My 54 european deluxe from start to finish
Page: Previous  1, 2, 3 ... 16, 17, 18 ... 21, 22, 23  Next
54bugn
54bugn is offline
PostPosted: Sat Feb 25, 2017 9:49 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Good day all, more work inside and out on the 54. Rear of the car coming together, the original Hella back up light contains a red LED bulb connecting it up as a third brake light.
And the interior coming together as well.
I also installed the passenger side running board as well.
Getting ready to pull new wires soon.
Stand by,
Mike
"Schwing wrote:
You either have to be too cheap to hire a pro or determined to do it yourself, but it helps to be both!"
54 European Sedan deluxe
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=414940
volksartist
volksartist is offline
PostPosted: Sun Feb 26, 2017 7:04 am    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Wow really coming together fast now! Nice work. I have an extra cruiser pedal if you like them, I prefer the feel.
Joey
Joey is offline
PostPosted: Sun Feb 26, 2017 7:06 am    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
It's going together quick. Looks great. Hope you won't be afraid to drive it once it's finished.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
txoval
txoval is offline
PostPosted: Sun Feb 26, 2017 8:54 am    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Mike:
Quick item, the two small rubber plugs in your rear apron are installed backwards.
If you did that on purpose I apologize, but I wanted to make sure you knew that
See below for reference:
54bugn
54bugn is offline
PostPosted: Sun Feb 26, 2017 9:41 am    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Thanks Volksartist, I want to try with the roller pedal will decide after how I like it. Thanks for the offer will let you know.
Joey, thanks man, the paint job is a 10 footer, looks good from 10 feet lol. I didn't want it too perfect or I might be afraid to drive it. But I intend to drive this one.
Txoval, oops, I guess I know what I am doing this am. Thanks for pointing that out.
More work to go today.
Cheers,
Mike
txoval
txoval is offline
PostPosted: Sun Feb 26, 2017 12:09 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
I love the roller pedal compared to the late model "pedal", that's personal preference though.
Your paint job appears much better than a 10 footer! But don't worry about driving it, chips/scratches happen...they can always be fixed
54bugn
54bugn is offline
PostPosted: Sun Feb 26, 2017 12:17 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Txoval, can't wait to try out the roller pedal, I think it's going to be great. The paint is probably better than a 10 footer, but I have already scratched and touched up a few spots trying to put this together, and it hasn't bothered me as much as I thought it would, its all history on this car😎.
Looking forward to driving it as much as I can.
Fixed the rubber plugs btw, already.
Thanks,
Mike
Joey
Joey is offline
PostPosted: Sun Feb 26, 2017 4:06 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
I like the roller pedal compared to the later pedal as well. so much I put a roller pedal on my '65 Beetle.
Joey
txoval
txoval is offline
PostPosted: Sun Feb 26, 2017 6:16 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
First day I got mine home from paint, I was installing the dang bumper bracket seals/grommets and scratched the paint. Learned to use painters tape after that. The door seals/scrapers/vent wings were the biggest pain...lots of painters tape on those.
Do the passenger door first...learn the tricks on that one and then less mistakes on the drivers door (which you see everytime you drive). Learned that one from when I built my 67
54bugn
54bugn is offline
PostPosted: Sun Feb 26, 2017 9:45 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Thanks for the tips on the doors txoval, I have been told that it is the hardest parts to get together without causing damage. I have a whole roll of painters tape ready to go.
So more production today, steering wheel is now in:
Area under the fuel tank getting more finished:
And now getting ready for the serious stuff, wiring:
Spent a lot of time cleaning contacts and soldering connections, wish me luck.⚡️
Cheers,
Mike
54bugn
54bugn is offline
PostPosted: Thu Mar 02, 2017 9:37 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Hello all, well from the battery forward is wired. I have spent a lot of time ringing out wires and check grounds while I compare the instructions that came with the wiring harness, the 54 European wiring diagram, and my changes required for the 12 volt upgrade. No voltage has been applied yet, but I am hopeful I have done everything correctly.
All electrical components are now installed except for the dome light including these babies:
This weekend will be finishing the wiring and introducing power to the systems. Wish me luck. Rolling Eyes
Mike
Zwitterkafer
Zwitterkafer is offline
PostPosted: Fri Mar 03, 2017 11:07 am    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Coming together nicely! Where did you source that rubber/fabric steering coupler?
- Zeuxius, 400 BC
54bugn
54bugn is offline
PostPosted: Fri Mar 03, 2017 10:55 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Hello Zwitterkafer, thanks for the comment. I think I got it from CIP, the best one, but it was quite a few years ago, not sure if they carry the same one now.
Mike
54bugn
54bugn is offline
PostPosted: Sat Mar 04, 2017 8:46 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Ok folks, wiring all done, with fingers crossed I turned the ignition key and the following video was the result.
I had a few issues, had to change my brake switch on the master cylinder, it wasn't working. So the following video was after that.
I however now have to bleed the brakes again after changing the switch. I also had to fix the left hand semaphore contact that turns on the turn signal light on the speedo, it works now as well.
Last item to get working is the original wiper motor. Currently just buzzes when I turn it on. But if I move it off the park position it returns to the park on its own. So didn't have engine running, just on battery, so will get this thing running and try again. Maybe just low voltage.
More testing tomorrow, and get this running again.
Cheers,
Mike
54bugn
54bugn is offline
PostPosted: Mon Mar 06, 2017 5:06 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Hello again, well here is the first engine run and full electrical check on the 54 after body installation and new wiring harness install.
More work to do but all in all a satisfying day! Very Happy Cool
Cheers,
Mike
txoval
txoval is offline
PostPosted: Mon Mar 06, 2017 7:34 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Coming along great. Another small detail, the parking brake boot should go on first and then the tunnel carpet. I'll try to get you a picture. It's minor and may not matter to you.
Praying the doors go just as good as the rest. They were the very last thing I did
54bugn
54bugn is offline
PostPosted: Tue Mar 07, 2017 10:13 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Thanks for the pointers txoval, I do appreciate the detail corrections. I have since fixed the brake boot.
I seem to be leaving the doors till last as well, everyone's got me all worried now, lol Rolling Eyes
Stay tuned for more.
Mike
wurd
wurd is offline
PostPosted: Wed Mar 08, 2017 1:40 am    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Hi Mike,
It looks like you will enjoy very soon riding on the roads.
Thanks for making us dream with such a quality restoration.
Best regards from France Smile
Wurd
54bugn
54bugn is offline
PostPosted: Sat Mar 11, 2017 8:37 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Hello Wurd, thanks for the comments, looking forward to cruising in Schultz very soon.
So here is the latest updates of pieces added. See if you can see what has gone on:
So if you can see the windshield in, I want to ensure I point out that this windshield that my friend Dave, my wife Naomi and I installed very carefully, is THE original windshield that this car was built with!
A few scratches and marks on it but gives some history. Cool
And got the first of two of these temporarily installed, has to come back out for the headliner.
Mike
54bugn
54bugn is offline
PostPosted: Sat Mar 11, 2017 8:45 pm    Post subject: Re: My 54 european deluxe from start to finish Reply with quote
Also started working on getting ready for seat covers etc.
Installed the original seat bottom still with original remaining cover on it to make sure everything fits.
I then placed the seat back in and realized that it isn't the correct one Embarassed Rolling Eyes Evil or Very Mad .
I guess I never checked when I bought the car and it's been wrapped up ever since just unwrapped it yesterday.
So if anyone has, or knows of a 54 rear seat back and mounts available please let me know.
Thanks,
Mike
Page 17 of 23
