parapa Samba Member
Posted: Fri Jun 11, 2010 10:17 am Post subject: Z-Bed hinges |
Hello hello,
I'm a french guy and I've got a 78 Delux Bay and a big question?
My rear seat can have this position:
So I would like to know if it's a good idea to install Z-Bed hinges? (like
here: http://www.camperstuff.co.uk/Site/Home.html)
Do you think it's better to keep my actual system, to put a bed on, and to keep my money...?
With the z-bed hinges, is the bed confortable or not?
Thanks for your answers
Ed'
[/url] |
SGKent Samba Member
Posted: Fri Jun 11, 2010 1:36 pm Post subject: |
You tell me.
with cut foam on top
With foam covered in westy material
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Desertbusman Samba Member
Posted: Fri Jun 11, 2010 4:52 pm Post subject: |
That looks more like a play pen than a bed _________________ 71 Superbug
71 Westy |
SGKent Samba Member
Posted: Fri Jun 11, 2010 6:02 pm Post subject: |
ya know, remember that from the 1971 bus witha a similar bed to camp in. I am too old to care anymore. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Jun 11, 2010 10:20 pm Post subject: |
Get a little older and you will start caring again. _________________ 71 Superbug
71 Westy |
parapa Samba Member
Posted: Fri Jun 11, 2010 11:21 pm Post subject: |
Thanks for your quick answers!
SGKent: under your foam, you've got a z-bed system? and when your seats are in road position, where is your foam?
Ed' |
SGKent Samba Member
Posted: Fri Jun 11, 2010 11:24 pm Post subject: |
on this car left at home. On the 1971 I had like it, I made it with a fabric hinge and it folded over and sat behind the rear seat. Maybe twice in all the years I owned it the reat seat was up. Normally we never had more than 4 people in it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
parapa Samba Member
Posted: Fri Jun 11, 2010 11:29 pm Post subject: |
Thanks for infos!
Perhaps I will keep my actual system and imagine a bed in 3parts which can be deploy when my rear seat is in bed position. Like the vw caddy tramper (look at 44s)
Ed' |
parapa Samba Member
Posted: Tue Jun 15, 2010 3:21 am Post subject: |
Finally, I buy a z-bed system from camperstuff!
I hope I can preserve my middle seat when my rear seat is in bed position?
I think I will put a foam in 3 parts (80cms, 80cms, 20cms) in order to put it in the luggage compartment when the rear seat is in road position!
What do you think about my solution?
Ed' |
Djoul Samba Member
Posted: Thu Jun 17, 2010 7:07 am Post subject: |
hello
les z-hinges sont la meilleure solution dans un bus pour préserver les banquettes d'origine
mais normalement, dans un deluxe, tu es obligé de démonter la barre de protection des bagages du dossier, mais aussi les accoudoirs qui empêchent le basculement du dossier ...
effectivement, il faut aussi ajouter un matelas par dessus tout ça...
A+
met des photos de ta transformation.... _________________ "please, excuse my bad English...."
69 CLIPPER-L
74 WESTY
68 BUG
73 THING
NEVER UNDERESTIMATE A BUS! |
parapa Samba Member
Posted: Thu Jun 17, 2010 11:28 pm Post subject: |
En fait, j'ai annulé la vente car je ne savais pas que le lit ne fonctionnait pas quand la banquette centrale était présente!
Après mon deluxe n'a pas la retenue des bagages, ni d'accoudoirs! |
SGKent Samba Member
Posted: Fri Jun 18, 2010 8:06 am Post subject: |
Ed' |
middle seat can be moved forward using small brackets you will have to make or buy.
Good solution. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
