Tiico converion quits on the road
Page: Previous  1, 2
MarkWard
MarkWard is offline
PostPosted: Tue Mar 16, 2010 1:25 pm    Post subject: Reply with quote
Something like this? http://www.thesamba.com/vw/forum/viewtopic.php?t=402197&highlight=wire Your problem could be completely unrelated to the conversion. Worth a look.
mgnut
mgnut is offline
PostPosted: Tue Mar 16, 2010 3:34 pm    Post subject: Reply with quote
Well we may have found the problem or perhaps two of them. The plastic cover over the distributor cap had been arcing and a code for the knock sensor came up so I unplugged it and plugged it in again and the code went away. Right now its running as good as new. Only put about 15 miles on it since them. I'll keep driving it and crossing my fingers. Thanks again for all the help. This is a cool website.
mgnut
mgnut is offline
PostPosted: Thu Mar 18, 2010 11:36 am    Post subject: Reply with quote
It probably would be a good idea if I check out this connector. You say it goes to the fuse block?
MarkWard
MarkWard is offline
PostPosted: Thu Mar 18, 2010 12:05 pm    Post subject: Reply with quote
It is on the back of the fuesbox. The type of fuse box that has this later connector has the later style "h" fuses. If you have a older style with the ceramic fuses, you would not have this connector. From the picture and the comments, the pin is undersized for the load. With a conversion there may be some other loads could have been added with the conversion. Often, you are looking for existing wires that have power when the key is on. A used fusebox from the junkyard is often easier to learn on. If you have a U pick junkyard, you could grab a fuse box and cut the harnesses with about 6 inches of pigtail. That will give you a life time supply of connectors. If your plug is melted, most likely the pin in the fuse box has also over heated. Luckily there is a heavier pin available looking at the thread discussion.
r39o
Samba Polizei
r39o is offline
PostPosted: Thu Mar 18, 2010 12:13 pm    Post subject: Reply with quote
The (black) cover on the distributor cap is for radio noise suppression.
The issue with the knock sensor can be many fold. A common problem with the knock sensor is bad connections and incorrect torque/lubrication. The issue is the very low signal levels produced by the sensor are lost through poor connections / attachment. Replacement knock sensors with golden pins were once used to help. There are contact enhancers too. In any case, simply cycling the connection is only a temporary fix.
If you cleared the code via OBD, do not be surprised if it comes back.
mgnut
mgnut is offline
PostPosted: Thu Mar 18, 2010 5:37 pm    Post subject: Reply with quote
What would the torque be and what is the lubrication needed, fir the knock sensor.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Fri Mar 19, 2010 9:50 am    Post subject: Reply with quote
Does Tiico use a Mk3 type knock sensor? (Motronic) If so....
From my A3 Bentley ('93 - '99) for 4 cylinder engines.
"Knock sensor to cylinder block..... 20 Nm (15 ft-lb)"
I have heard that removing/refitting can cause sensor to fail. I suspect that's not really the issue. Over torquing (as manual states) more likely to cause a failure. I have removed/refitted mine (2.0 ABA) w/no issues.
Attach VOM (DC) to 1 and 2 of knock sensor connector. Tap lightly on bolt head mounted. You should see minor voltage fluctuations.
Bentley also sez that if signal missing from knock sensor for any reason, ECM will retard timing by ~ 12*. I can't see this causing a no start, but I'm not certain of that.
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
mgnut
mgnut is offline
PostPosted: Fri Mar 19, 2010 10:28 am    Post subject: Reply with quote
I know that when it retards the timing power is decreased substantially.
Page: Previous  1, 2
Page 2 of 2
