MrVWGuy Samba Member
Joined: February 21, 2010 Posts: 525 Location: North of Pittsburgh PA
Posted: Sat Sep 10, 2011 3:06 pm Post subject: Heater channels- repair them or replace them? |
I wanted this post to be a poll, but I would have to start a new thread, so I guess I'll just ask for some feedback. Today I cleaned some undercoating & seam sealer off in order to better asses the current state of my heater channels. I was planning on replacing them until the reproduction heater channels I bought arrived at my house. I was pretty disgusted with the quality. I realize there are only one or two suppliers in the world who even make them, so I guess I should be happy I don't have to fabricate some new ones from scratch . After watching the bug me videos a couple of times, including recently, I'm well aware that replacing them is a lot of work. And that's before you take into consideration that the replacement heater channels will need to be "worked over" in order to make them work. Then there's the fact that every time I open the door, I'll look down on the crappy looking door sills. Looking at my current heater channels, I've certainly seen worse. They do need some repair. Which means cutting, fabricating, welding, grinding, etc. But I won't have to deal cross bracing the doors & door fitment. That's a plus.
The other thing to consider is the original heater channels' metal thickness is .045", while the reproduction heater channels are only .035" thick, pretty significant difference in my book considering these are structural pieces of the car.
Anyway, please take a look at the pics below & let me know what you would suggest I do- repair or replace. Thanks for looking!
Now here are the replacement aftermarket channels:
 _________________ '73 Beetle (under construction)
'68 Kombi |
jeff plock Samba Member
Joined: February 11, 2010 Posts: 51 Location: golden co
Posted: Sun Sep 11, 2011 6:19 am Post subject: |
well chris your never going to get all the rust thats hideing in the little cracks and its just gonna come back to haunt you once again. So that being said cut the damn things out your new channels look fine whats the issue your having with the new parts? as long as you make door opening supports and have them at the correct opening( put them in before you cut your channels out) its pretty easy to do grind and cut as you go and youll be able to dial it right in} . The issue you were having with the pan holes lineing up with your new heater channels is normal but they should be pretty close if you have to oblong the floor pan so what the washers they give you are huge and they will cover it up
GO FOR IT _________________ love doing fab work have anyquestions send me an e mail maybe i can help |
Posted: Sun Sep 11, 2011 6:30 am Post subject: |
DONT MAKE ME FLY OUT THERE AND CUT THOSE NASTY THINGS OUT MYSELF .
look at how beautifu lyour pan turned the .010 in mat thickness is nothing compared to what is already gone in yours cut them out youll be glad you did _________________ love doing fab work have anyquestions send me an e mail maybe i can help |
Posted: Sun Sep 11, 2011 6:40 am Post subject: |
The floor pans are og, the repop channels don't line up enough to get more than two bolts in them! _________________ '73 Beetle (under construction)
'68 Kombi |
Posted: Sun Sep 11, 2011 7:12 am Post subject: |
you have to ask yourself what the car means to you if its just gonna be a beeeter than fixing is probally the way to go. If its gonna be more than that well you should do it the right way your call keep me posted jeff _________________ love doing fab work have anyquestions send me an e mail maybe i can help |
conrad1468 Samba Member
Joined: December 20, 2003 Posts: 929 Location: Jeannette, PA 15644
Posted: Tue Sep 13, 2011 4:39 am Post subject: |
When i replaced my passenger side heater channel. The bottom of the channel completely fell off. I left my doors on and i put a support piece of angle iron across the door opening. I cut out the old channel with a dremel to help preserve as much good metal i could.
Once the old channel was out I slide in the new channel, lowered the body onto the pan with with the loose channel alined my pan to channel bolt holes the best i could in both channels and started welding in the channel. then took the body back off. I would do 1 side at a time.
Just like the in the bug me videos i built some saw horses to hold the body and i could roll the pan under the body. i have a tiny little 1 car garage.
It does look like your new heater channel is bent. I don't think you want to start with a bent channel. The pan bolts are hard enough to get lined up let alone using a bent heater channel.
I bought mine at CIP1. Like what you said.. The quality just isn't there for body panels.
That's my 2 cents... good luck and get that darn rust out of there!!! _________________ Fresh Air VW Car Club
New Pittsburgh, PA Car Club. 100% free!!!
club website link
http://groups.yahoo.com/group/FreshAirVWCarClub
thesamba link
http://www.thesamba.com/vw/forum/viewtopic.php?t=363031
Look us up on Facebook, too |
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 286 Location: West Auckland
Posted: Thu Sep 15, 2011 6:39 pm Post subject: |
I'm with conrad, something don't look right with that repop.
It's never going to fit the pan like that!
keep up the good work man. _________________ If you can't join them, beat them! |
Posted: Sun Sep 18, 2011 7:02 pm Post subject: Heater channel replacement |
Ok, so I decided to proceed with replacing the heater channels with the reproduction (aka repop) channels purchased from Wolfsburg West. Let me just say first of all, pay close attention to when Rick Higgins says "cut INSIDE of the solid welds around the pillars". Like an idiot, I cut outside of the welds. I have no idea what I was thinking. Learn from my mistake!
They will not come out if you cut outside of the solid welds. I went back & cut INSIDE the solid weld.
Then I drilled out the spot welds, front & rear:
Used the spot weld cutter:
Cut the rear solid weld:
Drilled out more spot welds:
Look Ma! Not heater channel! Note the 1"X1" angle iron bracing.
OK! Now we're getting somewhere! Initial channel fitment:
Note the area below that isn't painted. That's where I had to remove the carpet hold-down strip. Not only was it on BACKWARDS, it was over 2" too far back . Garbage channels.
See how it disappeared under the B pillar? Garbage.
Note the end of the air duct. Yeah, that crap will never fit on the piece it's supposed to go on...
That's as far as I got today. Initial fitment is "poor" at best. As you can see, I have a little bit of fabbing to do, and a lot more rust repair to do . Check back for updates. Thanks for looking. _________________ '73 Beetle (under construction)
'68 Kombi |
TonyPgh Samba Member
Joined: May 31, 2008 Posts: 1017 Location: Irwin, Pa.
Posted: Mon Sep 19, 2011 5:12 am Post subject: |
Wow!! Your project is coming along with pro results. I didn't get into the body work part of mine yet. I dread that part.
Heater channels are a pain!
Your pan and engine are outstanding! Looks like something out of Hot Vw Magazine. I need to stop by and check out your ride. And your garage! _________________ 1972 Standard Beetle. |
19-VW-74 Samba Member
Joined: June 28, 2009 Posts: 660 Location: washington
Posted: Sat Dec 03, 2011 6:33 pm Post subject: |
Any more progress? This thread is a good time  |
Posted: Sun Dec 04, 2011 2:37 pm Post subject: |
| 19-VW-74 wrote: | Any more progress? This thread is a good time  |
Unfortunately life crept up on me, from a number of different angles, and I have not been able to touch my project since September.
But thanks for the kind word, I didn't think anybody was following it anyway!  _________________ '73 Beetle (under construction)
'68 Kombi |
74matt Samba Member
Posted: Sun Mar 04, 2012 12:35 pm Post subject: |
| Just wondering if you had a chance to work on the bug again, It's looking great! |
Posted: Sun Mar 04, 2012 3:43 pm Post subject: |
| 74matt wrote: | | Just wondering if you had a chance to work on the bug again, It's looking great! |
Not recently, but one of the things that has put me off was the poor quality of the Klokkerholm heater channels that I got. So I had hoped to find a pair of originals cut out of a car, but couldn't believe the shipping prices I was quoted. So I finally ordered some new heater channels made by Dansk. They'll be there this Thursday. Hopefully they'll be better quality. We shall see. _________________ '73 Beetle (under construction)
'68 Kombi |
AirDirect Samba Member
Joined: November 03, 2010 Posts: 333 Location: Powderly TX
Posted: Tue Mar 06, 2012 9:54 am Post subject: Heater Channels |
| Nice job cutting them out. Get everything clean and tight before trying to weld. You will be glad you changed them. |
Beetlebaum Samba Member
Joined: December 04, 2008 Posts: 1777 Location: Virginia Beach, VA
Posted: Wed Mar 07, 2012 7:44 am Post subject: |
| Beetlebaum wrote: | | Just found this. Nice pan and chassis! I sure wish mine was that good. |
Thanks! But at least you can DRIVE yours! I cannot... _________________ '73 Beetle (under construction)
'68 Kombi |
Posted: Sat Apr 28, 2012 8:22 pm Post subject: |
| 66busman wrote: | So you're up to 3 bugs now? Congrats, you're in the icantstopbuyingvolkswagens club!
Great job on your project. |
3 bugs & a bus now  _________________ '73 Beetle (under construction)
'68 Kombi |
