djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32598 Location: Reading Pennsylvania
Posted: Tue Mar 31, 2015 6:48 am Post subject: |
HENDO wrote: |
PDXWesty wrote: |
Volts x amps = watts
120 x 8 = 960 watts
12 x 80 = 960 watts
8 amps at 120 volts is 80 amps at 12 volts
Your AC unit is drawing 80 amps continuous off your battery. The 90 amp alternator won't keep up with that draw and the battery will drain quickly. Your system will only work on shore power.
14.5 volts is fine. It's the amp draw that's too high. Fuses melt from high amps not high volts. |
Well crap. I already had a window unit setup for camping and I have a super quiet champion 3100 generator inverter for power.
So there IS NO solution to driving with this a/c blowing? Adding another aux battery or a higher output alternator maybe??? Anything? |
There sure is!
You could set it up a whole lot nicer than this guy did though!
It is not out of the realm of possibility.
Ghia
Vanagon
Beetle
danfromsyr Samba Member
Posted: Tue Mar 31, 2015 6:52 am Post subject: |
law of diminishing returns
you are using more than you are making.
look at the wire you have from Battery to Inverter, it should be fat
look at wire from Alternator to batter it's much smaller
and your alternator is doing duty to 1st provide power to your engine and such.
sorry to say this was never going to work from the start..
while it's not rocket science
it is electrical engineering.
to run the AC unit you want you'll need to have a 110v generator on the back hitch carrier to power it.
HENDO wrote: |
Well...I've got it installed. I've got a huge marine deep cycle battery with 115 AH and 5000/10000W inverter also installed.
Why isn't my alternator charging my aux battery while the engine is running???
Frustrating. |
you aren't the 1st with visions of chilly grandeur, but you are behind on the learning curve.
Abscate wrote: |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Tue Mar 31, 2015 6:57 am Post subject: |
Look at the size of the wire between your inverter and your aux battery. How big is it? It needs to carry some serious amps so it has to be big.
Now look at the wire that came with the GoWesty kit. If the alternator is to provide the power for your aux battery and A/C unit it has to transfer all the same amps through it's charging wires. How can is possibly do that without BIG wire? You would need big wire all the way from the power source to the power consumer.
You can't expect to attach a fire hose to your garden hose spigot and fight fires with it. The fire hose needs to attach to large pipes all the way to the water main. You can't just put a hose adapter on your garden spigot and step the hose up to fire hose size. The small pipes feeding the garden spigot will never carry enough water for a fire hose.
However if the A/C unit constantly needs more amps than the alternator can safely supply then increasing the wire size could slow down the battery drain but burn out the alternator after a while.
Mark
HENDO wrote: |
Well...I've got it installed. I've got a huge marine deep cycle battery with 115 AH and 5000/10000W inverter also installed. I have the components from Gowesty installed that supposedly seperates the aux and starter battery....installed. I also installed an adjustable voltage regulator on my Bosch alternator that reads 14.5V on my starting battery now while engine is running.
Ok...my.10k BTU a/c runs ok but eats up the aux battery, whether the engine is running or not, in about 20 minutes. I drove around.and.ran it tonight until the alarm on the inverter went off and it shut down. I also saw that my #7 fuse got ate up and pretty much melted. Do I maybe have the regulator cranked up too high???
Frustrating. |
Westified Samba Member
Posted: Tue Mar 31, 2015 7:01 am Post subject: |
Like TK said add a generator in a rear mounted tray or box. I have seen one here where a 2000 watt Honda fits in the box. The large RV rigs run a generator to run their roof top A/C units. Yamaha also has a dual fuel generator, gas and propane that looks nice. I don't think the 1,000 watt generator will be enough because of your start up draw. Also a generator isn't as efficient if it has to run at 100% all the time. These Honda and Yamaha generators are pretty quiet. _________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
HENDO Samba Member
Joined: November 23, 2012 Posts: 202 Location: Spring Branch, TX
Posted: Tue Mar 31, 2015 7:28 am Post subject: |
crazyvwvanman wrote: |
Mark
HENDO wrote: |
Frustrating. |
Oh all of.the wires are the size of the wires going to the main battery....the largest I could find. I even installed the upgraded alternator wiring kit Gowesty sells. _________________ 84 Westy AKA "Sludge" |
dixoncj Samba Member
Joined: June 17, 2004 Posts: 1083 Location: Charleston, SC
There is no way you're going to get a high output alternator to put out enough amps for a 120V a/c. Your better bet would be to - as suggested - put on a Honda genset on the back of your van. Or figure out a way to mount a second alternator - but even then I think you'd have major issues.
The Syncro I helped buildout for JBuffett had a Subie 3.0 with a high-output alternator and a huge bank of aux batteries and a big old inverter to run a RV AC on the roof. It was done by a really good boat guy. We still melted the alternator a couple of times before realizing that sometimes, you'd just need a bigger dang rig for all that power consumption. So we made sure the Behr in-dash a/c was running perfectly and JB only used the roofer if he was plugged in to a generator or shore power. |
HENDO Samba Member
Posted: Tue Mar 31, 2015 7:50 am Post subject: |
On the thoughts of a built in 110 AC air system......
What size electric motor would it take to spin a Sanden 508?
I know that their literature indicates 3-5 HP under load but what does that translate into on a spinning reduced pulley electric motor?
Surely not 5hp for every window unit going draws far less than that. Of course they are running a different compressor and Gas as well.
IF an electric motor size could be realistically determined, why not create a second built in AC system not unlike what Air Cooled units have run for decades! ....... Only made of modern components.
A Sanden Compressor.... Or cheap knock off or Junk Yard used......
A ceiling hung Evaporator, use a 110AC to 12v DC convertor to run the fans.....
An under vehicle Condenser with cooling fans, again using 110 converted to 12v ........
Put the compressor above the Transaxle.
I've considered picking up just such an Evaporator to hang on the Drivers cab ceiling to blow AC up front.
Abandon the rear Evaporator but now utilize it as is for the 110 system.
Not cheap!
New parts..... Probably a grand or so.....
But it would be neat and clean.
The key is IF a practical size 110AC Electric Motor can be determined.
Ghia
Vanagon
Beetle
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Posted: Tue Mar 31, 2015 7:53 am Post subject: |
HENDO wrote: |
I hate to say it but what folks are telling you is not what you want to hear. A car alternator is not designed to handle the high amp load of an A/C unit that was designed to run on 120V. When you first posted that you were installing this unit no mention was made that you intended to run it when driving, everyone else has been using shore power for their portable A/C unit. I think you are SOL. Sorry. _________________ Dave O
The Western Syncro build
HENDO Samba Member
Posted: Tue Mar 31, 2015 8:14 am Post subject: |
djkeev wrote: |
[pic]
[pic]
[pic]
Not cheap!
Dave |
Ok now here is a good idea! Thank you! I will research this.
I plan on keeping this van forever and really want a/c for the Texas summers. _________________ 84 Westy AKA "Sludge" |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17124 Location: Retired South Florida
Posted: Tue Mar 31, 2015 8:19 am Post subject: |
Hendo, You are a bit early for April Fools Day.
That said, it would be possible to add a second alternator rigged to charge at 120 volt independent of your automotive charging system. I can not speak to the sustained watts it can provide, but if you Google search how to covert an automobile alternator to 120 volt there is a lot of information out there. It is the poorman's way of building a cheap generator for a hunting cabin type situation. Good luck. _________________ ☮️ |
Posted: Tue Mar 31, 2015 8:22 am Post subject: |
You missed the whole point. All of the alternator amps have to flow through the GoWesty solenoid wiring to the aux battery or the aux battery will be quickly drained when the A/C is running from the inverter.
Also if the GoWesty aux kit is wired to the main fuse panel then all of those amps have to flow through that vehicle wiring before it gets to the GoWesty wiring.
Mark
HENDO wrote: |
Oh all of.the wires are the size of the wires going to the main battery....the largest I could find. I even installed the upgraded alternator wiring kit Gowesty sells. |
Terry Kay Banned
Posted: Tue Mar 31, 2015 8:35 am Post subject: |
<<On the thoughts of a built in 110 AC air system......
What size electric motor would it take to spin a Sanden 508? >>>
10 horse Dave--I'm still LMAO on this brain wave you came up with this morning--
Keep the cob coming--
Bwa Ha, Ha, Ha --oh my god--your outa your mind.
If you were Tesla or Tom Edison-- maybe--
Where do you come up with this goofy idea's?
You are the king of off the wall stuff.
Got your Vans AC system all dialed in already do you?
Push yourself away from the keyboard, quit dreaming, & get busy-- _________________ T.K.
HENDO Samba Member
Posted: Tue Mar 31, 2015 8:36 am Post subject: |
Mark
HENDO wrote: |
Frustrating. |
Actually I answered exactly the question you asked.
So I see I had visions of running with a/c. Looks like this set up won't do it. I'll find another way.
I appreciate those who have commented with helpful answers and optional ideas. That is what is good about this forum.
Those that enjoy commenting with condescending remarks I don't much care for. _________________ 84 Westy AKA "Sludge" |
Posted: Tue Mar 31, 2015 8:44 am Post subject: |
This is what you wrote to start with. The wiring in the Gw solenoid kit is part of the components of the aux kit you said you installed. The wire that comes with the kit is tiny for the job you tried to do.
Mark
HENDO wrote: |
..... I have the components from Gowesty installed that supposedly seperates the aux and starter battery....installed. ........ |
Terry Kay Banned
Posted: Tue Mar 31, 2015 8:49 am Post subject: |
If a few folks tried to talk some common sense to you in your trip into Never-Neverland in your attempt to create the impossible, and you deem that condescending, well hello to the real world of politically incorrect honesty.
It wouldn't have taken too much to read the amp requirements label on your AC unit & then do the same on your inverter, or gen set, without publicly making a clown outa yourself.
Your did that all on your own.
Or--you could have jumped back into the reams of already posted info here by folks who have thought the same as you do, at one time or another in the past--
Nothing condescending here, just honest info--
Now where's Dave / Marconi 10 horse electric motor powered Sanden AC compressor--
I wanna see this one fly--
More Rube sets up's by none other than Dave the NJ Mountain William--
I'm still rolling on the floor with this Eureka-- _________________ T.K. |
HENDO Samba Member
Posted: Tue Mar 31, 2015 8:55 am Post subject: |
Mark
HENDO wrote: |
and I replaced all the wire with heavier gauge wire...as I also said.
Thanks again for all your helpful inputs. _________________ 84 Westy AKA "Sludge" |
Terry Kay Banned
Posted: Tue Mar 31, 2015 9:00 am Post subject: |
I am almost 100% positive you'd have on hell of a time getting that puny relay to absorb that load--forget about the heavier wiring.
Get it outa your head--it ain't gonna fly with 12v DC supplied current. _________________ T.K. |
HENDO Samba Member
Posted: Tue Mar 31, 2015 9:05 am Post subject: |
Terry Kay wrote: |
I'm still rolling on the floor with this Eureka-- |
Such big bold words from a boy sitting behind a keyboard. _________________ 84 Westy AKA "Sludge" |
