kever56 Samba Member
Joined: September 06, 2004 Posts: 14 Location: Antwerp
Posted: Sun Mar 28, 2010 1:43 am Post subject: Clean engine case |
What's the best way for cleaning an engine case.
I've seen pic's here of the okrasa engines of mr okrasa and they are really "clean"
greetings
Geert |
oval56 Samba Member
Joined: July 21, 2003 Posts: 1309 Location: oktoberfest maintown
Posted: Sun Mar 28, 2010 2:38 am Post subject: |
the most are mediablast their cases with glaspowder but the cleaning is the main point after that ( removeing all oilplugs), cleaning all oildrains and if you think it is clean, do it again...
mr. okrasa do als a threatment of coating his cases to get the gold looking surface but that is his TOP secret how he does it... _________________ www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sun Mar 28, 2010 7:28 am Post subject: |
Do you blast it yourself? With wat?
Do you also doing the inside?
How do you protect the parts that you can't blast
Greetings |
SixVolt Samba Member
Joined: January 04, 2004 Posts: 1136 Location: Cleveland, Ohio
Posted: Mon Mar 29, 2010 3:31 pm Post subject: |
hazetguy wrote: |
some of the cleanest cases i have seen recently have been hot tanked and then soda blasted. the cases look NOS and the soda washes away with water.
A veteran VW guy said he was a little concerned about my planning a "hot tank treatment" for my backup 36 HP case. He seemed to be more concerned that it was a 36 and not a 1600, but I may not have that right. It's never been line bored. I have a local guy that will "tank" it for $25. I know Hazetguy knows his stuff, so what are the possible concerns about magnesium and a hot tank? I still consider myself to be a novice, so I know nothing. I want to hot tank it to be sure I'm getting it really clean. Also, I don't think this guy is going to 'soda blast' my block, so am I still good to go with the "tanking"? I'm not building a trailer queen. Here's my case currently sprayed with 'Easy Off'...
outoftheoffice Samba Member
Joined: March 02, 2009 Posts: 470 Location: Houston, Texas
Posted: Mon Apr 19, 2010 6:51 pm Post subject: |
Glad I found this thread. I'm also building a 36 horse and am considering cleaning the case while I have it torn down. Don't need to eat off it but don't want to spend all summer scrubbing either.
I am considering splitting the case then blasting it with walnut shells or some type of glass. Also planning on blasting the heads at the same time. Are there any holes in my plan?
Posted: Mon Apr 19, 2010 7:18 pm Post subject: |
outoftheoffice wrote: |
I started a 36 HP rebuild thread in here in Vintage, but it was moved to the Oval section. I don't know why. I'm sure there's probably a valid reason. What's funny is, I don't even have an oval.
Anyway, a few folks have weighed in (negatively) on glass beading a case. I don't know enough to comment. I dropped mine off before I read anything on the subject so I'll see when I get it back. You can read their comments here. http://www.thesamba.com/vw/forum/viewtopic.php?t=408776 |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
spectre6000 Samba Member
Joined: April 19, 2009 Posts: 2014 Location: Broomfield, CO
Posted: Wed Aug 25, 2010 6:13 am Post subject: |
I'm going to go with Bill on this one... Magnesium is fairly reactive, and any amount of residual grit in your case does not bode well at all... Soda seems like it would be OK from a grit standpoint since it's water soluble, but I don't know how it would react (it might not) with the magnesium. _________________ Jason Hopper
-'58 German Market Deluxe Beetle (in progress)
-'84 M1009 CUCV
-'81 K10
"Buy the best, cry once." -Gene Berg
"A cheap man will always buy the cheapest thing available, and then buys another one hoping for a better result, and then spends the rest of his life in misery complaining about it. A thrifty man will buy a good part once and never think about it again." -RockCrusher
"Don't feed the Shitty Parts Monster!" -Me |
Louis Samba Member
Joined: September 26, 2007 Posts: 423 Location: canada BC
Posted: Wed Aug 25, 2010 11:18 am Post subject: |
MR Okrasa uses a dow treatment for the gold coating and i heard that he uses a tumbler for the case.
i also read that he clean everything very good and when he thinks its ok, he reclean everything again (oil galleys)
the guy is building some nice stuff. |
Der6VoltFahrers Samba Member
Joined: April 15, 2009 Posts: 84 Location: Hannover Germany
Louis Samba Member
Posted: Wed Aug 25, 2010 3:43 pm Post subject: |
i say the best look for a 36er would be soda blast the outside while the motor is still together and then polish the generator stand, that would look awesome!! polishing is bad as the heat doesnt desipate but just the stand would cool as you dont see the rest of the motor anyway...
the gold look kind of ugly to me...and it rub off after a few year anyway.
i have nos 36 block that has the original coating and its way darker than mr okrasa's coating, he is not very accurate with his tone.
if you really want original you have to go dark. no one is doing that really. ill post a picture later of the REAL gold color . |
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Sat Aug 28, 2010 7:20 am Post subject: |
Soda blasting the case only removes the grime and grease...it does not etch or clean the magnesium...to do that it needs to be cleaned with a glass powder then treated with the top secret gold coating...to look factory of course...removing oil plugs and using rifle brushes or something similar is the best way to ensure no garbage is left...
Joe has done my Okrasa ,my 36 hp , and my split case for my Binz...top notch guy with a very good attention to detail...sure I could have done the job myself but having a guy like Joe on your side is extremely helpful when you are in need... _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Aug 28, 2010 9:03 am Post subject: |
Another system for cleaning them available now days, is "dry ice" blasting.
No residue. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sat Aug 28, 2010 1:22 pm Post subject: |
Russ Wolfe wrote: |
No residue. |
Dry ice blasting will achieve the same kind of results as soda,walnut shell,or plastic....the difference is all of those are coast effective...where as dry ice is hardly something you will find cost effective for an engine case...maybe mold remediation. _________________ www.blastserv.com
wanted:
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Sat Aug 28, 2010 1:48 pm Post subject: |
Russ Wolfe wrote: |
No residue. |
Although there is no residue from the media, there is residue from what is blasted off. It needs to be cleaned up just like any other blasting. If there wasn't anything left over you wouldn't need to blast it, right? _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Sunroof53 Samba Member
Posted: Sat Aug 28, 2010 2:17 pm Post subject: Water |
I have used lots of things in the past and found Two pack paint thinner to be the most effective non destructive method.Wet blasting is good and gives a nice finish ,but i always finish of with soapy water either a pressure washer or dunk in a tank.One thing i would always do is pull the plugs in the case. |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Sat Aug 28, 2010 3:31 pm Post subject: |
Where I used to work we had a CO2 blaster for the injection molds in the production area. It worked great on cases and heads, but you're right to say it not something that would be affordable for the hobbiest. I use soda also but that needs to be rinsed in hot water, I have a dishwasher for just that purpose. (Don't use the one in the house, the wife may get mad) _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sat Aug 28, 2010 9:34 pm Post subject: |
Can you use baking soda in a regular siphon type sand blaster? I want to do a case but I dont want to use glass. I have access to 80 grit "garnet" that we us in the water-jet at work, do you think it would be to coarse and damage any surfaces in the case?
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
cru62 Samba Member
Posted: Sun Aug 29, 2010 8:07 am Post subject: |
I've used it in a small gravity feed/siphon gun with excellent results. I bought regular food grade baking soda at a food service supply store in 10 lb. bags. I was using it to blast some wire mesh air cleaners and did not want ANY chance of the media getting sucked into my engine. It worked fantasic!
Don't use garnet, or sand on your case. They are way too aggressive and could damage surfaces you don't even want to touch. Glass beads are about as aggressive as you want. gatorwyatt is a good resource. Look at his posts for info. And there are some pic of the blasting I did in my gallery. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
