Komissar Samba Member
Joined: May 18, 2008 Posts: 894 Location: Bucharest, Romania
Posted: Mon Jun 28, 2010 1:36 pm Post subject: 32 PCI question |
Hello,
I have recently bought on-line a Solex 32 PCI carb in excellent condition, however, it's missing the accelerator pump, cover, diaphragm and likage.
Do these items match from other solex carburettors ? If so ... from what specific carbs ? _________________ 1965 Sunroof Beetle
1972 Type 3 Squareback
1978 Skoda 105S |
EverettB Administrator
Joined: April 11, 2000 Posts: 69807 Location: Phoenix Metro
Posted: Mon Jun 28, 2010 11:32 pm Post subject: |
Thanks for the answer.
I only have the photos from the e-bay auction I bought it from.
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=270593801173
I am waiting for it to arrive, until then i can only speculate about it. _________________ 1965 Sunroof Beetle
1978 Skoda 105S |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Fri Jul 02, 2010 10:50 pm Post subject: |
IIRC the majority of a 28 kit will fit. But EB is correct. The Accelerator pump diaphram is different. It is the same as a bunch of other Porsche carbs and variations. Pretty hard to come by and spendy. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Posted: Mon Jul 12, 2010 9:00 am Post subject: |
The carb has finally arrived - and it's an odd little one
The pros might be the fact that is in "uber-NOS" condition - the recessed mixture adjustment screw still has a protective rubber cap on it ... and it's obvios this carb has never seen gasoline in it's life....
Now, ... for the odd parts - first there is a manual on/off idle jet - the long thin brass thing on the side of it, as it appears in the pictures. When you press it, it shuts-off the idle jet. ...
Regarding the accel pump - it appears to have been disabled at the factory, since although there is clearly a provision for an accel pump, i cannot find an "intake" hole inside of it ... I have attached a close-up picture of the pump area.
This clearly suggest a carb modified for an industrial aplication (the accel pump issue plus the "special" on/off idle jet ) ...
Does anyone have ever seen something like that ?
Uploaded with ImageShack.us
Uploaded with ImageShack.us _________________ 1965 Sunroof Beetle
1978 Skoda 105S |
Sunroof53 Samba Member
Posted: Tue Jul 13, 2010 10:55 pm Post subject: |
I had something similar years ago and was from a type 4 industrial engine.It was a 30 or 32 and looked just like a 28 pci but the stud spacing to mount it was 5mm further apart than a 28.One of those things i wish i had kept but couldnt find a use for it at the time. |
LittleMicroCars Samba Member
Joined: January 14, 2010 Posts: 123 Location: Carlsbad, CA
Posted: Thu May 31, 2012 8:52 pm Post subject: solex 32 |
maybe its set up for propane???? leo _________________ Importer of Steyr Puch rally cars, military Jeeps, and air cooled parts Vienna, Austria |
spuck Samba Member
Joined: March 14, 2014 Posts: 5 Location: Belo Horizonte - Brazil
Posted: Fri Mar 14, 2014 7:37 am Post subject: |
Are you sure this is a SOLEX carb? I don't really know if SOLEX made one named as it.
However, in Brazil the exactly same carb is known as WEBER 32 PCI
This is a very unknown information as there isn't any brand-logo on it
I am buying this carb right now, and I'll add a secondary venturi on it to improve idle stability |
AirCooledClassics Samba Member
Joined: August 20, 2004 Posts: 294 Location: Saskatoon, Sk Canada
Posted: Sun Mar 16, 2014 11:04 pm Post subject: |
This is an Industrial use carb. This division of vw did things very different from their car factory. We get brazil solex.peirsburg, and german solexes on crop sprayers and zambonis alone. this carb was meant to be used with a govenor so there is no provision for an accel pump. If you want this you going to have to drill the passages.check balls and seats,yourself. _________________ 2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552 |
