tziegler03 Samba Member
Joined: December 17, 2009 Posts: 145 Location: Tampa, FL
Posted: Tue Oct 25, 2011 3:54 am Post subject: |
The front is on air ride. That's aired down in the front. |
maggiolino91 Samba Member
Posted: Wed Oct 26, 2011 2:44 pm Post subject: |
what type of blue is this? it's amazing! _________________ 1956 strato silver L227 ragtop
1961 beryl green L478 ragtop
1973 superbeetle pastelweiss L90D |
Posted: Wed Oct 26, 2011 2:49 pm Post subject: |
The color is Sea Blue. It's an original color for 64. |
Hugo Stiglitz Samba Member
Joined: August 07, 2009 Posts: 782 Location: Southern California
Posted: Wed Oct 26, 2011 3:14 pm Post subject: |
I think I asked this in another thread you posted in, but are those AirEvo wheels? _________________ '63 slow n low build thread...
Jay Leno's Garage
(o\ ! /o) | o \/ o | (o)=|=(o) [o\|_|_|/o] |
Posted: Wed Oct 26, 2011 4:17 pm Post subject: |
They are brm reps. |
Posted: Wed Oct 26, 2011 6:39 pm Post subject: |
CIP1 |
Posted: Mon Nov 28, 2011 9:31 am Post subject: |
GtiKyle Samba Member
Joined: March 27, 2008 Posts: 211 Location: Tacoma, WA
Posted: Mon Nov 28, 2011 9:52 am Post subject: |
Wow...I'm in love. It's beautiful, nice work sir |
Posted: Mon Nov 28, 2011 9:56 am Post subject: |
Thank you very much!!! |
ottvw Samba Member
Joined: February 28, 2006 Posts: 928 Location: Auburn,WA
Posted: Fri Dec 02, 2011 7:40 am Post subject: |
Is it still 2" narrowed beam with dropped spindles? Did you have to run a spacer in the rear? _________________ Save a tree eat a beaver |
Posted: Fri Dec 02, 2011 7:50 am Post subject: |
Yes 2" narrow up front with drop spindles. I am running spacers in the rear. I am going to swap out the rear drums this weekend with Thing drums. Uses the same axle length but the face of the drum is further out, to eliminate some of the 1 5/16 worth of spacers, that I am not very comfortable with. |
ottvw Samba Member
Posted: Fri Dec 02, 2011 8:31 am Post subject: |
Cool thanks. I ran a 1" with my old 17's. You could always run 67 axles they are wider. _________________ Save a tree eat a beaver |
BYeaton Samba Member
Joined: November 27, 2007 Posts: 362 Location: El Segundo
Posted: Fri Dec 02, 2011 9:02 pm Post subject: |
Those BRM's really set it off, car looks fantastic. Great Job.
One thing I've noticed is how dirty the underside of the deck lid is. If you're showing it as much as it seems you are, take that thing off and detail it out. You'll thank yourself you did. |
Posted: Wed Mar 28, 2012 10:06 am Post subject: |
Here's a newer one!
JDGas Samba Member
Joined: June 23, 2004 Posts: 1233 Location: Escondido
Posted: Wed May 09, 2012 3:59 am Post subject: |
Thank You very much. I'm running 205/40's all the way around. |
Todd66 Samba Member
Posted: Wed Aug 01, 2012 8:52 am Post subject: Brakes |
Love the look. I have been looking at running a 17" wheel combo when I ran across your thread. You said you had dropped spindles/disc brakes. What brand are you running? Do you have any tire rub? If so, where? I want to keep the wheels out as wide as possible. I can't go as low as yours due to the great roads where I live, but love the look you have of the wheel wells being filled up. Thanks. |
Posted: Tue Aug 07, 2012 4:32 am Post subject: |
Thanks Todd!! I am running a 2" narrows beam up front. I am running 2 1/2 drop spindles up front, not sure of the brand, they where on the car when I got them. I'm still running 4 wheel drum brakes on the car, all stock. As for rubbing I have a lot of spacer in the rear. I only rub out back when I have 2 people in the car and hit a big bump or take a hard turn, the top of the tire will rub on the back inner fender well because of all the camber. The front is on air ride, so I don't have any problems rubbing. What you see in the latest pictures is the car aired all the way down. I can't drive the car that way.The rear is a static drop and that's how I drive it. Let me know if you have any other questions. Thanks again. |
Posted: Thu Apr 17, 2014 8:36 am Post subject: |
It's been a while but here are some recent pictures of the car..
