notchboy Samba Member
Joined: April 27, 2002 Posts: 22449 Location: Escondido CA
Posted: Tue Mar 17, 2015 3:30 pm Post subject: |
Now that the peeling paint has been sorted. Back to assembly. I dropped some coin on the first wave of new bits. Lots of rubber and plastic bits. I did however get the JK sliding window for the right rear. Ill take that window and put it on the left rear - no vent window and no real need for a slider window when the cabinet takes the majority of the window. Maybe later Ill put in a rear pop out
For now I dressed up the pedestals with their new rubber. Put the passenger seat in and fit the front carpet for a look. I also laid some deadener on the pedestals and inside the passenger door.
Ill either do the doors and dash next or the cabin floor and cabinets.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
white74westy Samba Member
Posted: Tue Mar 17, 2015 4:24 pm Post subject: |
Looking good Chiba!!!
What is your take on the carpet? I'll be in a similar position to yours, once mine is back from paint. The thought of putting the old carpet back in is a little bothersome. Is there that much of a noticeable difference? Look forward to your take on things, now that its installed.
She really does look beautiful. Can't wait to see her completely done! |
Tcash Samba Member
Posted: Tue Mar 17, 2015 5:18 pm Post subject: |
Looks great.
What is this in the red circle. I don't remember seeing it before?
Keep at it.
Tcash |
Posted: Tue Mar 17, 2015 7:41 pm Post subject: |
That is the power that goes back to the fridge. It didn't sit right under the mat or the rubber so I decided to reveal it.
The carpet is no where near the correct color or spec. But when I walk 100 people by it 98 of them will think its amazing, one will be questioning it and thats because the last one of you in the know told him it wasn't correct.
Im good with 98%.
I did a capet compare awhile back.
Thats stock - no fade og on top. The new stuff on the bottom.
t3kg wrote: |
1964 1500 S
eche_bus Samba Member
Posted: Tue Mar 17, 2015 8:25 pm Post subject: |
Exciting to see the interior begin to take shape. So nice and clean looking! |
Tcash Samba Member
Posted: Tue Mar 17, 2015 9:43 pm Post subject: |
If you wanted to you could take the carpet to an upholstery shop and have them sew binding around where you had to cut for the wire. This would stop it from unraveling.
Good Luck
Tcash |
Posted: Sun Mar 29, 2015 8:11 pm Post subject: |
So I went to start putting the floor in today - get the layers up to the carpet. Throw some dynamatt down and what not. Then I found the rubber for the slider and was side tracked.
So I pulled the slider off, popped in the new rubber - sure is nice, pulled and cleaned most the slider hardware, put it all back together.
Sure is nice and snug.
In the same box I found the og door step grips. So I got the heat gun out, got them all gummy - sprayed the back with a bit of 3M - boom nice side step grips that stay in place.
t3kg wrote: |
1964 1500 S
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Mon Mar 30, 2015 7:54 am Post subject: |
Nice!
What are you doing for side windows? Back to Jalousies? Keeping the "smokers window"? _________________ 1976 Westy
1966 Beetle |
Posted: Mon Mar 30, 2015 8:26 am Post subject: |
The two middles will be rebuilt Jalousie with those accessory edge protection things on them.
The pass rear is a JK slider and the driver rear is going to be the solid one from the pass side. No vent-wing window Im not trying to have a leak.
Maybe later Ill put in a rear safari. _________________
t3kg wrote: |
1964 1500 S
Posted: Thu Apr 09, 2015 8:37 pm Post subject: |
Got some more doo dads cleaned up - namely the headlight stuff. This being a 74 has the plastic type headlight trims. The term plastic is often used as a derogatory remark, one most likely passed to us from our grandparents to our parents then onto us. A throwback to a time when cheap goods from Asian markets flooded the US market for the first time in mass. If it was plastic, it was cheap and not made to last long. Crap, not of US origin and not made to last from metal or the like.
And as most of us know growing up in an era of Plastic - not all carp is the same. We have different levels of crap. Some as in real crappy, others are just plain crap.
Germany is known for making good stuff. So Id assume that in the 70's when presented with the idea of making metal parts from plastic there had to of been a ruffled boars brush or two on ones Oktoberfest hat. But being Germans I can see them saying - if we are going to make crap, it better be the best crap out there.
With that idea in mind I present you my headlight trim rings. I have no doubt that these are the originals. These were installed by Karl at the Hanover factory some 40 odd years ago on this bus and sent on its way. I can only guess the adventures the bus had from 74 to 89. But the tabs stop for 1989 in San Antonio Texas. There this bus sat in a field with other buses. Rain, Sun, Wind, Sun, Dirt, Rain, More Sun. Even more Sun. Then my Girlfriend Michelle and I rescued the bus in 2011 from the same spot it had sat for all those years. When I stripped the bus, these parts were taken off, glanced at for condition and placed in a box where they have sat for the last couple of years. The only life lived other than being on the bus was when I put a battery in the bus and found the bulbs to work.
Now with assembly of the beautifully worked body brought back to better than 1974 conditions these parts are taken out cleaned and inspected for condition.
This is where the crap thing comes in. It seems today everyone wants to use a paste or a tube of goo to smear on your bright work. I remember when Mothers Mag came out. I could of swore some dudes would spread that stuff on toast they loved it so much. Granted a paste with fine polishers in it, like toothpaste can clean well and leave a protective film on the polished. Ill probably put a coat on these as well
But Im kinda old school. I always have bags of steel wool on hand. This fine steel once rubbed on any polished or chrome surface brightens up any day. This plastic crap rings are good example of what a fine piece of wool can do.
Look now as the the original finish comes back to showroom condition. Not bad for rings made on the cheap, by anal perfectionists and cleaned with a technique most 20 somethings would know to try.
Kilroy was here.
After on the left - Before on the right.
t3kg wrote: |
1964 1500 S
Lynn Gleason Samba Member
Joined: August 17, 2011 Posts: 109 Location: Port Townsend, WA
Posted: Thu Apr 09, 2015 9:28 pm Post subject: |
Hey Jason,
In the 1st photo, that wasn`t steel wool you were using---that looked suspiciously like Never Dull!
outed,
Lynn
BTW, to all of you out there, Flitz to bring back the shine, and Never Dull to maintain it---try it! |
Posted: Mon Apr 13, 2015 9:04 am Post subject: |
Got the OE headlights cleaned, restored and placed back on the 74 Westfalia. She can now see!
t3kg wrote: |
1964 1500 S
Rumdum Samba Member
Posted: Mon Apr 13, 2015 3:16 pm Post subject: |
Looks great! Where did you get the VW emblem? I ordered one from Busdepot and its at best Ivory in color and cheapest looking thing I've ordered to date. Looking for a "white" one. _________________ 1975 Westfalia Campmobile
CB Performance Dual IDF Weber 40
- jetted and optimized by Aircooled.net |
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1559 Location: orlando
Posted: Mon Apr 13, 2015 5:36 pm Post subject: |
notchboy wrote: |
Im good with 98%.
i saved a sample so i can dye my carpet to the right shade however it is sunfaded _________________ 75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus |
Posted: Mon Apr 13, 2015 6:20 pm Post subject: |
Rumdum wrote: |
Looks great! Where did you get the VW emblem? I ordered one from Busdepot and its at best Ivory in color and cheapest looking thing I've ordered to date. Looking for a "white" one. |
Im not sure. It was bought awhile ago. Im pretty sure the one on my panel is from BusDepot. I thought it did the job well?
t3kg wrote: |
1964 1500 S
Rumdum Samba Member
Posted: Tue Apr 14, 2015 6:13 am Post subject: |
notchboy wrote: |
Both of yours look "white". Maybe it's a production flaw that I was sent. My bus is pastel white so its imperative to me that the emblem be actually "white" and not ivory (almost yellowish). Wish I had taken a pic. Thanks for the comparison pics. I'll send it back for sure. _________________ 1975 Westfalia Campmobile
Posted: Thu Apr 16, 2015 6:35 pm Post subject: |
So two things. In regards to the above plastic VW emblem on the panel. Thats out of the box new put on over a year ago now. Here is a - this bus is outside all the time present shot of it. Its still looking good to me but has yellowed.
And as posted in the BN4 thread I have going - I needed the return air piece in a recent ad. Ive since bought it and got it. I removed the part the snorkel goes into and will be cutting and placin on the 74 soon. This was the last piece I was missing to have a 100% complete factory correct BN4 eberspacher gas heater set up
t3kg wrote: |
1964 1500 S
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Fri Apr 17, 2015 6:51 am Post subject: |
Are those the special over-riders with headlamp squirters?
I've never found myself jealous of another man's squirter before. LOL
You sir, are indeed what Kirk would call a 'trinket pimp'.
did you ever get to use the slider door track floor trim I sent ya?
Buses look fantastic man. _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
Rumdum Samba Member
Posted: Fri Apr 17, 2015 7:24 am Post subject: |
notchboy wrote: |
So two things. In regards to the above plastic VW emblem on the panel. Thats out of the box new put on over a year ago now. Here is a - this bus is outside all the time present shot of it. Its still looking good to me but has yellowed. |
Thanks for the pic! I can see the yellowing. The emblem I ordered is even more yellow than that. Very cheaply made too. Sent it back today. Went ahead and ordered the chrome one since I have that goofy raised circle on the front due to my nose being Brazilian made. I must have something there.
Awesome work on the heater and the bus overall. Threads like these keep me motivated! So, thanks!! _________________ 1975 Westfalia Campmobile
Posted: Fri Apr 17, 2015 10:50 am Post subject: |
Yes sir it is a headlight squirter. Im fully tickled that I have all the stuff to make it run. Just got to get around to installing it. Hoody hooked me up with a second set that completed my first set not to long ago. Now I have a working main pump and OE wiring harness.
I cant wait to post a you tube vid for this - Bay Window Bus Headlight squirters!
Oh and I did get the threshold trim. I ended up having to use something different on my 77. I may use it on the 74.
Rumdum - right on brother - thanks for the kind words. Did you offload that B2 yet? I have one on the back burner here at home I plan to restore so I can display in my office
t3kg wrote: |
1964 1500 S
