turbo_dub Samba Member
Posted: Fri Jun 01, 2012 5:58 am Post subject: |
vwlovr73 wrote: |
Here's a pic to help you.
Is that upper hole behind the window really for a shoulder belt? I have this in mine and am getting ready to install belts for my kids. I wasnt sure if that upper mount was for a rear shoulder belt or possibly for a pop out rear side window. |
vwlovr73 Samba Member
Posted: Fri Jun 01, 2012 6:03 am Post subject: |
turbo_dub wrote: |
vwlovr73 wrote: |
You know, I'm really not sure. Perhaps someone else can answer that one? I will say, it has the exact same plastic plug in it that all the other seatbelt holes had. That's why I assumed it'd be for a rear shoulder belt (though I know rear shoulder belts were never used in these, at least I've never seen them). _________________ 1963 Beetle euro spec "Darrel" (since 2012)
Past - 1973 Beetle "Arthur" (owned 1998-2005)
Red River VW Club- http://www.redrivervwclub.com |
Posted: Fri Jun 01, 2012 6:17 am Post subject: |
I am interested in a retractable belt for the rear as well. Does anyone have a retractable rear? |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
Posted: Fri Jun 01, 2012 10:19 pm Post subject: |
vwlovr73 wrote: |
turbo_dub wrote: |
vwlovr73 wrote: |
You know, I'm really not sure. Perhaps someone else can answer that one? I will say, it has the exact same plastic plug in it that all the other seatbelt holes had. That's why I assumed it'd be for a rear shoulder belt (though I know rear shoulder belts were never used in these, at least I've never seen them). |
YES that plug is for the shoulder belt. It is the EXACT same plug you will find under the grab strap on the B pillar in a '67 for the shoulder harness anchor for the front seats. The popout latch had three small screws close to the window. As for a retractable shoulder belt in the rear, one was not made for the '67. If one IS made nowadays, you should check with Wolfsburg West. If they dont have it, it doesnt exist. _________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
NayaBeach Samba Member
Joined: August 29, 2012 Posts: 167 Location: Puerto Vallarta
Posted: Fri Oct 04, 2013 7:04 am Post subject: |
67 Florida Deluxe wrote: |
vwlovr73 wrote: |
turbo_dub wrote: |
vwlovr73 wrote: |
YES that plug is for the shoulder belt. It is the EXACT same plug you will find under the grab strap on the B pillar in a '67 for the shoulder harness anchor for the front seats. The popout latch had three small screws close to the window. As for a retractable shoulder belt in the rear, one was not made for the '67. If one IS made nowadays, you should check with Wolfsburg West. If they dont have it, it doesnt exist. |
Just installed rear seatbelts, retractable type three point. The car had holes in all places except the center one.
I welded on nuts with bug original thread for seatbelts in the holes with reinforcements around. Used original bolts from vs bug as well.
Bought Brazilian made Swedish brand seatbelts with CE certifications for a small sum and installed.
Looks fine and works okay. Cramped. Old car.
I'd show you some photos if photobucket mobile would work.
My holes on the sides were located a little close to the window and walls. But my bug is a 1990 Mexico bug. _________________ Roger
Mexican Bug
Puerto Vallarta
"The purpose of life is to enjoy it." |
Longboardluv Samba Member
Joined: September 23, 2014 Posts: 934 Location: Austin TX
Posted: Tue Sep 23, 2014 8:46 am Post subject: |
NayaBeach wrote: |
vwlovr73 wrote: |
turbo_dub wrote: |
vwlovr73 wrote: |
My holes on the sides were located a little close to the window and walls. But my bug is a 1990 Mexico bug. |
Can you put up some pics of the install with the rear retractable belts? |
cab57 Samba Member
Posted: Wed May 25, 2016 12:53 pm Post subject: |
fluxcap wrote: |
allihjelm wrote: |
Thanks for you help guys.
Do you know if WW are still selling the retractable belts in light brown?
Any chance even that you guys have photos of the arrangements?
Thanks Al. |
I got these from Jbugs a while back. They have them in quite a few colors.
http://www.jbugs.com/store/merchant.mvc?Screen=PRO...=UniBelts4
I went with these because they have the old look, but are retractable. Most retractables have a black plastic receiver piece, but these have the cool chrome latch. I put a wolfsburg crest sticker on mine. They are a little fidgety sometimes when trying to pull them to put them on (they will want to catch), but you just have to pull slow. I don't think it is the fault of the seatbelt, but more the low shoulder mount on the car. The mount is slightly lower that the top of the seat back, so when pulling the seatbelt, you are pulling it up and over the top of the seat, and then down across your chest. Just have to pull slow.
Hi,
what is the color of your belts : Grey #6005 or Silver #6007 ?
Could you post a picture of the latch system ?
Thanks _________________ Beetle convertible built 06/66
Beetle ragtop built 28/04/59 |
dvancleve Samba Member
Joined: August 11, 2013 Posts: 129 Location: Chandler, AZ
Posted: Tue Jul 05, 2016 3:41 pm Post subject: |
turbo_dub wrote: |
Pretty sure I know the answer, and I'm pretty sure that it's "no". Is it possible to put retractable three-point belts in the back? It looks to me like the retractor would keep the rear seat bottom from fitting in. I'm sure the late style retractable lap belts could be used, not sure anyone sells those new.
Thanks, Doug _________________ '62 ragtop bug w/ '71 1600 dual port |
bird blaster Samba Member
Joined: June 04, 2018 Posts: 49 Location: Ontario, Canada
Posted: Wed Aug 22, 2018 6:24 pm Post subject: Re: Seat belts for my 67 |
just posting in an old thread.
I have a '63 in which I would like to add rear belts for my kids.
I have a grey interior. Who carries a nice non-retractable?
Thanks for the help...well more thanks from my 2 & 5 year old. They absolutely love the beetle and they want to be in it as much as possible.
Murdlem Samba Member
Joined: February 06, 2004 Posts: 512 Location: Port Angeles, Washington
Posted: Thu Aug 23, 2018 3:49 am Post subject: Re: Seat belts for my 67 |
Great - thanks so much!!! |
Posted: Fri Sep 07, 2018 8:40 pm Post subject: Re: Seat belts for my 67 |
Quick update. Thanks for the help.
Seatbelts in grey look good in the car. Pretty close colour to the fronts. Super easy to install and can be taken out just as easily!!!
Made for some very happy kids to finnaly go out for ice cream!
