Transmission Ground Strap
kaferdude
kaferdude is offline
PostPosted: Wed Apr 28, 2010 8:09 pm    Post subject: Transmission Ground Strap Reply with quote
I'm trying to get my pan completed before I put the body back on ('57 oval). Unfortunately, its been several years since I took everything apart and I can't remember how/where the transmission ground strap goes on. Before I start loosening up too many transmission bolts, is it like pic1 or pic2 on the right side of the transmission or some other configuration? Anyone have any pics of what it should look like?
And just out of curiousity, what is the purpose of this strap? What's being 'grounded'?
pic 1
pic 2
Thanks for the help.
Dan
RareAir
RareAir is offline
PostPosted: Wed Apr 28, 2010 10:17 pm    Post subject: Reply with quote
Like in pic #1, but on the Left side of the trans
1947 Typ 11a
1954 Typ 117
1955 356A
1956 Typ 151
1959 Typ 117
1966 Typ 151
1966 Typ 241
RareAir
RareAir is offline
PostPosted: Wed Apr 28, 2010 10:18 pm    Post subject: Reply with quote
i believe it's to ground the engine
1947 Typ 11a
1954 Typ 117
1955 356A
1956 Typ 151
1959 Typ 117
1966 Typ 151
1966 Typ 241
Der Bugmeister
Der Bugmeister is offline
PostPosted: Thu Apr 29, 2010 12:40 am    Post subject: Reply with quote
Grounds the engine/transmission to the chassis. Without it, your accelerator and clutch cables act as the ground which leads to premature cable failure at the leaded ends.
Type 1: 1957, 1961, 1971, 1979
Scirroco: 1976 (For Sale!)
Schwing
Schwing is offline
PostPosted: Thu Apr 29, 2010 7:53 am    Post subject: Reply with quote
Mine is at the nose. Its a 57 as well.
Is that ok?
SixVolt
SixVolt is offline
PostPosted: Thu Apr 29, 2010 4:33 pm    Post subject: Reply with quote
Is that ok?
Just a suggestion. I would take that strap off and clean it up real good and clean the studs and bolts as well. A dirty ground strap once caused me some head scratching gremlins.
It's me, Sean
1957 Oval (36 horse 6 volt)
1978 Transporter (6 volts too many)
Schwing
Schwing is offline
PostPosted: Thu Apr 29, 2010 5:13 pm    Post subject: Reply with quote
Good suggestion. I'll add it to the list I couldn't agree more.
kaferdude
PostPosted: Thu Apr 29, 2010 7:10 pm    Post subject: Reply with quote
Okay, Rareair, you say that the strap should be like pic1 but on the driver's side. But Schwing's picture appears to have the strap on the passenger side of the transmission but looped around and connected to the other rear-facing bolt/nut. I just tried doing as in Schwing's picture but it sure looks like my ground strap is too long (see pic). Schwing, has your strap ever been removed?
I guess this configuration will serve its purpose. Any thoughts?
Volumex
Volumex is offline
PostPosted: Thu Apr 29, 2010 7:34 pm    Post subject: Reply with quote
I'd suggest not having a loop hanging down in the direction of travel - just in case these is a stick or something poking up enough to get caught in it.
Schwing
Schwing is offline
PostPosted: Fri Apr 30, 2010 3:30 am    Post subject: Reply with quote
To my knowledge the transmission or strap has never been removed. My bug sat since the 80s with 149K original miles so its not likely anyone ever removed the transmission.
I just checked the "Volkswagen Owners Handbook by Floyd Clymer" (published in 1957) and there's a pic with the transmission ground strap at the nose of the transmission (where mine is) only its mounted to one of the nuts much higher on the transmission.
I can't speak for this book's accuracy but its at least another pic. Here it is:
Suboval
Suboval is offline
PostPosted: Fri Apr 30, 2010 6:45 am    Post subject: Reply with quote
Here's mine on my 57 Hoizon Blue Oval with only 28,000 miles on it.
It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history.
Russ
Russ is offline
PostPosted: Fri Apr 30, 2010 6:53 am    Post subject: Reply with quote
the after market straps you buy are definitely longer,maybe twist it a couple of times to take up the slack
Cruiser pedals for sale (see my ad's)
55 hardtop finally finished
65 beetle done:)
Schwing
Schwing is offline
PostPosted: Fri Apr 30, 2010 7:24 am    Post subject: Reply with quote
Or just loop the slack around the top.
It looks like VW did this a lot of different ways. I wonder if it came down to what technician was installing it. I agree with Russ, give it a few twists to take up slack then run any slack UP instead of DOWN.
OR people can start crawlin under their dubs and snappin some shots here Cool
By the way kafer your chassis looks real clean! I need to get busy.
