side but not sure what they are supposed to do.
Is this rail really from an oval? If so anyone have an idea what they are for?
Thanks |
Tbone Samba Member
Joined: April 18, 2006 Posts: 158 Location: Pfafftown N.C.
Posted: Wed Mar 03, 2010 7:17 pm Post subject: 1957 rear seat support |
derluftwagen,
To me the "clamps" look like they are for wire management.
Perhaps the support bar is for a later model beetle with the voltage regulator under the rear seat.
Ted _________________ Right between the U and X. |
sterling11 Samba Member
Joined: September 27, 2012 Posts: 6 Location: yuma az
Posted: Mon Oct 27, 2014 8:17 pm Post subject: |
Did you ever find out what this is for ? Mine has the same thing.. |
wj32796 Samba Member
Joined: October 31, 2006 Posts: 254 Location: space coast, Fla.
Posted: Mon Oct 27, 2014 8:46 pm Post subject: |
If you place it in the car you will probably find its to long. It looks like it's for a later model car. |
vwsonmybrain Samba Member
Posted: Mon Oct 27, 2014 11:23 pm Post subject: |
Could be wrong as it's been a while since I had it, but I think the rear support for 62 Beetles had clamps to hold the rear heater tubing under the seat. |
GüteAndTite Early Convertible Güru
Joined: June 16, 2005 Posts: 2144 Location: Low So Cal
ryanator Samba Member
Joined: May 17, 2020 Posts: 16 Location: Canfield ohio
Posted: Sat Feb 05, 2022 5:50 am Post subject: Re: 1957 rear seat support |
speaking of rear seat supports, does anyone have one out there for a 57 beetle?...Im in Ohio. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sat Feb 05, 2022 10:43 am Post subject: Re: 1957 rear seat support |
ryanator wrote: |
Remove the ('62-only) clamps as i'd bet all those rails are the same - otherwise - z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Sun Feb 06, 2022 5:43 am Post subject: Re: 1957 rear seat support |
ok, that said....does anyone have, or know where i can get ANY year rear seat support bar? i've checked sites...cip1, jbugs, etc and cannot find any listed?...Its 48" long...I guess i could just use angle iron, prime and paint and be done, but i'd prefer an original one, Thanks! |
mynameismud Samba Member
Joined: October 23, 2002 Posts: 5928 Location: Middle of a corn field
Posted: Sun Feb 06, 2022 6:52 am Post subject: Re: 1957 rear seat support |
ryanator wrote: |
Have you posted a WTB in the classifieds? I bet there is at least 1 floating around out there. 🤷♂️ _________________ Even YOU can prevent FIRES!
Click to view image |
Posted: Sun Feb 06, 2022 7:00 am Post subject: Re: 1957 rear seat support |
no i have not, i will try that, thanks! |
Posted: Sun Feb 06, 2022 11:29 am Post subject: Re: 1957 rear seat support |
... did you look in thesamba classifieds? There are many for sale at just $30, but the 1962 one you have, should function, just fine - i typed in REAR SEAT BAR - Saw and responded to your wanted-ad -, good luck - z _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Posted: Tue Feb 08, 2022 5:55 am Post subject: Re: 1957 rear seat support |
anyone know the difference between a 58 and up rear seat support bar and ones from 58 and below...is see some listed but im looking for one for my 57 sedan? wouldn't think they would change THAT part much??? |
OvalinAz Samba Mini Tech
Posted: Tue Feb 08, 2022 9:24 am Post subject: Re: 1957 rear seat support |
ZENVWDRIVER wrote: |
... did you look in thesamba classifieds? There are many for sale at just $30, but the 1962 one you have, should function, just fine - i typed in REAR SEAT BAR - Saw and responded to your wanted-ad -, good luck - z |
It will not work in a pre 57 car. it is too long. ovals are smaller. _________________ Dad's 4/55 Oval
8/56 Oval
5/64 French Notchback
12/62 French 11 Window Bus
Wedge VW
Pandraggers C.C. |
Posted: Tue Feb 08, 2022 9:31 am Post subject: Re: 1957 rear seat support |
Thanks, Zen |
Posted: Tue Feb 08, 2022 2:47 pm Post subject: Re: 1957 rear seat support |
OvalinAz wrote: |
It will not work in a pre 57 car. it is too long. ovals are smaller. |
I useta' know all that kinda' stuff - thanks - z _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
