oldgit Samba Member
Posted: Sun Nov 23, 2014 9:27 pm Post subject: |
I cant Wait!!!!!
slowtwitch wrote: |
Hi folks, I cleaned up the prototype... Here are some pictures.
more to come....
slowtwitch Samba Member
Joined: July 03, 2004 Posts: 730 Location: just north of philly
Posted: Mon Nov 24, 2014 4:59 am Post subject: |
Hi folks, First of my apologies, for the delays on this new system. I have all the mechanical aspects of the design worked out. I wrote all the code for the machines for it...The issue I have right now is cost. The setup you see in the above pics, would bring the cost of the system to about $350.00. I really don't want to go that high...
My goal is to design a product that would be in the same price range as the original SyncLink and I think I have come up with a way. It will resemble the setup in the above pics, but, would be more cost effective. I have a long weekend at home this week and I hope to have something machined by this weekend. Actually, count Thursday out, as I'll be eating some turkey and watching the Eagles-Cowboys game
hang in there _________________ pete |
terryly Samba Member
Posted: Mon Nov 24, 2014 6:54 am Post subject: |
That looks great Pete. And is about perfect timing for me. I have a set of CBs space saver manifolds and IDFs[reverses carbs so adjusting screws are towards fan shroud] Looks like it may work by taking the right carb and putting it on the left. and the left carb on the right[the one with 2 cables] and using a little longer cable to throttle pedal. Any of you eagle eye sharper type guys see a problem with this plan? The reason for doing this is because there is space issues with my engine cage and carb" hats" that will be attached to intake piping [like a turbo] and a Donaldson air filter.Trying to prevent water/mud intrusion into carbs on a off road car.
what do you guys think go/no go??
Terry |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Mon Nov 24, 2014 8:14 am Post subject: |
terryly wrote: |
Terry |
I'm pretty sure Jake Raby was able to run the originaly style sync-link on a set of reverse installed carbs. You could do the same thing on a car with heater outlets with the original style system. |
Tom_Kathleen Samba Member
Joined: August 26, 2004 Posts: 919 Location: Vernon, CT
Posted: Mon Nov 24, 2014 10:22 am Post subject: |
Pete - for the quality of those parts, I see no problem with a $350 price tag. Tom _________________ Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA |
oldgit Samba Member
Posted: Mon Nov 24, 2014 10:49 am Post subject: |
$350 is not bad at all. Hell I send ya that right now. After seeing a Sync Link on a frends rail, the cost is worth not having to fiddle with crossbar linkage anymore. I am not saying crosbar is bad just a bit more finiky to set up. |
Posted: Mon Nov 24, 2014 5:35 pm Post subject: |
Here are a couple more teaser pics The throttle bodies are from "theDubshop", very nice tb's. The crossover cable could be trimmed a bit, but, you get the idea
Here's a closeup.....
You will notice a slot at the adjuster. There are slots cut into both right and left brackets. Because the accelerator cable does not go through the shroud with this setup, this will allow engine removal without pulling the accelerator cable, as was required with the standard system.
Lastly, if you look at the bottom pic..... imagine that it's an IDF or DRLA carb. and all you had to do was put your own breather base on top of the the setup.... that is what I'm thinking of doing to bring down the price.
Naturally, I will offer also offer the billet breather base and top version _________________ pete |
c21darrel Samba Member
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Tue Nov 25, 2014 8:26 pm Post subject: |
just wonderin' why in your ad you say . . . "Lastly, this system is to be use on off road and show vehicles only." _________________ Jesucristo es mi Seņor y Salvador! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue Nov 25, 2014 8:29 pm Post subject: |
57BLITZ wrote: |
just wonderin' why in your ad you say . . . "Lastly, this system is to be use on off road and show vehicles only." |
It's a liability clause. If you get into a accident on a public road and it's linked to the linkage then he's not liable.
Most aftermarket and/or high performance parts have that statement. _________________ Glenn
Member #1009
#BlueSquare |
PASHN8 Samba Member
Joined: January 30, 2011 Posts: 152 Location: Melbourne, Australia
Posted: Mon Jan 12, 2015 6:50 pm Post subject: |
Hi Pete,
Any update on these? _________________ www.dinography.com.au - Dino!
1957 11-Window Split Bus
1954 3-fold Sunroof Oval Beetle
*** Looking for '56 Porsche T1 356A 1300 engine no. 22373 *** |
Posted: Tue Jan 13, 2015 3:47 am Post subject: |
Hello folks, I have a couple kits out there being tested by some reliable folks. I'm waiting to hear feedback....hopefully it's good _________________ pete |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Tue Jan 13, 2015 8:36 am Post subject: |
Pete sent a new system my way and I'll be installing it next week. This is a welcome thing for the vehicle that it'll be used on, that has an AC compressor that does not allow Sync link to be used in standard form without interference. For the last 3 years I used the system behind the carbs, facing the firewall. This worked, but it really sucked to install and work with.
The new mounting provisions should solve all of that. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
oldgit Samba Member
Posted: Wed Jan 14, 2015 9:11 am Post subject: |
1 step closer |
Howard 111 Samba Member
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
gdando Samba Member
Posted: Sun Apr 12, 2015 3:43 am Post subject: |
Pete,
Good morning. As I rebuild my 2110 again. I am not running a fresh air fan shroud however I would like to know if your linkage will clear the Gilmore AC compressor stand with CB EFI. Thank you
Gene _________________ "Sicilian Frankenstein, 74 T-1 w/ 2110, irs, Gilmore A/C, disk brakes, original fuchs 6" dish"
http://www.shoptalkforums.net/viewtopic.php?t=120800&highlight= |
oldgit Samba Member
Posted: Sun Apr 12, 2015 7:22 am Post subject: |
I just uncovered the engine and car for the summer and remembered this was one of the things I wanted before I put the engine in. It was at the top of the list again so I have to ask any date yet on when these might be ready? The moneys burning a hole in my pocket. LOL
Oldgit |
Bad bug Samba Member
Posted: Sun Apr 12, 2015 8:32 am Post subject: |
slowtwitch wrote: |
Hello Folks, I just wanted to post this pic...
It's a crude prototype of the SyncLink System for engines with heat ducts. The good news is that it works
I have all the parts drawn in CAD and all the code needed for the CNC. I'm going to try and have a finished setup in about a week or two.
This new system will consist of a new breather base (similar to the one above). The accelerator cable (the one on the left) will not go through the fan housing (see pic), as did the original SyncLink. There will also be a slot in the bracket to, so that the accelerator cable can be disconnected and put aside (instead of pulling the cable all the way through)..making engine removal easier.
Oh and here's another view....as you can see plenty of room from the ducts
This setup is universal and will work with both Weber IDF and Delortto DRLA carbs. At least that's what my CAD program is showing me..lol.
It may even work on Type 3's with IDF/DRLA carbs
Lastly, I apologize for the delays in getting something for you folks with heat, it's tough sometimes to get these old brain cells moving
I also wanted thank all the people who have purchased, supported and gave me input... it means alot |
Thanks a lot slowtwitch as this will help me a lot since i have both IDF and DRLA carbs and a fan shroud with heater ducks. |
oldgit Samba Member
Posted: Sat Apr 18, 2015 1:13 pm Post subject: |
Ant Idea on the availability date? Hey the old lady left me all I have left is a cat dog and my Bug. Its going to be a good summer. This is high on the needed parts list
Oldgit |
