'56 Oval Baja Build with RGB's
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
tanner_122
tanner_122 is offline
PostPosted: Fri Aug 27, 2010 7:28 pm    Post subject: Reply with quote
badseed74 wrote:
this has got to be the best way ever to ruin a historic beetle,your so awsome !!! you should buy a schwinn krate and turn it into a mountain bike
quit your bitching this thing would have ended up rotting away or being crushed at the junk yard
if u dont like it leave the offroad fourm
91 jeep Cherokee "TANK"
mr.rong
mr.rong is offline
PostPosted: Fri Aug 27, 2010 7:32 pm    Post subject: Reply with quote
whats a matter? you cannot afford so you make fun of him?
Green bug Guy
Green bug Guy is offline
PostPosted: Sat Aug 28, 2010 12:50 am    Post subject: Reply with quote
hahahaha he's only making the other bugs out there worth more! hahahaahah the less there are the more money they are worth!
joescoolcustoms Premium Member
joescoolcustoms is offline
PostPosted: Sat Aug 28, 2010 10:13 am    Post subject: Reply with quote
Interesting. You must belong to the same group who bash me for lifting my '59 Single Cab Bus and off-roading it.
BTW, I did take my yellow metal flake Schwinn Apple Crate bike with the banana seat and turn it into a BMX in the day, after I welded two front forks together to make it a chopper.
The early bird might get the worm, but the second mouse gets the cheese.
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Member of Wagenfolks
http://images.thesamba.com/vw/gallery/pix/870707.jpg
http://www.thesamba.com/vw/forum/viewtopic.php?t=479740
PostPosted: Sat Aug 28, 2010 10:21 am    Post subject: Reply with quote
joemama wrote:
I have a couple of questions. So with the Johnson kit, you bolt the axle tube sleeve to the stock type 1 spring plate, and the only other thing that bolts to the rgb is the link to the torsion tube? I have a set of axle tube stiffners that look like could be made to work like the ones in the Johnson kit with the addition of a zerk fitting. Have you made a set of plans for copying the Johnson no hop kit? I would like to copy it, if you do. Also, can you use the type 1 backing plates and drums? or do you have to use the bus stuff? Do you think the width of this set up would fit in a class 11 type of car? or do you think it is too wide?
I know this is a lot of questions, but you are a great source of relevant info. Thank you.
First question, yes. The pivit alows the axle tube to twist and not bind up againt the lower strut. I have not yet made any plans on copying the JJ No Hop, and most likely will not. I do intend to take some pictures and post up the lower strut diminsions for future use.
Second question, On a large nut trans, only the bus backing plates and drums will work. On a small nut, I have read that Type III rear brakes will work.
Third question, I cannot answer this. But I will post up the mounting face to mounting face of the rear and you can make that determination. The mounting face to mounting face is 57 1/4 inches.
PostPosted: Sat Aug 28, 2010 1:13 pm    Post subject: Reply with quote
Welded the transmission mounting fork seams. I hate doing this because they are not a easy weld, but the strength that it adds is worth it. The top half and bottom half is just spot welded and during hard use/abuse, it can buckle in between the spot welds and fail. By welding the seam solid, it greatly reduces this happening.
I also welded the forward JJ No Hop strut mounts, (took out the torsions, rubber bushings so they would not get heat soaked) and welded in studs for the front transmission strap that goes where the gear case split is located.
PostPosted: Wed Sep 01, 2010 8:34 pm    Post subject: Reply with quote
I flipped the pan upside down to allow better access for my skid plate fab work.
I started out with a left over 1 5/8 DOM Tubing section from a previous roll cage build. I bent into it two 15 degree bends, then cut in half.
Came off of the torsion housing with these two pieces, picked up bracing from the bottom of the trans support forks. I will later weld vertical risers off of these tubes to go up to the package trey bottom to bolt into the down tube of the roll cage. These will also be the bottom mounts for the rear bumper. I welded tabs to bolt a skid plate onto with.
nukeworker
nukeworker is offline
PostPosted: Wed Sep 01, 2010 8:38 pm    Post subject: Reply with quote
That's some real nice looking work there.
DirtGhost
DirtGhost is offline
PostPosted: Thu Sep 02, 2010 7:02 am    Post subject: Reply with quote
Sweet !!!!
Orange Boxx Design and Fabrication
SAND RAIL PROJECT
Hot VW / VW Trends for sale trade
Wanted: four beat up, ugly, curb rashed 7" & 4" NON-bead locked BTR wheels
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
PostPosted: Thu Sep 02, 2010 11:42 am    Post subject: Reply with quote
Thanks for the props guys!
The wife has to work this Monday and do not. A full day on the body lift and rock sliders are now in order.
DirtGhost
PostPosted: Thu Sep 02, 2010 11:46 am    Post subject: Reply with quote
My Girl Friend has to work monday and I do not. Doc says I can start wrenching now. So back to work on the web car.
SAND RAIL PROJECT
K_Yandell
K_Yandell is offline
PostPosted: Thu Sep 02, 2010 2:03 pm    Post subject: Reply with quote
Are the J-Tubes of the exhaust going to clear? I ran some braces similar on a baja I had and ran into problems.
DirtGhost
PostPosted: Thu Sep 02, 2010 3:00 pm    Post subject: Reply with quote
Really nice job. Keep us posted of progress . It gives the rest of us ideas....
SAND RAIL PROJECT
shred625
shred625 is offline
PostPosted: Thu Sep 02, 2010 3:18 pm    Post subject: Reply with quote
Just please don't use that pipe bender for the roll cage. Its not s tubing bender!!
“It takes a big man to cry, but it takes a bigger man to laugh at that man.”
~ Jack Handey
PostPosted: Thu Sep 02, 2010 5:38 pm    Post subject: Reply with quote
The pictures are deceiving, remember the pan is upside down so these are 2 1/5 inches lower then the bottom of the engine. I am not going to run J-tubes, I am running high performance heat exchangers that I will be modifing for more heat capacity.
I know what you are saying DirtGhost, your build help inspire me and gave me ideas of other ways to do what I want to do.
Been beat to death on that subject shred. I have lost count of how many cages I have bent out of DOM Tubing with this set up, more than the amount of HF Kinker basher threads on this site. I will be using it again for this build and the tube chassis drag rail I am building. THAT is all I am going to say in this thread about THAT subject.
PostPosted: Thu Sep 02, 2010 5:58 pm    Post subject: Reply with quote
Made it home from work travel today and found these on the door step. New hardened steel Hiems with grease zerk fittings for my front tie rods.
Some DOM tubing, a little welding and bam!
sxuxrxf Premium Member
sxuxrxf is offline
PostPosted: Fri Sep 03, 2010 7:42 pm    Post subject: Reply with quote
Very clean skid plate mounting tubes. I wish I could turn my whole car over when I get to that point Sad
(ignore the X's )
Volker Rader Klub
Join us Saturday nights at IN-N-OUT on Hwy 76 and Frazee in Oceanside.
West Coast Bays
PostPosted: Mon Sep 06, 2010 8:56 am    Post subject: Reply with quote
Got the pan upright and ready to put it back as a roller!
I had given away my last spring plate tool to a local guy and had to make another. I use a old $ 2.00 swap meet VW jack and weld a bolt to the top. Use a hole on the shock tower and jack the spring plates into place.
Check out the cool spring plate covers I scored a few years ago for $ 10.00 at a swap in VA.
I went to Larry's Off Road Spring Nationals (rain reschedule) yesterday and in the swap meet area I scored these items for the Baja. A $ 2.00 fuel gauge (the '56 oval does not have a fuel gauge and this one will be mounted on below the dash and wired to a three position, three pole switch so I can switch between tanks and see what is in each. A German fuel pump stand and shift rod cover for $ 2.00. A set of clip on valve covers in very nice shape for $ 10.00. And a NOS Johnny's Speed and Chrome rear trans strap for a bartered price of $ 15.00. The JSC strap alows for the use of the stock rear mounts but still straps the bellhousing in rubber for a semi-solid securing of the trans and lessons the rattling vibrations into the car.
pafree
pafree is offline
PostPosted: Tue Sep 07, 2010 3:03 am    Post subject: Reply with quote
A set of clip on valve covers in very nice shape for $ 10.00. g]
great ideal using the jack. good luck with those valve covers though. they take a special size gaskets and i have never been able to use them without leaks.
1972 vw hunting truggy
sand it, fill it, paint it, throw some mud on it and then baja it.
PostPosted: Tue Sep 07, 2010 7:20 am    Post subject: Reply with quote
Thanks for the tip pafree! If they take special gaskets, they will go back to swap meet material in the future.
Page 4 of 10
