allihjelm Samba Member
Joined: April 29, 2009 Posts: 231 Location: Akureyri, Iceland
Posted: Tue Mar 16, 2010 1:45 am Post subject: Seat belts for my 67 |
Hi there,
As spring is getting closer I need to fit seat belts into my 67 Bug as it did not come with belts originally. I will be driving with my family and therefore really need to fit belts in front and back.
I would like to ask you guys what kind of belts I should put into my 67. Would you recommend the retractor front seat belts or the fixed ones? How much space does the retractor take?
Kindly post some pictures of your seat belts arrangements.
I will be buying the belts from Wolfsburg west. Would you recommend a better seller, cheaper maybe?
Thanks, Al. _________________ 1967 European 6V Volkswagen 1300 Beetle |
Stumpy 09 Samba Member
Joined: December 02, 2009 Posts: 59 Location: Charleston,WV
Posted: Tue Mar 16, 2010 6:49 am Post subject: |
I purchased the ones from Wolfsburg West a couple weeks ago for my 67. I did not get the retractable ones because of the price. They were very easy to install. I was very happy with the quality and hardware that came with the belts. The non retractable ones are a little awkward when you get in the car and try to buckle up but I could'nt justify the BIG differance in price. |
Seb67 Samba Member
Joined: December 02, 2003 Posts: 1006 Location: New England
Posted: Tue Mar 16, 2010 7:34 am Post subject: |
The good thing about '67 (and a little bit earlier cars) is that there are seat belt mounting points already installed at the factory. Even if your car did not come with belts, it has the ability for them to be installed. There are mounting points for both lap belts and shoulder belts. modern 3 point retractable belts were not available at the time of production but they can be retrofit with the WW kit you mentioned. Some people say that 3 point belts should only be used in conjunction with seats that have some kind of head rest due to whiplash concerns. Here are your options:
1. Find and install some original retractable lap belts.
2. Find and install some original (non-retractalbe) shoulder belts. These were usually installed outside of the USA.
3. Install modern reproduction non-retractable lap belts as sold by WW and others.
4. Instsall modern 3 point retractable lap belts as sold by WW and others.
The choice is up to you but one thing I would not be asking is: "What is the cheapest option". Do you really want to be cheap on something like saftey?
I am by no means an expert on this so anyone else with more info please chime in. _________________ 1964 Type 1 |
Insaniac Samba Member
Joined: February 13, 2009 Posts: 594 Location: Nor/So Cal
Posted: Tue Mar 16, 2010 11:30 am Post subject: |
I have the non-retractable 3 point style on my front seats. I will say they work good, it's a simple bolt installation. The one problem I have is when other people use them, they seem to confuse people a lot. It's especially annoying when people exit the car and slam the buckle in the door. One of the downsides of non-retractable.
I looked on WW right now, their retractable seat belts are $120? There are many other places you can buy seat belts from, check out this website, there are a lot of different buckle combinations and other things:
http://www.gotbelts.com/index.html
Here is also a retractable seat belt from cip1, with the chrome latch style. It's not bad for the price, includes the plastic sleeve. I think it'd be cheaper to get the same from the other website tho'.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C26-857-033 |
Posted: Tue Mar 16, 2010 3:46 pm Post subject: |
Thanks for you help guys.
Do you know if WW are still selling the retractable belts in light brown?
Any chance even that you guys have photos of the arrangements?
Thanks Al. _________________ 1967 European 6V Volkswagen 1300 Beetle |
bobjoe Samba Member
Joined: August 24, 2006 Posts: 125 Location: Southern California
Posted: Tue Mar 16, 2010 6:49 pm Post subject: |
From their website, it looks like they sell the 3 point retractable in Black only. You can get non-retractable in tan, however. I installed the WW retractable in my 67 and it was fairly easy. You asked how big the retractor is...I'd say it was smaller than a can of Coke and it mounts on a supplied bracket on the B pillar, about next to a rear passengers knee, say. It does get in the way when rear passengers enter or exit, but there's not a lot of room back there to begin with. I have lap belts only for the rear passengers. If by "family" you mean a couple of kids, there's no problem. Adults may be a little cramped in the backseat of a Bug.
Bob |
fluxcap Samba Member
Joined: February 07, 2006 Posts: 1969 Location: Newnan GA
Posted: Tue Mar 16, 2010 8:06 pm Post subject: |
allihjelm wrote: |
Thanks Al. |
I got these from Jbugs a while back. They have them in quite a few colors.
http://www.jbugs.com/store/merchant.mvc?Screen=PRO...=UniBelts4
I went with these because they have the old look, but are retractable. Most retractables have a black plastic receiver piece, but these have the cool chrome latch. I put a wolfsburg crest sticker on mine. They are a little fidgety sometimes when trying to pull them to put them on (they will want to catch), but you just have to pull slow. I don't think it is the fault of the seatbelt, but more the low shoulder mount on the car. The mount is slightly lower that the top of the seat back, so when pulling the seatbelt, you are pulling it up and over the top of the seat, and then down across your chest. Just have to pull slow.
_________________ Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black." |
irishdood Samba Member
Joined: September 30, 2008 Posts: 105 Location: chino hills ca
Posted: Tue Mar 16, 2010 10:55 pm Post subject: |
you could also go down to the junkyard and yank some later 3 point harnesses out of another bug they're almost straight bolt on
all you have to do is drill a hole in the bottom of your b pillar for the post thats on the retractor to seat into
thats what i got in mine but make sure they still have good spring tension in them
mine dont so i end up with my seatbelt hanging out the door when i park it alot _________________ 1967 sunroof bug with 1600 dual port, 34 pict, 034 dizzy |
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
ddadams77 Samba Member
Joined: August 10, 2010 Posts: 1 Location: glendora, ca
Posted: Tue Feb 28, 2012 7:50 pm Post subject: 3 point seat belt installation |
I just finished ulphostrying my car but i can only find 2 seat belt holes , one at the bottom rear seat floor and the other at mid quarter window. Can anyone tell me were the third seat belt hole is? |
Aynthm Samba Member
Joined: July 07, 2010 Posts: 1315 Location: Beaverton, Oregon
Posted: Thu Mar 01, 2012 6:29 pm Post subject: |
I bought the non retractable ones from WW also and they are just fine. I got tired of the center belt flopping between seat and tunnel even getting stuck in there a few times. I found this as my solution that seems to work great.
I had some old used computer chairs just taking up space in the garage and then I noticed the plastic covering on the seat back. Here are some photos that can better explain what I did. It's a good solution for me.
cory464 Samba Member
Joined: November 25, 2010 Posts: 659 Location: kokomo in
Posted: Thu Mar 01, 2012 8:03 pm Post subject: |
don't buy used seat belts. nylon degrades and weakens over time. sun light and other factors also wear them out. just better to get new regardless of style |
vwlovr73 Samba Member
Posted: Tue May 29, 2012 8:34 am Post subject: |
Aynthm wrote: |
That is really slick. I may steal this idea. _________________ 1963 Beetle euro spec "Darrel" (since 2012)
Past - 1973 Beetle "Arthur" (owned 1998-2005)
Red River VW Club- http://www.redrivervwclub.com |
dbelkhart Samba Member
Posted: Tue May 29, 2012 9:55 am Post subject: |
My jeep wrangler has the same type of belt that makes it curve and free-standing. Could get a used set somewhere, not sure about the other side to click into it? _________________ Banging on all four cylinders.... |
Aynthm Samba Member
Posted: Tue May 29, 2012 11:11 pm Post subject: |
vwlovr73 wrote: |
Aynthm wrote: |
That is really slick. I may steal this idea. |
Thanks, those buckles kept falling between the tunnel and seat rails and getting stuck. This keeps them right where you need them at all times and was free. Doesn't look too bad either. |
pb_foots Samba Member
Joined: April 15, 2010 Posts: 1089 Location: Ben Lomond, CA
Posted: Wed May 30, 2012 5:30 am Post subject: |
That's perfect! I can't tell you how many times I've had to contort myself to get to the buckle that has fallen between the seat and the tunnel.
Wonder where I can buy just those pieces? |
Posted: Wed May 30, 2012 6:30 am Post subject: |
pb_foots wrote: |
I bet if you looked at a thrift store you could pick up a couple of crappy desk chairs for under $5 a pop. _________________ 1963 Beetle euro spec "Darrel" (since 2012)
Posted: Wed May 30, 2012 6:34 am Post subject: |
I just noticed that this post was from 2010 and the rebirth of this post was asking where to find the third seat-belt bolt hole. Am I correct or did I read this wrong? _________________ Banging on all four cylinders.... |
Posted: Wed May 30, 2012 6:54 am Post subject: |
dbelkhart wrote: |
I just noticed that this post was from 2010 and the rebirth of this post was asking where to find the third seat-belt bolt hole. Am I correct or did I read this wrong? |
Oh funny. It sure is. I just saw the chair-back mod and got all starry eyed. Having installed belts over the weekend in my 63, here's what I can tell you about that year, I don't know for other years.
I had plastic plugs in the car plugging seat belt holes in the following locations:
For front seats:
--mid-way up the b-pillar (shoulder hole)
--on the floor just inside the heater channel (behind the seat rail on either side)
--on the tunnel (again, behind the seat rail a bit).
For rear seats:
--in the center above where the tunnel/chassis VIN stamp is.
--behind each rear window (for rear shoulder belt)
There was no designated belt hole for the outer part of the rear seat lap belt. You use two of the bolts that are already in the car.
Also, I have read that having these holes in the car was a factory option (I think??). It might depend on what options your car had, and whether it was a german, export, or where its intended destination was when it left the factory. From what I understand I was pretty lucky that I had all these holes in my 63.
Here's a pic to help you.
I don't have a pic of the front seat area before i installed them, but this one shows them installed in the holes in the tunnel, for the front seats.
Posted: Wed May 30, 2012 7:10 am Post subject: |
I thought it was about seat-belts too until I finished my 2nd cup of coffee. Maybe I will get to work now or maybe I won't. ha ha, I just might stay on here. _________________ Banging on all four cylinders.... |
