The Twin Pulley Cable System
Page: Previous  1, 2, 3 ... 21, 22, 23, 24, 25, 26  Next
tattooed_pariah
tattooed_pariah is offline
PostPosted: Fri Feb 28, 2014 10:38 am    Post subject: Reply with quote
Steve Arndt wrote:
Adjust idle speed with the idle speed screws. Not by pulling on the cable at the pedal end!
Confused
I thought the screws were now irrellevant? the old linkage arm is still in place on the passenger side carb, but it would not fit with the wheel on the driver's side, so I relocated it to the front (closest to the backseat) side on the driver's side carb..
if that's the case, I'll have to relocate the driver's side screw as well and adjust them from there..
I guess I was just under the impression that if you had the "pedal to the floor/WOT" set properly, it would position it so you would set the idle speed by adjusting that top fitting on the driver's side carb..
-pariah (just a novice from "that other VW site")
'72 Volksrod "Effigy"
"Never worry about stepping on people's toes. People who get their toes stepped on are either sitting down, or standing still on the job."
-Admiral Arleigh Burke, USN(ret.)
Steve Arndt
Steve Arndt is offline
PostPosted: Fri Feb 28, 2014 12:32 pm    Post subject: Reply with quote
https://www.youtube.com/watch?v=RVDKMCwgqEs
Notice the idle speed screws. Adjust those so your syncrometer reads the same side to side.
Then adjust the slack on the cable between the two so they rotate the same.
Finally setup your pedal for wide open throttle so it doesn't over travel.
tattooed_pariah
PostPosted: Fri Feb 28, 2014 12:49 pm    Post subject: Reply with quote
ahh gotchya.. guess I'll have to move the driver's side screw to the front and adjust those.. I must have overlooked a step or something, i've got my cables all lined up already, carbs move together, but it just doesn't idle yet..
I wonder if just adjusting the passenger idle screw will pull the driver pulley enough to help it idle too. the amount of pressure needed on the pedal is seriously the least amount of pressure i've ever put on anything, so it's not off by very much.. the pedal only needs to go down about 1/16th of an inch in order to keep it running..
Steve Arndt
PostPosted: Fri Feb 28, 2014 12:56 pm    Post subject: Reply with quote
You need a synchrometer to balance and synchronize the carbs before worrying about the cable linkage. That is done with the idle speed screws alone, just like if you had standard cross bar linkage.
tattooed_pariah
PostPosted: Fri Feb 28, 2014 1:24 pm    Post subject: Reply with quote
I've always done it by ear but i do own a snail tool.
right now i can't do anything because as soon as i get out of the car to go back to the engine it dies.. like i said in the other posts, i thought the cable tension would hold the pulleys in place advanced enough to maintain idle..
I'm confused now about what the function of the adjustable top piece is then.. I thought it was for fine tuning idle speed..
(circled in this pic)
Steve Arndt
PostPosted: Fri Feb 28, 2014 1:46 pm    Post subject: Reply with quote
It is called sync link for a reason. That cable links the two carbs together and keeps them in sync.
They must be in sync to start with though.
His video shows how to adjust the link cable to get side to side tandem movement once they are synced at idle with the idle speed screws.
slowtwitch
slowtwitch is offline
PostPosted: Fri Feb 28, 2014 1:48 pm    Post subject: Reply with quote
Steve is correct. Your idle and mixture settings are done before the linkage install. The top adjuster is to fine tune your pedal, to get wide open throttle when your pedal is to the floor.
pete
tattooed_pariah
PostPosted: Fri Feb 28, 2014 2:12 pm    Post subject: Reply with quote
gotchya, my mistake then Smile
at the very least I'm helping you root out the kind of idiotic things people will do if you don't tell them not to Wink Laughing
Dr. Frankensteen
Dr. Frankensteen is offline
PostPosted: Fri Feb 28, 2014 5:48 pm    Post subject: Reply with quote
I'm interested in this kit for my wife's '77 Bay with Dellorto 36's. Is there a website? How do I order?
Thanks!
SBD
SBD is offline
PostPosted: Fri Feb 28, 2014 8:50 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=1381017 Cool
tattooed_pariah
PostPosted: Wed Apr 09, 2014 8:59 pm    Post subject: Reply with quote
Bumping this thread back up to the top for the benefit of some SoCaler's... brought my car out to a meet tonight and everyone LOVED the linkage.. told em all to check here, so figured I'd make it easier for them to find Pete Wink
slowtwitch
PostPosted: Sun May 04, 2014 2:27 pm    Post subject: Reply with quote
Hello Folks, I just wanted to post this pic...
It's a crude prototype of the SyncLink System for engines with heat ducts. The good news is that it works Smile
I have all the parts drawn in CAD and all the code needed for the CNC. I'm going to try and have a finished setup in about a week or two.
This new system will consist of a new breather base (similar to the one above). The accelerator cable (the one on the left) will not go through the fan housing (see pic), as did the original SyncLink. There will also be a slot in the bracket to, so that the accelerator cable can be disconnected and put aside (instead of pulling the cable all the way through)..making engine removal easier.
Oh and here's another view....as you can see plenty of room from the ducts Smile
This setup is universal and will work with both Weber IDF and Delortto DRLA carbs. At least that's what my CAD program is showing me..lol.
It may even work on Type 3's with IDF/DRLA carbs Smile
Lastly, I apologize for the delays in getting something for you folks with heat, it's tough sometimes to get these old brain cells moving Smile
I also wanted thank all the people who have purchased, supported and gave me input... it means alot Smile
pete
Tom_Kathleen
Tom_Kathleen is offline
PostPosted: Sun May 04, 2014 3:09 pm    Post subject: Reply with quote
Great, Pete. That should get you quite a few more sales! Make sure you warn the customers not to drill into the oil cooler on the non doghouse shrouds! Tom
Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA
911pickup
911pickup is offline
PostPosted: Sun May 04, 2014 4:14 pm    Post subject: Reply with quote
This is GOOD news!
OLD VW NUT
OLD VW NUT is offline
PostPosted: Sun May 04, 2014 5:04 pm    Post subject: Reply with quote
Is there any reason why a guy couldn't use a hydraulic throttle setup to work with these pulleys? That way there'd be no cutting/drilling/routing through the fan shroud.
71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI
slowtwitch
PostPosted: Sat May 24, 2014 10:14 am    Post subject: Reply with quote
Hi folks, I cleaned up the prototype... Here are some pictures.
more to come....
Smile
pete
Rustforlife
Rustforlife is offline
PostPosted: Sun May 25, 2014 8:27 am    Post subject: Reply with quote
That air cleaner base is a work of art! Shocked
1956 Ragtop
keo808
keo808 is offline
PostPosted: Wed Oct 29, 2014 9:37 am    Post subject: Reply with quote
bumping up the thread...any updates? heater duct version is looking good. Very Happy
VWporscheGT3
VWporscheGT3 is offline
PostPosted: Thu Oct 30, 2014 11:49 am    Post subject: Reply with quote
other than many hydraulic fluids are highly flammable and you would want them on your engine?... no ..no reason lol.
Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
koolkarmakombi
koolkarmakombi is offline
PostPosted: Thu Oct 30, 2014 3:43 pm    Post subject: Reply with quote
Bwahaha it's a sealed system, more risk from the fuel lines coming off the fuel pump/carb than from the 10cc of hydro fluid in a sealed system Wink
Page 22 of 26
