poopdevil Samba Member
Joined: September 03, 2008 Posts: 270 Location: Seattle
Posted: Mon May 17, 2010 8:15 am Post subject: POR 15 left Air Bubbles! Why? |
WTF!
I used Por 15 on my clutch assembly while rebuilding it last night and this morning there are alot of tiny pindots on it .
Looks like air bubbles.
Anyone else have this problem?
I did shake the can to mix it. Is this why?
I didnt know you couldnt do that.
Just asking.
I am totally irritated with it.
What a bummer. |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Mon May 17, 2010 3:05 pm Post subject: Re: POR 15 left Air Bubbles! WHY??? |
poopdevil wrote: |
I didnt know you couldnt do that. |
I guess next time you'll read the directions then.
POR-15 Directions wrote: |
STIR CONTENTS THOROUGHLY before painting. Do not shake. |
http://www.por15.com/Data%20Sheets/POR15ApplicationInfo.pdf
poopdevil wrote: |
I am totally irritated with it. |
How can you be irritated with a product when the problem you have is one of your own creation because you decided not to follow the directions? Seems like the only thing you should be irritated with right now is yourself. I've used POR 15 plenty of times, never had an air bubble problem. Care to venture a guess as to why?? _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Posted: Mon May 17, 2010 3:50 pm Post subject: |
WTF is your problem man. Geez. I never said I was irritated with the product. I didn't go online first and I figured it was my doing. I just wanted to make sure that was the reason.
I was stating I was irritated at the situation. the (it ) meaning the outcome.
Go bash someone offline.
It's easy to be a jerk to people in a forum setting.
I was just asking around to confirm my own mistake. |
Posted: Mon May 17, 2010 3:52 pm Post subject: |
By the way, does anyone know if the Por is ruined now or will it go back to normal with time? |
Chris Hollaway Samba Member
Joined: November 01, 2003 Posts: 183 Location: Southeast Ga
Posted: Mon May 17, 2010 3:56 pm Post subject: |
It will probably settle after a few days or so. Also, what you don't use in the can, put some wax paper or plastic between the lid and can. You can put it in the frig to extend the shelf life. I put the whole can in a big ziploc bag. |
Posted: Mon May 17, 2010 3:57 pm Post subject: |
Just to make you feel better, I did the samething. Just habit I guess. |
Posted: Mon May 17, 2010 3:58 pm Post subject: |
Thanks man, Nice to hear a positive response.
Was habit for me too.
I do know of the baggy thing. I learned that the hard way a can or 2 ago..
hehe |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Mon May 17, 2010 10:33 pm Post subject: |
The bubbles could be from oil or something left on the metal. _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
zeroman Samba Member
Joined: February 05, 2010 Posts: 891 Location: Cane field
Posted: Mon May 17, 2010 11:14 pm Post subject: |
Wrong WRONG WRONG
well.. most likely.
It makes bubbles if it is on with any sort of thickness at all. It captures escaping gas. It films over instantly and any gasses in the paint due to excessive thickness will get stuck and cause bubbles to form. It wants to go on in two .. VERY thin coverings and you must wait till you get that "slight finger drag" I figure that means a bit closer to dry than tacky.
You MUST put down a second coat as even the thin coat has tiny little bubble holes in it. That's why it says (on all these products) 2 coats mandatory. And those bubbly puddle spots are hell to sand.. try to avoid them. This may be exacerbated by shaking the can.. but I only ever get bubbles where it pools.
If you ever doubt it will "foam up" when thick and cause bubbles.. leave that last little bit in the can.. just like an 1/8". Leave the lid off for 2 days. It'll puff up to about 3/8" inch and be spongy when cured.
I just did the inside of all my fenders and hood. Shook the can before hand. I've used por dozens of times .. always shake it. It smoothes out beautifully when put down thin. I mean.. you can top coat the stuff if you put it on with a roller and top coat it while still tacky. I don't even trust the "tie-coat" anymore. Guy at the paint shop said even the POR rep told em.. coat while tacky to get adhesion. I put it on with a foam roller.. nice and thin.. it looks like it was sprayed with a much better gun than mine. _________________ 77 super convertible |
volksaddict Samba Member
Posted: Tue May 18, 2010 6:17 am Post subject: |
Why were you putting por 15 on your clutch assy anyway? |
Posted: Tue May 18, 2010 8:54 am Post subject: |
I put it on because it was kinda rusty and chipped so I grinded it down and decided to use it instead of just paint because it is a nice hard finish and looks great.
I used marine clean first too so it had no oil etc. Might have been too thick a coat too.
I got it all off again and will give it another go tonight. Thanks for all the feedback |
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Tue May 18, 2010 3:44 pm Post subject: |
I did it too. Shake, shake, shake. That's life. Mr Perfect needs some sensitivity training on how not to be an asshole. |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Tue May 18, 2010 4:27 pm Post subject: |
zozo wrote: |
He pointed out the obvious -- READ THE INSTRUCTIONS. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Bugshift Samba Member
Posted: Tue May 18, 2010 5:01 pm Post subject: |
I was trained by a POR 15 rep. (we use alot of the stuff at the shop) They told us two thin coats. I got little bubbles once when I was in a hurry and did one thick coat. |
zozo Samba Member
Posted: Tue May 18, 2010 6:18 pm Post subject: |
Gary wrote: |
zozo wrote: |
He pointed out the obvious -- READ THE INSTRUCTIONS. |
As my mother used to say, "It's not WHAT you say, it's HOW you say it." |
Posted: Tue May 18, 2010 6:54 pm Post subject: |
Bugshift wrote: |
yea.. and those bubbles kill the whole idea don't they. Leaves holes potentially down to substrate.
2 thin coats.. and I personally guarantee you, you will have NO bubbles.
*guarantee does not imply liability.
I was thinking of spraying the stuff, when the guy at the paint store pointed out how it has such an affinity for skin. If you spray it, not only is any you inhale (of course you're wearing a niosh mask) and any exposed skin will be coated.
So.. spraying probably ill advised for the DIY guy. _________________ 77 super convertible |
harryset Samba Member
Joined: July 14, 2005 Posts: 690 Location: Bemidji, MN
Posted: Wed May 19, 2010 7:04 pm Post subject: |
Almost agree with all of the above, coupled with the fact that you're in Seattle, painting with a product that cures faster with high humidity. No time for it to lay out as smooth. _________________ '72 Standard
Proud owner of a "Hoover Bit"
185 60's up front, Empi disc kit, 2 1/2" drop spindles, 185 65's in back, stock drums.
Sound Deadening by Secondskin |
Posted: Wed May 19, 2010 8:04 pm Post subject: |
is it a moisture cure product?
I never payed attention, but I thought it was solvent...
regardless..
Seattle is a desert.. I live in hawaii and it smoothes out just fine. _________________ 77 super convertible |
Posted: Thu May 20, 2010 7:01 am Post subject: |
Yep, directions, when read , even tell you not to sweat on it.
And there's a reason why Seattelites get the nickname "Web Foot". _________________ '72 Standard
66buggie Samba Member
Posted: Thu May 20, 2010 7:08 am Post subject: |
for cryin out loud..dont read the directions |
