'56 Oval Baja Build with RGB's
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
joescoolcustoms Premium Member
joescoolcustoms is online now
PostPosted: Wed Sep 08, 2010 1:58 pm    Post subject: Reply with quote
Thats funny Louis! If the haters would have stepped up in the year that car was posted for sale on this site and restored it, then I would not be so tempted to bunk with Lucifer. It was sooo close to being cut up for parts when I bought it.
I do not look forward to doing the rust repair. I have a one piece front end and have kicked around using it on this body, but still want the sealed dash and trunk space. I will make that decission while holding the cut off saw.
The early bird might get the worm, but the second mouse gets the cheese.
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Member of Wagenfolks
http://images.thesamba.com/vw/gallery/pix/870707.jpg
http://www.thesamba.com/vw/forum/viewtopic.php?t=479740
LouisB
LouisB is offline
PostPosted: Wed Sep 08, 2010 2:13 pm    Post subject: Reply with quote
You seem to be a pretty talented fab guy, you could probably come up with an inner structure made from thin gauge sheetmetal or aluminum for the one piece front.
There was a blue and white oval baja w/ a bug eye kit in HVWs a few years ago that looked killer. Always liked that car.
--louis
Louis Brooks
'67 Manx II
Old people at weddings always poke me and say "Your next." So, I started doing the same to them at funerals.
PostPosted: Wed Sep 08, 2010 2:41 pm    Post subject: Reply with quote
Got a little more done last evening.
Before putting on the wheel adapters, I decided to weld up the press in studs so they would not break loose and turn, trapping the wheel on the adapter. Just a good healthy tack. I ran the aluminum adapters (4 VW to 5 chevy) for 6 years and 117,000 miles while commuting to college with out any problems and being hammered with a teenager and a 1915, so I bet these steel units will work OK.
I finished fabbing the E-Brake handle / Poor Mans Steering brake aparatus. I am now ready to cut the cables, silver solder them and install shorterners to get a E-Brake for it functioning.
Here it is at rest.
Here is one side in use to stop a spinning wheel when stuck.
Here is the E-Brake applied to park the car. Cool $ 5.00 purchase at a swap meet.
PostPosted: Wed Sep 08, 2010 6:48 pm    Post subject: Reply with quote
I am very close to finishing the pan. Just the last few small items left to go. Put oil in the RGB boxes, trans oil, short hard brake lines to the rear brakes, align the front suspension and rear suspension. I will wait until after the body is on to install the peddles because they will be in the way for rust repair work.
So, I just completed the cable shortening for the E-Brake / Poors Mans Steering Brake set up.
I am useing a EMPI part (darn it!). A cable shortening kit.
I then drilled out the shortening side a little to make room for the cable end like I want.
After measuring and marking the cables, I cut them to the length I wanted. Then, the reason for drilling out the cable shortening item, I slightly unraveled the end of the cut cable.
I then applied Flux and Silver Soldered the ends. (Some call it silver soldering, some call it silver brazing. Either way, it involves using a high composition silver rod and heating the steel to around 900*. It is WAY stronger than the lead/tin solder that is used on copper pipe). The unraveled end gave a slight taper to help physically keep the cable from slipping out of the the shortener.
The sand blasted handel is still drying from being painted, but here is a look at the shortened cables ready for use. I live on a hill and my drive way's slope, so getting the body out of one garage and into the next garage on this pan will involve a E-Brake to keep what is mine on my property.
The down side to using these poor mans steering brake set up is that the heater controls cannot be used in the stock location. Another fab problem to over come.
PostPosted: Thu Sep 09, 2010 8:24 pm    Post subject: Reply with quote
I contemplated not building the body lift at this time to help meet the goal of having a drivable Baja for October 25th. But, if I do not build it now, the rear bumper will not line up where it goes through the firewall to the roll cage when the body is lifted later. Also the risers off of the trans cradle forks that will also connect to the roll cage will be too short when the body is lifted.
So...
I barrowed a cut off saw from a friend and started the body lift. I am using the POS 3 inch body lift as a model to get started.
Then cut reliefs through three sides of the 2 X 2 boxed tubing and made the bends needed.
One side almost done in about 30 minutes. Just have to weld, grind, drill, clean up and paint. Yep, almost done. Rolling Eyes
surewriting
surewriting is offline
PostPosted: Thu Sep 09, 2010 8:54 pm    Post subject: Reply with quote
I am addicted to your build! It has truly been a pleasure to watch and learn as this cool vehicle is taking shape. I applaud your skills, ingenuity, and creativity. Keep the updates coming! Very Happy
STOICH
STOICH is offline
PostPosted: Thu Sep 09, 2010 10:40 pm    Post subject: Reply with quote
LouisB wrote:
I don't envy the rust repair you have ahead of you. I had a '67 in about the same shape and ended up making it into a Manx buggy lol. (Though an Oval may be worth it.) Good luck oh, and your going straight to 'ell for cutting up an oval into a baja. Laughing (Coming from a guy who cut up a '55 RHD ragtop car in about the same shape)
--louis
funny, my rag has the exact same story... in the classifieds, I actually titled it, "will be baja soon if not purchased" I got SOOO many "dont cut its" Ill buy it!! never came, which is why my blog got titled "guess I'll keeper"... Wink
ps Joe, funny to see you in a Benz getup... I work for Lexus myself, and my close buddy helping me on my build is also a Benz tech... we are quite often at each others throats about philosophy Laughing
my build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...;start=560
Lotrat
Lotrat is offline
PostPosted: Fri Sep 10, 2010 12:14 am    Post subject: Reply with quote
The heck with the date. Build it the way you want it. Don't rush it. How about October 25th, 2011?
PostPosted: Fri Sep 10, 2010 5:23 am    Post subject: Reply with quote
Thanks for the props surewriting, I am addicted to the build too! Plenty pictures to come.
STOICH, your build thread has inspired me also. I like seeing different ideas, it spurs creativity. The shirt is me being a cheap @$$. I bought a bunch of dealership shirts from a secondhand clothing store to work in. They are not very comfortable, wife hates the looks of them, but dang it, they do not stain like my tee shirts do. And they get me discounts at the parts stores from people thinking I work as a mechanic!
I am a firm beleiver in building the way you want Lotrat. Notice all the old school stuff? Swing trans on a Baja, who does that now days? E brake cable steering brakes, aluminum slot rims, ball joint front end, long ranger fuel tank. I am building it just the way I want and not sparing any quality, just on an accelerated time table.
The goal is a hard set goal because of my health. I can not walk very much due to my hips and knees and we are planning on going to the beach this fall. I cannot walk on the beach like I used to and want to drive about 100 miles of beach and dunes on vacation and cruise the full North Carolina Outer Bank islands.
I will not be finishing some things on this compressed build. Will not paint the body or body parts, will not repair the rust on the door bottoms, will not be putting in new interior, may not polish the front rims, mat not put the Thing spindles and disc brakes on the front to shave off time. These items will get done, just not in the next 6 weeks.
If I only did not have to work at my Garbage job (I work for a landfill disposal company), I could get something done.
Lotrat
Lotrat is offline
PostPosted: Fri Sep 10, 2010 8:55 am    Post subject: Reply with quote
So when are going in for a rebuild? My next door neighbor had his knees replaced and plays golf non-stop now.
PostPosted: Fri Sep 10, 2010 10:26 am    Post subject: Reply with quote
Wish it were that simple. I have had a kidney transplant 9 years ago and the medication I take deteriorates all my joints, attacks the muscles in the body and drastically slows healing. Unless it is a life/death circumstance, my doctors/surgeons prefer I do not have the joints replaced. At 45, I am just about as wore out as that '56 body I am using in this build, but I am alive and productive.
PostPosted: Sun Sep 12, 2010 1:21 pm    Post subject: Reply with quote
Body lift almost complete. Just final welding of sections to make a complete perimeter.
JWHracing
JWHracing is offline
PostPosted: Mon Sep 13, 2010 10:46 am    Post subject: Reply with quote
not to hi-jack or anything, but if you or anyone else is curious where to get those torsion bar covers CB Performance has them on their website. Saw them while i was browsing.
65 Baja, Turbocharged 1915 cc, IRS Rear, Link Pin front, 2.0 Fox Shox all around, full cage front to rear, Starburst blue and Briar brown paint, Douglas Aluminum Wheels, Pioneer components
LouisB
LouisB is offline
PostPosted: Mon Sep 13, 2010 12:43 pm    Post subject: Reply with quote
Nice work on the lift. I just finished welding mine up yesterday but I still need to drill all the holes.
--louis
Louis Brooks
'67 Manx II
PostPosted: Mon Sep 13, 2010 6:35 pm    Post subject: Reply with quote
Thanks JWHracing for the tip on those aluminum spring plate caps from CB Performance!
I understand LouisB, 52 9/16 holes will wear a man down, not to mention the drill bit too.
I filled up the RGB boxes and tranny with a combination of Lucas and 85 W - 90 gear oil. Installed the rear hard brake lines.
I more than tacked together the perimeter body lift, WOW! what strength that gives the pan. Still needs just a little welding to finish it after the body comes off for the gaskets. The heater channels are bolted in place and the pan is ready for a rusty body.
The body is all but toast. I did not realize just how extensive the rust is. But, I am saving a Oval, perse. What is shocking to me, the pan is in better shape than the body. Hopefully tomorrow, the rust pile will sit on top of the RGB pan.
roland
roland is offline
PostPosted: Tue Sep 14, 2010 2:00 pm    Post subject: Reply with quote
awesome work, love what you're doing with that baja!
If you don't have the right NOS one-eyed duck, or pressed-rib, super anodized industrial rarest-of-the-rare triple-hoop that wraps around your bus three times bumper, you ain't cool enough to hang with the big dawgs.
perrib
perrib is offline
PostPosted: Tue Sep 14, 2010 5:47 pm    Post subject: Reply with quote
Go for it I would have no problem Bajaing an oval or split if I find a cheap one. Your doing a great job.
PostPosted: Tue Sep 14, 2010 6:13 pm    Post subject: Reply with quote
Thanks for the props guys! Keeping me motivated to get it finished by my goal date.
Moved the other heaps around so I could get the new(er) '67 pan over to the house garage to get the '56 body. Wow, my legs are tired from pushing too many non-running VW's.
Here is the first shot with the body sitting on the pan!
Then push it back over to the work garage, ugh. (notice the floor dri where my SCab marks it's spot)
Progress! Not quite ready to just start welding back together yet. The body needs raised and the bad portion cut off, lowered back down then I can start welding back together.
BugMan114
BugMan114 is offline
PostPosted: Wed Sep 15, 2010 9:08 am    Post subject: Reply with quote
freakin sweet. I'm loving this build Cool
1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!!
LouisB
LouisB is offline
PostPosted: Wed Sep 15, 2010 9:46 am    Post subject: Reply with quote
Sits good and looking tough.
--louis
Louis Brooks
'67 Manx II
Page 6 of 10
