HoustonPhotog Samba Member
Joined: February 20, 2013 Posts: 1514 Location: Houston, TX
Posted: Wed Aug 20, 2014 5:35 am Post subject: |
pbrown wrote: |
It wasn't me but I was bidding on that same set.
--Patrick |
Doh my bad... I prolly bumped you out too only to get bumped out myself.
I just won this set of new take-offs on ebay yesterday. i was the only bidder. brand new, no miles, stored for 14 years. mint!
Paid $450 and $150 for shipping.
funny that 2 sets of brand new unused CLK wheels hit ebay within a week of each other... that NEVER happens...
I know many people luck out and find great sets on craigslist for $100-$200 but I havent found any in my area at all. Even though I have these coming I'll still be on the look out locally...
_________________ Abel Longoria
VanAlert App for Vanagons/Buses | Texas Vanagons | My Vanagon Build Thread | Follow Me On Instagram | Vanagon-centric Stickers Available Now |
babywindow Samba Member
Posted: Tue Sep 16, 2014 1:17 pm Post subject: CLK Wheels |
For future reference, the wheels being discussed here are MB Part #
2084010002
Also known as "Tolimans", but rarely called that. |
imdbui Samba Member
Posted: Wed Sep 17, 2014 6:12 pm Post subject: |
HoustonPhotog wrote: |
I just ordered my hardware from T3, Thanks Chris for getting me all lined out on what I need...
Got my lugs and drill bit from Chris too, nice to deal with. Hurry and get these bad boys on!
btw what did you plan on doing with the center caps? I ordered T3 aluminum ones but decided to go a different direction.. They'll be on the classifieds if you're interested |
pbrown Samba Member
Joined: July 15, 2008 Posts: 443 Location: Seattle, WA
Posted: Wed Sep 17, 2014 6:19 pm Post subject: |
I also found my set of CLK wheels. I have all five and will be mounting some BFG 215-70-16 tires for a Syncro build. I was tempted to spring for 225-75-16 but decided to be a bit more conservative this time. I hope I don't regret that.
Wheel lugs and locks ordered from Chris yesterday.
--Patrick |
imdbui Samba Member
Posted: Wed Sep 17, 2014 6:23 pm Post subject: |
pbrown wrote: |
--Patrick |
I went with 215/65/16 on my syncro, I think its a good balance, 215/70/16 would look a bit beefier, but with a stock 2.1, I decided to be more conservative. |
westyzimsgym Samba Member
Joined: October 16, 2013 Posts: 9 Location: Iowa/minnesota
Posted: Mon Sep 22, 2014 9:14 pm Post subject: |
Found some wheels on CL and was wondering if anyone has seen or used these on their vanagon/westy. I have an 81' westy. Size of wheels are
15"x7", ET37 offset, 5x112 bolt pattern. Any help would be appreciated. Thanks all
geodude Samba Member
Posted: Mon Sep 22, 2014 9:27 pm Post subject: |
Yes and go to the ultimate wheel thread for all the info. _________________ 1988 GL Camper
1991 Multivan — the basket case |
DeadSetMonkey Samba Member
Joined: April 15, 2010 Posts: 532 Location: Denver, CO
Posted: Tue Sep 30, 2014 8:21 pm Post subject: |
Anyone able to confirm these caps? Are they indeed Toureg center caps? _________________ ----------------------------------------------------
'90 Syncro Westy 2.5Subi Turbo, BFGs 215/75/15 Rheins |
Posted: Thu Oct 02, 2014 9:23 pm Post subject: Ebay wheels |
Yeah I was bidding on those houstonphotog, until the price went stratospheric.
Why pay that much for used rims when you can buy the repainted ones for a couple hundred more?
I'm feeling like going with steel passat rims right now |
Posted: Fri Oct 03, 2014 5:53 am Post subject: Re: Ebay wheels |
babywindow wrote: |
Why pay that much for used rims when you can buy the repainted ones for a couple hundred more? |
Only thing with the re manufactured ones is that their structural integrity may be compromised.. meaning they were bent at one point and had to be reshaped. I'd assume they would be prone to bend again but i'm not certain.
Maybe someone that has purchased re manufactured clk wheels before can say how their experience so far has been. _________________ Abel Longoria
Jon_slider Samba Member
Posted: Fri Oct 03, 2014 11:47 am Post subject: |
pbrown wrote: |
will be mounting some BFG 215-70-16 tires for a Syncro build. I was tempted to spring for 225-75-16 but decided to be a bit more conservative this time. I hope I don't regret that. |
you did good
225x75x16 wont work without modifications to rear trailing arm. And a stock motor wont have the power to turn them, as they are 16% taller than stock. That seriously raises your granny gear crawling speed too. All bad things, unless you modify your transmission and front differential to use different Ring And Pinions. You dodged a Bullet.
215x70x16 will already hit you with a 10% power penalty, and you will probably be wishing for a stronger motor, even with that size.
Keep in mind that a Syncro requires the spare tire to match, and be included in the rotation pattern. Therefore, you need a total of 5 CLK wheels, and 5 Tires. You will also need a solution to carry your spare tire, as it will not fit in the stock location. I recommend the RMW Rear mounted tire carrier.
This is not my listing, I just came across it. |
listing has one sentence that I want to highlight:
"These are light, and do not require adapters with a vanagon, or a Syncro vanagon. "
imo, though CLK rims do not require adapters, they do REQUIRE different Lug Nuts! Do NOT use the VW lug nuts with CLK wheels. Contact T3technique.com for correct lug nuts.
CLKs also require a spacer IF you want to use a CLK centercap.
If you want a VW centercap, contact T3technique.com _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
WLD*WSTY Samba Member
Joined: November 04, 2009 Posts: 438 Location: Arizona
Posted: Fri Oct 03, 2014 9:04 pm Post subject: |
Jon_slider wrote: |
imo, though CLK rims do not require adapters, they do REQUIRE different Lug Nuts! Do NOT use the VW lug nuts with CLK wheels. Contact T3technique.com for correct lug nuts. |
They also require drilling the lug holes out to take the 14mm Vanagon lugs. _________________ '82 SyncroWesty, the first ever conversion.'06 Subaru 2.5L |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sat Oct 04, 2014 3:08 am Post subject: |
They also DO require a spacer for the front on 2wd, unless you have managed to find a really skinny tire, like 195/75. |
Chuey Samba Member
Joined: October 18, 2010 Posts: 858 Location: Oceanside, California
Posted: Sat Oct 04, 2014 10:04 pm Post subject: |
levi wrote: |
Sometimes, they require spacers. Sometimes, they do not. Mine did not. But I added 10mm spacers from T3 to the rear. Also, I got my lug nuts and drill bit from Chris. He's tops!
Chuey |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Mon Oct 06, 2014 9:13 am Post subject: |
What is the minimum spacer thickness required to to fit the CLK center caps on the rear?
With this spacer, are the stock studs long enough? |
