My 58 Beetle Project (lots of pics)
Goto page Previous  1, 2, 3, 4, 5  Next
67sunbeam
67sunbeam is offline
PostPosted: Sun Aug 22, 2010 6:09 am    Post subject: Reply with quote
Very nice build.
1974 Westy
1967 Sunbeam Alpine
A-Wall
A-Wall is offline
PostPosted: Sun Aug 22, 2010 10:28 am    Post subject: Reply with quote
thanks everyone!
paulsvwbug wrote:
I'm really liking your car, looks hella good. I also put on all the factory engine tin, but was wondering where do the small ones go, the ones on the left in the picture of all the tin (I think), I have my sleds and deflector tin on but not the others, do you have a picture?
I don't have any pics of those tins installed, but they go on the back side of the cylinder jugs and force air down.
LTL4 wrote:
Are you running dual carbs with single port headers?
If by headers you mean heads then yes, they are steel single port manifolds for the dual kads.
Amigo-2k
Amigo-2k is offline
PostPosted: Fri Aug 27, 2010 7:24 am    Post subject: Reply with quote
Your GPS says you were going 92 MPH?
1958 Rag Top
http://ryanendres.com
Operations manager with a results-driven passion for process improvement
A-Wall
A-Wall is offline
PostPosted: Fri Aug 27, 2010 10:06 am    Post subject: Reply with quote
that would be scarry, the gps is in KPH.
A-Wall
A-Wall is offline
PostPosted: Tue Feb 22, 2011 12:07 pm    Post subject: Reply with quote
Haven't done much with the car over the winter other then make this vid.
I have some parts on the way to get this thing ready for spring so i'll be updating more soon.
Hansolo99
Hansolo99 is offline
PostPosted: Tue Feb 22, 2011 3:06 pm    Post subject: Reply with quote
WOW!! Love that idle sound!! Sounds like a straight hot rod, but when you gun that thing it sound sooooo on time and smooth! AWESOME!!
A-Wall
A-Wall is offline
PostPosted: Tue Apr 12, 2011 8:27 am    Post subject: Reply with quote
Here is another quick vid of me messing around with this adjustable tach adapter to try and get this old sun tach to work.
TastyTuner
TastyTuner is offline
PostPosted: Tue May 10, 2011 1:23 pm    Post subject: Reply with quote
updates, anything new. your 58 is one of my favorites. always happy to read your progress
A-Wall
A-Wall is offline
PostPosted: Tue May 10, 2011 2:24 pm    Post subject: Reply with quote
i'm glad you like it! currently, the pass side fenders are off and i'm taking the drivers side ones off too. I've got to swap the extended spring plates with stock ones and urethane bushings. after that there are just a couple small things left to do and i can put it back on the road!
TastyTuner
PostPosted: Tue May 10, 2011 3:04 pm    Post subject: Reply with quote
why are you switching out the rear spring plates?
A-Wall
A-Wall is offline
PostPosted: Tue May 10, 2011 6:12 pm    Post subject: Reply with quote
When i bought the car it was already lowered 2 clicks in the rear and they put the extended spring plates to get the toe in line again.
I wanted to put an exhaust on the car so i raised it up 1 click. Now i have like 1/4" of toe out with these spring plates in place. the back of the car steps out when i hit bumps and makes for a pretty scary ride sometimes. putting the stockers back in should either put me at zero toe or even a little bit of toe in which is fine by me.
TastyTuner
PostPosted: Tue May 10, 2011 8:52 pm    Post subject: Reply with quote
makes sense.
currently i have a 66 in pretty good shape, but i have my heart set on owning a 58 some day. they are my favorite year. id love to have both the 58 for the first year big window, and my 66 for the last year original sloping front fenders.
keep on keepin on. i look forward to more updates and pictures
HRVW
HRVW is offline
PostPosted: Tue May 10, 2011 9:23 pm    Post subject: Reply with quote
Smile High fives for perserverence and quality of work.
I am wondering about the Fresh Air hose with a header system.The hose is supposed to be for a heater system like the 63 bug on.
If you wish to keep the fan housing get a 1-7/8 freeze plug for the outlet.
Either that or a 62 bug fan housing that did not have the air outlet. Cleaner look considering the header system.
Just a thought being a VW mechanic of 28 yrs. Steve
A-Wall
A-Wall is offline
PostPosted: Wed May 25, 2011 1:31 am    Post subject: Reply with quote
Apart...
A-Wall
A-Wall is offline
PostPosted: Tue May 31, 2011 2:32 pm    Post subject: Reply with quote
Just working on the details.
cleaned up and re-painted the radio bezel. this radio is not the correct one for the bezel so i had to adapt it with some strips of aluminum and some custom nuts. I also gutted the radio and pretty much cut it in half but made it look original by moving the back forward and wiring up the light again. the tuning knob still works also.
Aluminum strips
Installed
A PO had cut a hole in the dash so i wanted to cover it with something different. So i made this plate for the fuel reserve, i copied the style from a barndoor bus i saw in a magazine. Took me awhile to get it done but i think it turned out pretty cool.
Every thing finished and dash polished
vwbyoy88
vwbyoy88 is offline
PostPosted: Wed Jun 01, 2011 7:45 pm    Post subject: Reply with quote
WOW!!!!
Jimmy F
67 Sunroof Notch Project
63Ragtop NZ
63Ragtop NZ is offline
PostPosted: Thu Jun 02, 2011 1:55 pm    Post subject: Reply with quote
nice man, this things in good hands.
I really like where you put the tacho also, very cool.
If you can't join them, beat them!
A-Wall
A-Wall is offline
PostPosted: Thu Jun 02, 2011 2:26 pm    Post subject: Reply with quote
thanks guys! still have to wire the tach up.
but i got some some fun stuff yesterday at Summit Racing in Ohio.
Electric Oil temp with the sender and mechanical Oil Pressure. They kinda match the tach. I'm going to make some custom gauge cups and mount them under the dash.
Hopefully tomorrow my order from Cip1 will come in. After that I have no excuses but to GET IT DONE.
A-Wall
A-Wall is offline
PostPosted: Sat Jun 04, 2011 11:40 pm    Post subject: Reply with quote
Parts arrived! It's like Christmas. Fast shipping with Cip1!
Not all is from Cip1 for the record.
I really really have no excuses now...
A-Wall
A-Wall is offline
PostPosted: Tue Jun 07, 2011 10:48 pm    Post subject: Reply with quote
more small details.
the Stewart Warner gauges I got were from the same series but one bezel was polished and the other was satin. Summit went through their whole stock to see if they could match up 2 of the same but they couldn't. I bought them anyway figuring i could polish the dull one or dull the polished one. I tried the polishing first and am glad i did.
here is it compared to a vintage gauge that has the dull ring
this is the other polished gauge
i also installed the Pertronix Igniter module in the distributor and the new Bosch blue coil. I left the distributor set at where it was left with the points and it fired right up. checked the timing and it was at 30 degrees BTC. got it back down to 7.5 and it idles so much smoother. Seemed like i had a slight miss at idle before.
i changed the oil and put in the EMPI magnetic oil drain plug but reused the old gasket, i don't trust the new mushy rubber one.
next i machined the weld bungs i got for my oil breather setup. i turned them down some one would be a slight press fit into the air filter tube and the other would be a slight press into the actual oil breather. that way if i want, i can return it back to original (ya right) the magic numbers are .695" and .419".
the right one machined
left one machined
installed
that's all for now
next on the menu is gauges, spring plates and wiring.
http://www.thesamba.com/vw/forum/viewtopic.php?t=412491
Page 4 of 5
