quadrazer Samba Member
Joined: April 11, 2010 Posts: 293 Location: Castalia, Ohio
Posted: Sat Apr 17, 2010 5:30 pm Post subject: Brian's V-6 rail (re)build (pics added daily) |
Last spring, I built my sand rail from the ground up in just under a 3 month period to have it ready for our sand dune trip. The chassis was a knock down Berrien kit, with parts gleaned from a 68 Beetle donor car. Using all stock VW suspension front and rear, a factory IRS transaxle, and powered by a built 3.8L Buick odd-fire V-6. It worked well in the sand with the paddles on it, but was lacking in aesthetics, and needed some modifications in the rear suspension as well. This prompted me to tear it down to the bare chassis a few weeks ago and basically build it again. This time...I'm adding some color to the chassis and other components, long travel rear trailing arms, rear disc brakes, matching aluminum wheels and new tires, as well as a few other odds and ends. I'll add more pictures as the build progresses.
Here's what it looked like last year when I first built it:
Here it is all torn down to the frame a few weeks ago:
After sanding the origional paint and putting it into primer/sealer:
With a base coat of Vermillion Red paint:
And finally the clear coat. Ready to begin assembly:
Front seats, aluminum diamond plate floor (rhino lined), headlights and passenger grab bar put on:
Trans primered 4-19-10
Trans painted 4-19-10
Hi torque starter housing primered 4-19-10
Hit torque starter painted 4-19-10
Transaxle installed with hi torque starter (still have to change transaxle flanges to Type 2) 4-19-10
chopperhopper Samba Member
Joined: October 17, 2009 Posts: 71 Location: Niceville, FL
Posted: Sat Apr 17, 2010 6:45 pm Post subject: |
| Looking good so far! Rhino Lined floor huh?.......got me thinking about doing that to mine now. How well does it seem to stick to the aluminum floor? I am also in the process of rebuilding mine and I haven't decided how I want to strip the old paint, how did you strip yours? |
Posted: Sat Apr 17, 2010 6:53 pm Post subject: |
| chopperhopper wrote: | | Looking good so far! Rhino Lined floor huh?.......got me thinking about doing that to mine now. How well does it seem to stick to the aluminum floor? I am also in the process of rebuilding mine and I haven't decided how I want to strip the old paint, how did you strip yours? |
My aluminum floor was looking pretty rough. Used to be polished, then it was scratched to heck, and some corrosion was on it. I cleaned it off with a degreaser then scrubbed it with a scotchbrite pad to ruff it up a bit. I bought two rattle cans of Rustoleum Truck Bed coating (bought at Wal-Mart) and laid in two coats. It adheared fine, and the black matte finish looks great. Not to mention the slightly gritty finish will keep your feet from sliding around.
I did not strip my old paint....I sanded it! And sanded it...and sanded it! LOL! I started with 180 (since I had next to no rust) and worked up to 320 before priming. Then wet sanded the primer with 400 before sealing and finally painting. Tons of elbow grease, but it was totally worth the effort! |
Posted: Sat Apr 17, 2010 8:45 pm Post subject: |
| Wow, sanded?! You definately have more patience than me, thats a whole lot of nooks and angles to get into. I am thinking about a liquid paint stripper, but have never used it before. Sandblasting in my area seems to be CRAZY expensive. |
Posted: Sun Apr 18, 2010 5:33 am Post subject: |
My origional paint job was POR 15 rust preventative paint. I didn't want to take that finish off completely due to the protection it offers against rust. The nice thing about sanding my chassis was, it allowed the origional paint to act as a leveler to fill in the low areas as I sanded, which in turn provided me with a flatter surface overall in which to paint. And yes....it took me a little over a week to hand sand it, and yes...it sucked. But as you pointed out, sandblasting is rather expensive to have it done. If I were to sandblast, I would buy the sandblaster setup and do it myself. Harbor Freight has a sandblaster for outdoor use that you can get for $130 plus shipping and blast media, here's the link to it: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95014
Obviously you would have to have a good area outside to use it, but it would be worthwhile if that were the route you chose to go. But I'm sure you can find a quality paint stripper out there that would work also.
In regards to the 'nooks and angles' encountered during sanding, I used a scotchbrite pad to sand in theses areas as it conforms really well to the hard-to-get-at areas where sandpaper would be impracticle. |
Posted: Tue Apr 20, 2010 4:48 pm Post subject: More pics |
I got my new 2x3 Rear trailing arms in primer.
And installed my new Type 1 to Type 2 axle flanges on the transaxle. Still waiting for my seal plugs to get here to put them in.
Step by small step....she inches closer to completion!
Posted: Wed Apr 21, 2010 2:02 pm Post subject: Front ball joint beam |
Got my ball joint beam sandblasted today. Nice to have it down to the bare metal and see how good the condition is. No holes, no cracks...looks good. Now to flush it clean on the inside, hand sand it a bit and get it in to primer, then paint.
Posted: Thu Apr 22, 2010 2:07 pm Post subject: Valve covers painted |
Well, I got the valve covers painted. These are for the 3.8L odd-fire Buick V-6 I'm running in my rail. Not gonna get a whole lot more done tonight, since I want to watch the NFL draft on TV. But tomorrow is another day, and at least I got something done tonight!
po7g Samba Member
Joined: June 15, 2004 Posts: 454 Location: Schererville, Indiana
Posted: Thu Apr 22, 2010 7:39 pm Post subject: |
| is your type one stock or does it have some beefing up done cause I was always told you should go with a 091 trans to a larger motor cause you will tear up your trans |
carlos_magnum Samba Member
Posted: Thu Apr 22, 2010 8:47 pm Post subject: |
| Looks like you're in the right track! Will definitely follow this build thread. |
Pozi Samba Member
Posted: Fri Apr 23, 2010 7:48 am Post subject: |
| po7g wrote: | | is your type one stock or does it have some beefing up done cause I was always told you should go with a 091 trans to a larger motor cause you will tear up your trans |
I too am curious. Buick V6 with a type-1.
...tick tick tick |
ataim Samba Member
Joined: June 17, 2009 Posts: 219 Location: Fort Worth
Posted: Fri Apr 23, 2010 9:40 am Post subject: |
| Pozi wrote: |
...tick tick tick |
 _________________ I like steak. |
Posted: Fri Apr 23, 2010 12:57 pm Post subject: |
Not the first time I've heard this exact comment. And yes...I agree it would be an issue IF I were even remotely hard on this tranny. But last year, when I built this, was the 1st and currently the only time it was off-road...on the dunes in the sand...for one full week. The key to it's survival was, in my opinion, tire slippage. I used 28" diameter paddles with this setup and thankfully never got a ton of grip, as I'm sure it would have grenaded this tranny. Obviously, the Type 1 was never designed for this application (or abuse) and any kind of a serious shock load to the tranny would toast it. On the street, I don't dump the clutch or anything, specifically to save this tranny, for now.
I know, "Why build a rail if you can't pound on it even a little bit?" Well, the short answer is: this is what I had, it got me to the point where I could use it, and it gets me by for the time being. I guess it beats not being able to use it at all!
As this is a work in progress (and it will be for a long time as I get different upgrade parts), I will eventually upgrade to a bus tranny, just to be able to take the punishment. But for now, I bide my time and take it as easy as I can (tick tock ) to try to preserve this tranny. Thanks for the comments, and pointing out a VERY valid concern that I also share! Please, feel free to comment on anything regarding my rebuild, as I welcome any thoughts for upgrades, or just general ideas. Thanks again!
po7g Samba Member
Posted: Fri Apr 23, 2010 5:04 pm Post subject: |
| I agree that babying your trans will save it. I had a type one trans in my car and it never gave me a problem and I found a hell of a deal on a 002 so I had to go get it. I would say if you could find a super diff for ur trans I would strongly recommend you install one of those. |
Posted: Fri Apr 23, 2010 5:10 pm Post subject: |
| po7g wrote: | | I agree that babying your trans will save it. I had a type one trans in my car and it never gave me a problem and I found a hell of a deal on a 002 so I had to go get it. I would say if you could find a super diff for ur trans I would strongly recommend you install one of those. |
Thanks for the tip! I guess the overall question is, depending on how it's used, would a super diff in my Type 1 be better than upgrading to a 3 rib Bus transaxle? |
Posted: Fri Apr 23, 2010 5:29 pm Post subject: V-6 Engine cradle |
Ok, here are 2 pictures of my engine cradle I built to house my 3.8L Buick V-6. Commonly know as "underbars" in regards to Berrien Chassis', I modified mine by adding motor mounts and moving the crossover bar down and back in order to clear the belt driven accessories of the V-6. The nice part is, with the engine mounted, the bottom of the oil pan sits almost flush with the top edge of the underbars. This will allow me to install a skid plate completely flush along the bottom of the underbars to help protect the engine oil pan.
The pic below shows the side view of the motor mounts:
Posted: Sat Apr 24, 2010 3:47 pm Post subject: Rain delay on paint |
Well, mother nature decided to give me 55 degree weather with high humidity this weekend which stalls me from painting my front beam, rear trailing arms and a few other odds and ends. Never fails...sunny and 65-70 degrees monday thru thursday and then crappy weather when I have a weekend off work!
Anyways, I thought I would toss up a pic of my old dash assembly I made last year for my rail. It wasn't exactly pretty, but it was quick and allowed me to get the rail running for my dune trip last summer. I used an 1/8" thick piece of aluminum plate and mounted it to a plastic housing to keep everything dry and covered. It worked great, never failed, and held up to all the vibrations like a champ. I intend to make a new center console assembly to house everything, and to look a bit nicer. Most likely a floor to windshield frame setup.
The old dash:
The 4 empty holes surrounding the speedo in the above pic are the mounting holes for the dash to mount to the plastic housing. The bolts are removed in this pic. _________________ I DID wash my hands....the rest is 'built-in' dirt!
My build: http://www.thesamba.com/vw/forum/viewtopic.php?t=409845 |
Posted: Sun Apr 25, 2010 12:53 pm Post subject: Engine adapter plate & headers |
Well, since the weather isn't cooperating, no painting at all this weekend. But, I did start wrapping my headers for the 3.8L V-6 today. I got the driver side header wrapped, still have to do the passenger side header yet. The headers collectors are welded directly to the Supertrapp exhaust cans with diffuser discs on the ends. And yes...my shop is a mess and the floor needs swept! Rags, sandpaper, and what not from this project are all over the place under and around the chassis. I'll get to it as soon as I can (about the same time I finish the rail!)
The picture below is of the engine adapter mounted on my tranny. This allows me to mount the Buick 3.8L V-6 to the tranny.
DONT Samba Member
Joined: October 19, 2006 Posts: 338 Location: Gilbert, AZ
Posted: Mon Apr 26, 2010 4:34 pm Post subject: |
| Looks nice. BTW, what is the white project car hiding in there? |
Posted: Mon Apr 26, 2010 5:00 pm Post subject: |
| DONT wrote: | | Looks nice. BTW, what is the white project car hiding in there? |
Hiding? No....it's just camera shy! It's a Lamborghini Countach Anniversary Edition kit car. Sitting on a Fiero chassis....but that's a WHOLE other story! I can send you a pic of it if you'd like.
As for my rail...here is a a pic of my ball joint trailling arms (spare set) that I am sandblasting and repainting. If mother nature decides to give me good weather to let me paint them, I'll press in the new joints when they're done.
The below pic is after sand blasting. Took FOREVER to get the old crud off of it. Only 3 more to go......
