Joined: February 21, 2010 Posts: 532 Location: North of Pittsburgh PA
Posted: Wed Nov 03, 2010 5:16 pm Post subject:
I painted the rotor with high temp paint, I installed my Varga calipers, checked the brake hose length. I ask you- have you ever seen anything so beautiful???
Posted: Thu Nov 04, 2010 5:05 am Post subject:
Thanks! It's nice to have something to show for my months of work other than a bare pan leaning up against my garage wall and a big pile of new & refurbished parts! _________________ '73 Beetle (under construction)
'68 Kombi
Posted: Sat Nov 06, 2010 5:01 pm Post subject: shocks & transaxle installed
Today I installed my new KYB GR-2 shocks ($99 delivered for all 4 from rockauto.com!), I installed my transaxle & painted my master cylinder in prep for installation.
Posted: Sun Nov 14, 2010 5:30 pm Post subject:
I disassembled, cleaned, greased & reassembled my pedal cluster. I blasted & powder coated my emergency brake handle. I installed the emergency brake cables, installed the clutch cable bowden tube & accompanying seals, lubed up & installed the clutch cable & throttle cable. Installed the pedal cluster & master cylinder. I installed the new shifter rod bushing, the shifter rod, shifter & the shift rod coupling. I bent & installed the brake line kit from Wolfsburg West (German made, Teflon coated, very nice quality) & installed the rubber brake lines.
Posted: Sun Nov 21, 2010 4:43 pm Post subject:
Disassembled the axle shafts, blasted & powder coated the shafts & CV joint plates, disassembled & cleaned the CV joints, re-assembled everything & greased the CV joints. I must say this has been my most least favorite thing I've done to my beetle yet. Hint: if you pay close attention to how Robert Bentley tells you to re-assemble the CV joints they will go together easily. If you don't pay close attention, they will go together even easier & then lock solid on you. As if they were welded together. Luckily you can still get them apart if this happens!!
Posted: Sat Jul 09, 2011 2:55 pm Post subject: Finally, some updates!!!
Well I guess it's time for some updates. I had been posting most of my progress in the "what did you do to your bug today" section, guess it really should go here. So I purchased a bunch of parts from an older VW guy I found locally, including an align bored case, reground crank, refurbished connecting rods, all new bearings, oil pump, Mahle pistons, rings, jugs & wrist pins, etc, etc, everything needed to build a long block engine except heads. I purchased Mofoco 040 heads, which are technically stock replacement heads, but they flow better & cool better than the stock VW heads. I sand blasted all of my engine tin, buying original VW tins off thesamba classified to replace a few that were too rusted to use. I repainted all except the lower sleds, which I powder coated for extra protection.
I carefully built my longblock, actually having to dis-assemble it once & re-assemble it to correct a couple of things.
After completely assembling everything onto the chassis, and after getting a German made muffler (see pic below) that fit to replace the Danish one (see pic above) that didn't, I was ready to start my newly rebuilt engine for the first time!
As excitement grew, I began to crank the engine, listening for it to come to life. Alas, is was not to be. The fuel pump, which worked when I took it off the engine, did not work now. Well, at least now I can get the proper generator style fuel pump to replace the technically incorrect alternator style that I had on there. The new pump arrives Monday, and hopefully that's when I get to hear her run for the first time! I know she has oil pressure at least, which is good. Stay tuned! _________________ '73 Beetle (under construction)
'68 Kombi
Posted: Sat Jul 09, 2011 4:08 pm Post subject:
Paulc1964au wrote:
Excellent thread so I assume you are restoring back to original.
Look forward to more updates
Pretty much. I added Ghia spindles & disc brakes & a VW of Mexico filter pump, other than that stock so far. It's an early '73 so it had a generator, which I love the look of, so I'm keeping it. But I HATE the look of '73 & later tail lights so I'm making it look like a '72 in that aspect. _________________ '73 Beetle (under construction)
'68 Kombi
Today I broke-in the cam on the engine I just rebuilt! It went great! Good oil pressure, thermostat opened fully, sounded great!!! This videos is running it after the initial cam break-in of 20 minutes:
Joined: April 25, 2011 Posts: 207 Location: Sydney, New South Wales
Posted: Mon Jul 11, 2011 4:56 pm Post subject:
little bit of an idle issue probably because it was cold, sounds great though all it needs now is a body _________________ Visit my VW facebook page Streetwise Aircooled Volksagens
https://www.facebook.com/Streetwiseaircooledvolkswagens
Posted: Sun Jul 17, 2011 12:56 pm Post subject: 34 pict/3 carb adjusted
A few days back I took the oil pump back out & used Permatex® Aviation Form-A-Gasket® No. 3 Sealant along with a new paper gasket to seal the oil pump to the case and this time it does not leak. Today adjusted the valves, checked the timing (dead on with a timing light), and then I adjusted the 34 pict/3 carb by following this step by step: http://www.vw-resource.com/34pict3.html. Excellent guide, I must say. She now starts, idles, and revs beautifully!!! Check it out:
Posted: Sun Aug 14, 2011 3:59 pm Post subject: body dolly/ body cart constructed
Well after having to devote some time to doing some much needed work around the house, I was finally able to turn my attention back to the beetle in my garage. I constructed a cart or dolly, (whatever you want to call it) that enables me to roll the body around, even outside if I need to. Check it out:
Now I can get to work stripping the remainder of the parts off of the body & fixing the rust! _________________ '73 Beetle (under construction)
'68 Kombi
Posted: Sun Aug 28, 2011 5:51 pm Post subject:
Well I'm not even sure if anybody's even watching my thread, but I'll keep posting. Today I finished stripping out the dash pad, wiring harness, & headliner. Lot of work. Then I pressure washed it to clean it up & be rid of the mouse droppings. Yuck. Anyway, had to be done.
All times are Mountain Standard Time/Pacific Daylight Savings Time Goto page Previous1, 2, 3, 4Next
Page 3 of 4
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
