vwbug14 Samba Member
Posted: Sun Mar 14, 2010 5:49 pm Post subject: Front Door Differences |
Was wondering what changes the Single Cab doors had (differences) between 1960 upto 1968?
please help.
Thanks
Mike |
bagpipe goatee Samba Member
Joined: February 26, 2008 Posts: 93 Location: Madison
Posted: Sun Mar 14, 2010 7:00 pm Post subject: |
Yes. In the beginning of 64 they changed the handles, latches, and door panel retainers.
68 was a baywindow with a totally different door. |
oodeftone Samba Member
Joined: November 08, 2004 Posts: 65 Location: Carlsbad, CA
Posted: Tue Apr 09, 2013 9:06 pm Post subject: |
What is the yearly breakdown for changes to the front doors on split busses? 50-55, 56-63, 64-67? I have a 59 and I'm trying to figure out why the passenger door doesn't fit right. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
Posted: Tue Apr 09, 2013 9:45 pm Post subject: |
55-67 fit same opening. Latch and outer door handle area changed. Post images of your fit problem. _________________ In Stereo, Where Available! |
Clara Samba Member
Posted: Wed Apr 10, 2013 8:34 am Post subject: |
here is a thread from the FAQ.
http://www.thesamba.com/vw/forum/viewtopic.php?t=481086
It is about door handle differences, but that overlaps with door differences.
SC doors are the same as the same as on a bus buildt at the same time. |
Posted: Sat Apr 19, 2014 9:54 pm Post subject: |
Eric&Barb wrote: |
55-67 fit same opening. Latch and outer door handle area changed. Post images of your fit problem. |
I know you've been waiting with baited breathe for these photos... Sorry, I was waiting to get the door back together first. Chrome took 6 months! Here are some pics of my passenger door fitment problems. The problem is the overhang in the dogleg area and a very tight fit in the upper, rear corner. What do you think?
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
Posted: Tue Apr 22, 2014 9:26 pm Post subject: |
glideking wrote: |
The door looks correct for '59 by the handle area. I had a similar overhang when installing my new doglegs. The doors are quite flexable and there are many many ways to adjust them. I used lumber and clamps to flatten mine. I think this door can be adjusted to fit but in the end the paint may need repair.
I see a deviation in your dogleg. You could make a cardboard template to compare right and left sides to see if it is the door or dogleg that is out. It is possible to adjust either one. |
Any chance you have pictures of the set-up you used? Maybe a good explanation of what you did exactly. Thanks! |
