GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Sat Feb 25, 2012 6:56 am Post subject: |
mondshine wrote: |
and from underneath:
Where did you get that drain valve? |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Sat Feb 25, 2012 3:46 pm Post subject: |
I purchased the Kepner check valve at a local hydraulic supply.
Since then, I have made some small changes to the oil system plumbing in my daily driven Beetle. From under the engine, it now looks like this:
The oil pump output is through the steel tube and 90* elbow, and into a Moroso 23875 check valve ( http://www.jegs.com/i/Moroso/710/23875/10002/-1 ) which is more compact, has a lower crack pressure, and is cheaper than the Kepner valve. You can see it mounted vertically, just below the bulkhead fitting which is the oil filter inlet. Definitely go with the Moroso unit.
The other fitting visible is the oil return to the engine.
From the top, it now looks like this:
Inlet to the filter is through the bottom, and outlet is somewhat visible at the left side of the filter.
The two flexible hoses lead to an oil thermostat mounted to the firewall with bulkhead fittings. There's a Setrab oil cooler mounted near the transaxle, like this:
All of this stuff is on my Beetle, not the Thing. The Beetle uses the shorter CM filter which fits nicely next to the distributor; the Thing uses the tall CM filter (photo is shown earlier in this post).
The Thing engine compartment is very roomy by comparison, making access much easier. The oil setup on my Thing is at least ten years older, but both have worked very well for me. The filter location on the Thing (at the aux air filter bracket) is great; easy to reach, yet out of the way.
Hope that helps, Mondshine |
VWfanboy28 Samba Member
Joined: July 16, 2015 Posts: 9 Location: Wausau, Wisconsin
Posted: Thu Jul 16, 2015 11:42 pm Post subject: where? |
Where can i get this. I am doing an engine swap project in my 1994 Toyota Pickup. Putting a 1.9L ALH Tdi into my truck... Would like to put this in when I do the swap. Would be great to mount somewhere out of the way and easy to get to. |
imtb Samba Member
Posted: Fri Jul 17, 2015 5:45 am Post subject: |
Here is pic of mine and I am going to replace man fitler with K&N on first oil change very soon.
Oil filter gets very hot.
Posted: Fri Jul 17, 2015 6:25 am Post subject: |
VWfanboy28-
As far as i know, the TDI uses a cartridge type filter in stock form, and it is easy to service. (both of our daily drivers are TDI's but I never do any work on them myself)
If you really think you need a remote filter & cooler, check this link:
http://forums.vwvortex.com/showthread.php?4251807
Good luck, Mondshine |
Posted: Fri Jul 17, 2015 5:32 pm Post subject: |
wait it might also be the ahu i might use too.. the ahu actually has a spin on filter....
but otherwise alh or ahu are my two options for motor |
