asesapie Samba Member
Joined: March 07, 2005 Posts: 756 Location: Spokane, WA
Posted: Tue Jul 01, 2014 5:23 pm Post subject: |
Well I drove the square to Costco and it's pretty warm out. She sat for about 30-45 minutes started up and then died soon there after and smelled like gas pretty strong. She then wouldn't start again for about 30 minutes. I have videos in my post before this one showing the gas just flowing into the carb after running. The motor was pretty warm as well so is the gas boiling or is it vapor lock? I have the phenolic spacers between the manifolds and carbs but the carbs are still getting warm. I have got to get this crappy problem resolved.
Who out there can tell me how to keep this car from getting too hot and not running after driving |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Wed Jul 02, 2014 10:16 am Post subject: |
Well I have my fuel pressure set to 3psi so I would hope that's low enough for the fuel pump to not push the fuel through. I don't really want to go to an electric pump either.
I of course have aluminum intakes and the do heat up pretty quick and the carb will heat up as well. I think it may be heat soak causing the issue more than pressure. I have all of my fuel lines raised off the case too |
W1K1 Samba Member
Posted: Wed Jul 02, 2014 11:47 am Post subject: |
I had the same thing with the stock pump in the summer.
I put a gauge inline at the tee and the needle would pulse 2-6PSI for 15-20 minutes after shutdown from the heat.
I switched to an electric under the tank, and have never had the problem again.
Same for the wifes Superbeetle, we went through a couple pumps and never got it to work better so we switched to electric.
Put a gauge inline and see what it does on shutdown with a warm engine _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Wed Jul 02, 2014 7:47 pm Post subject: |
W1K1 wrote: |
Put a gauge inline and see what it does on shutdown with a warm engine |
Good catch, and good point. If the problem is only when the engine is hot, then something must be causing it.
In my case, it was the pump itself that would vapor lock (wouldn't pass fuel thru it). I went to an electric pump, and haven't had an issue since. I even run an electric pump on my dual Weber carbs, as well as both sets of Solex carbs I have here. With mechanical pumps being manufactured almost anywhere on the planet, the quality is all over the place (you never had to run a regulator with a stock pump before). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Jul 02, 2014 8:50 pm Post subject: |
Thanks guys. Do you have a suggestion for what electric pump to run and where to mount it? Are they easy to wire in? |
Posted: Wed Jul 02, 2014 9:06 pm Post subject: |
asesapie wrote: |
I've been running the Mr.Gasket brand 42S pump. It's a low pressure electric pump for Import cars. It doesn't really need a regulator, and is easy to wire in and plumb in. Ideally, you should run an "impact" switch with it (available at NAPA), so the pump shuts off in an accident. Sorry I don't have a part number for that right at the moment though.
That pump can be had at Autozone, Advanced, O'Reilly's, and several other places. It's a common on the shelf item at those places. Sells for 49.99 to 51.99 depending on where you go.
I normally mout the pump up front, under the fuel tank. The shift rod access cover is a nice place to put it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Jul 05, 2014 8:06 am Post subject: |
Well I bought the Mr.Gasket pump and was going to change that all today. Jacked the front of my square up last night so I can get out this morning and get it done. Well I found a big puddle of gas under the motor. Looks like the drivers side carb was somehow pulling fuel through and flooded the motor with gas. Don't know how this happened as it's just like parking on a hill? I'm thinking fuel pump and needle valve in that carb?
Now I drained the oil already but do I need to pull the motor or is it okay to change the oil a couple of times? |
Posted: Sat Jul 05, 2014 11:58 am Post subject: |
Anyone out there to help me with this? Should I pull the motor or not? I assume it was leaking from the front and rear main seals. |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Sat Jul 05, 2014 12:40 pm Post subject: |
Fill with fresh oil and it should be OK, but it sounds like you'll need to replace the needle and seat in that carb. I think I'd go ahead and do them both. _________________ 71 Elm Green FI A/T Squareback |
Posted: Sat Jul 05, 2014 4:54 pm Post subject: |
Yeah I was thinking that needed to be done too. I have the electric fuel pump installed but I'm getting no gas. Any ideas why it's not pumping?
I mounted it on the firewall near the same level as the bottom of the tank and wired the positive to the fourth fuse from the left as from what I understood it needed to be wired to an ignition powered fuse or the pump should only have power when the car is on. Should the pump make noise while on or not? Can I test at the pump somehow to see if it is getting 12v power? |
Posted: Sat Jul 05, 2014 5:08 pm Post subject: |
This is a 69 Square, right? If so that fuse only gets power when the headlights are on.
I would mount the pump right under the gas tank for best results. _________________ 71 Elm Green FI A/T Squareback |
Posted: Sat Jul 05, 2014 6:07 pm Post subject: |
asesapie wrote: |
4th fuse from the left is the right headlight. Try the 4th fuse from the right, as that's switched power (key on). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Jul 05, 2014 7:08 pm Post subject: |
Sorry long day in the sun working on my square. I meant I have it wired to the fuse 4th from the right. And I cant really mount it right under the gas tank as there isn't a good place to do so. I'll post a a pic of where I mounted it here soon. |
Posted: Sun Jul 06, 2014 6:26 am Post subject: |
asesapie wrote: |
Then it's time to dig out the VOM, and check the fuse locations for 12 volts when the key is on. Also re-check your ground connection, as you might not have a good ground. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Jul 06, 2014 7:03 am Post subject: |
Volt meter reads 12v power with key on. I sanded the paint down where the ground is on the firewall so that should be good. So will the fuel pump make noise when on? Thanks |
Posted: Sun Jul 06, 2014 7:28 am Post subject: |
asesapie wrote: |
It does make some noise, but for the most part it's pretty quiet. You really have to listen for it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Jul 06, 2014 1:26 pm Post subject: |
Okay I'll go give it a go here in a bit after my betters is done charging. |
Posted: Sun Jul 06, 2014 9:08 pm Post subject: |
Alright so it was a really hot day in the sun on Saturday as I totally unplugged the 4th from the right fuse wire to hook a spade connector to plug both wires in and plugged into the wrong connector and didn't realize it till today. Fuel pump is working and the square is alive again.
I think it does need new needle valves though as the gas is still leaking on the passenger side carb. So I'll be ordering rebuild kits tomorrow morning.
Thanks for the assistance again fellas |
Posted: Sat Jul 12, 2014 10:56 am Post subject: |
So the fuel pump sucks as it leaked fuel like a bandit from the filter that screws onto the pump. Went back to the mechanical pump and drive for a bit and no I've got vapor lock I'm pretty sure as it started up and ran then died off again like the last time that started this whole problem.
I don't know what I can do to cure this issue but I'm near throwing in the towel on the square as a bus and bug motor don't seem to have this problem of over heating constantly and causing the gas to boil over. My square has me goin crazy!!!!
It was hot enough in the engine bay that the hex bar was hot to the touch. I have everything in place for cooling but still it gets too hot. The outside temps were around 85*. |
