Empi Sportster Roll Call
Page: Previous  1, 2, 3 ... 7, 8, 9 ... 31, 32, 33  Next
PG Sportster
PG Sportster is offline
PostPosted: Tue Nov 17, 2015 9:53 am    Post subject: Re: Empi Sportster Roll Call Reply with quote
I think you can still get ZXZs from Coker, but they are pricey. Older tires are always a bit of chance. I don't drive too far or too fast with this buggy so I'm not too worried.
andygere
andygere is offline
PostPosted: Tue Nov 17, 2015 4:50 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
PG Sportster wrote:
Thanks.
I believe the taillights are 1964 Impala's, due to the slope. I had a 1962 Corvair Monza and the rear end is more vertical.
Taillights are 1965 Impala, and a good choice. Nice looking buggy!
PG Sportster
PostPosted: Tue Nov 17, 2015 5:02 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Thanks for the info.
vponder
vponder is offline
PostPosted: Mon Nov 23, 2015 5:02 am    Post subject: Re: Empi Sportster Roll Call Reply with quote
PG I sent a PM
PG Sportster
PostPosted: Mon Nov 23, 2015 1:57 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Here are a couple of new photos with 1966 style wheels and hub caps for a retro look.
vponder didn't get your PM yet.
vponder
vponder is offline
PostPosted: Mon Nov 23, 2015 3:29 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
PG, I sent another one, don't know why first didn't go.
PG Sportster
PostPosted: Mon Nov 23, 2015 5:59 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
vponder
I just checked my PM inbox, still nothing.
64empi
64empi is offline
PostPosted: Tue Nov 24, 2015 12:29 am    Post subject: Re: Empi Sportster Roll Call Reply with quote
this says it all
I'm always interested with anything to do with empi sportsters
vponder
vponder is offline
PostPosted: Tue Nov 24, 2015 5:06 am    Post subject: Re: Empi Sportster Roll Call Reply with quote
PG Sportster wrote:
vponder
I answered your pm let me know if you get it ,
PG Sportster
PostPosted: Fri Dec 04, 2015 4:47 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
I finally completed the retro wheel installation on my Sportster. It handles better now with the stock wheels up front and the 30/9.50r15s in the back on 15"x 8" rims.
BL3Manx
BL3Manx is offline
PostPosted: Fri Dec 04, 2015 5:01 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
I love the rack over the Type 3 engine and the chrome windshield frame. Looks like you have something custom mounted on the tunnel ahead of the shifter
PG Sportster
PostPosted: Fri Dec 04, 2015 8:03 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Thanks.
The rack appears to be from an old sports car with an aluminum sheet beneath it as an engine cover.
The instrument panel is a steel tube with a VW speedo, ignition and switches for lights, wipers and reverse lights. I had to cut a section out of it to get my size 13 feet on the accelerator pedal, but it works fine now.
vponder
vponder is offline
PostPosted: Sat Dec 05, 2015 4:25 am    Post subject: Re: Empi Sportster Roll Call Reply with quote
Looks Good, I'd like to see a up close picture of the speedo set up, never seen one done like that. V
PG Sportster
PostPosted: Sat Dec 05, 2015 3:20 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Here are some photos of the Sportster's instrument pod. The small toggle switch is for the reverse lamps.
vponder
vponder is offline
PostPosted: Sat Dec 05, 2015 7:01 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Looks good that was pretty creative to put it there. I think I saw a pic your radio was up under the dash. Nice
PG Sportster
PostPosted: Sat Dec 05, 2015 7:05 pm    Post subject: Re: Empi Sportster Roll Call Reply with quote
Thanks.
I took the radio out since I could hear it anyway.
PG Sportster
PostPosted: Sun Dec 06, 2015 12:07 am    Post subject: Re: Empi Sportster Roll Call Reply with quote
To be clear. I removed the radio because I could not hear while driving.
Buggy Brian
Buggy Brian is offline
PostPosted: Fri Dec 18, 2015 6:09 am    Post subject: Re: Empi Sportster Roll Call Reply with quote
Have the opportunity to purchase an original Sportster, but the seller doesn't speak much English, and it's hard to get much information about it. I've got the following pictures, and a couple of basics. No idea if it has a title, but definitely comes with a bill of sale (won't be an issue in GA), he state's that it runs good, and that's about it.
Based on the limited knowledge, and that it's more than a few hours away, I tend to limit my pricing on only what I can see.
I'm asking your opinions on value based on the below pictures and above description. Again, the above info is all that I can obtain at the moment.
Thanks!
Brian
[/img]
-(Loretta) Manx # M2940D910E on customized 1970 chassis by Joescoolcustoms
-(Scarlett) Manx Resorter #12 (R0012B931S) on 1969 chassis.
-Original Home built buggy that started all. I learned to drive in it back in 1985.
Manx Club Member # 4436
Check out my Loretta here: http://www.manxclub.com/forum/viewtopic.php?f=65&t=3365Manx
Scarlett is getting a Makeover! http://manxclub.com/forum/viewtopic.php?f=82&t=3745&p=24983#p24983
BL3Manx
BL3Manx is offline
PostPosted: Fri Dec 18, 2015 8:08 am    Post subject: Re: Empi Sportster Roll Call Reply with quote
You say its an original Sportster, do you mean original factory built or an older plans built? I can see a couple things that are different from a factory built.
Buggy Brian
PostPosted: Fri Dec 18, 2015 8:13 am    Post subject: Re: Empi Sportster Roll Call Reply with quote
BL3Manx wrote:
You say its an original Sportster, do you mean original factory built or an older plans built? If it is actually a factory made EMPI Sportster it would be worth more than a plans buit Sportster. I can see a couple things that are different from a factory built.
Sorry, I meant as in an old real Sportster. Not sure about factory built, but from what I have read, it would appear to be a kit. I'm just trying to find a fair price on it, before trying to negotiate.
Page 8 of 33
