Leaking brake light switch on 1970 VW Bug master cylinder
DocErickson
DocErickson is offline
PostPosted: Tue Jun 08, 2010 6:36 pm    Post subject: Leaking brake light switch on 1970 VW Bug master cylinder Reply with quote
So, I just installed a new master cylinder (Brazilian, not German) and did all the things you are supposed to do (bench bled, adjusted brakes, remove drums to check slave cylinders...etc.) and the front brake light switch is leaking. I cranked down on it as hard as I could and it's still leaking. I tried replacing it with the old one and it still leaks. That leads me to one of two conclusions. The MC is trash or the I misadjusted the push rod and it's going down too far, but I'm pretty sure I adjusted it right. Should I replace the master cylinder again or is it the push rod adjustment that I messed up?
Thanks for your help.
dakdak
dakdak is offline
PostPosted: Tue Jun 08, 2010 6:43 pm    Post subject: Re: Leaking brake light switch on 1970 VW Bug master cylinde Reply with quote
When you say you "cranked down" as hard as you could, it is possible you may have craked the master cylinder at the threads. Check the master cylinder around the brake light switch threads for any cracking. If you're satisfied it's not cracked, you may try using the white teflon thread tape on the switch threads and see if it still leaks. This may draw some criticism, but if it works, it works.
The great enemy of the truth is very often not the lie - deliberate, contrived and dishonest, but the myth - persistent, persuasive and unrealistic.
JFK
DocErickson
PostPosted: Tue Jun 08, 2010 6:47 pm    Post subject: Reply with quote
I had it pretty snug to begin with, saw that it was leaking when my assistant was pushing on the brakes, so I gave it another quarter turn, and I'm no Hercules, so I'm pretty sure I didn't crank it too hard. I'll try the dope tape method.
69 Jim
69 Jim is offline
PostPosted: Tue Jun 08, 2010 7:44 pm    Post subject: Reply with quote
Not a good idea to trust your life on a garbage Brazil made master.
DocErickson
PostPosted: Wed Jun 09, 2010 5:17 pm    Post subject: Reply with quote
After all was said and done, I replaced the brake light switch with genuine German switches with high temp thread sealer, and it's holding up as of right now. Now I have to wait for my assistant to help me bleed my brakes.
johneliot
johneliot is offline
PostPosted: Wed Jun 09, 2010 11:30 pm    Post subject: Reply with quote
I had exactly the same problem with my 69. I decided to go cheaper with the MC (i was a Varga I believe). No amount to tightening would stop th leak. I decided to eat the $25 and buy a German one and it never leaked again. You should not have to use any type of sealer on the switches. Brake fluid eats paint in no time, I can't imagine what it would do to teflon tape.
John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost"
69 Jim
69 Jim is offline
PostPosted: Thu Jun 10, 2010 12:06 am    Post subject: Reply with quote
My switches came with brown loctite on them.
Cusser
Cusser is offline
PostPosted: Thu Jun 10, 2010 6:28 am    Post subject: Reply with quote
Agree.
Teflon (polytetrafluoroethane or PTFE) won't dissolve in brake fluid, or most anything.
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
bogrady
bogrady is offline
PostPosted: Mon Dec 13, 2010 10:30 am    Post subject: Reply with quote
Where did you purchase your part from? I am having the same problem and need to know the best/cheapest place to get it.
Thanks!
JonF
JonF is offline
PostPosted: Mon Dec 13, 2010 11:35 am    Post subject: Reply with quote
i had a prob over the summer with brake light switches also! there was a bad batch of switches made and i had to replace the switches 3 times before i got 2 good switches.
68 bug 1600sp 30/31
68 baja 1600sp 010 32ndix
View user's profile Send private message Facebook Classifieds Feedback
marcodelat
marcodelat is offline
PostPosted: Mon Dec 13, 2010 12:44 pm    Post subject: Reply with quote
DocErickson wrote:
... Now I have to wait for my assistant to help me bleed my brakes.
While you are waiting... let gravity be "your assistant"... in other words try gravity bleeding - do a search here or on the net.
velvetguru
velvetguru is offline
PostPosted: Thu Dec 16, 2010 10:12 pm    Post subject: Reply with quote
Why not just rebuild your original German made master cylinder. A kit is inexpensive and easy to install, it's just a few rubber parts and a spring. You have the advantage of keeping the car original and you don't have to deal with all these new 'just as good as the original' junk parts being made today. Just my two cents.
Joe
rtaylor
rtaylor is offline
PostPosted: Thu Jan 06, 2011 4:18 pm    Post subject: Reply with quote
if anyones still checking this post, it has been a while since it was posted, butt im having the same problem with my brake switches. ive gone through litterally 8. autozone has replaced them everything since they have a warranty. buttt im gettin tired of buying brake fluid and having to bleed my brakes. soo any idea of a better palce i can go? i just ordered some from napa.....but if they ont work i need a back up plan
