Chad1376 Samba Member
Joined: January 29, 2005 Posts: 1033 Location: Henderson, Nevada
Posted: Tue Sep 07, 2010 8:35 am Post subject: |
I love those spring plate covers. They should help dissapate heat and prevent grommet meltdown as you cycle the suspension..
Seriously, this is a great build to follow. Top quality work + great pictures. _________________ See progress on my "Free Thing" here
http://1973vwthingproject.blogspot.com/ |
JWHracing Samba Member
Joined: September 17, 2008 Posts: 102 Location: Gilbert, AZ
Posted: Tue Sep 07, 2010 9:18 am Post subject: |
i have those same exact valve covers on my baja and they take the same gaskets as every other valve cover. put some silicon on the gaskets and you'll have no leaks. _________________ 65 Baja, Turbocharged 1915 cc, IRS Rear, Link Pin front, 2.0 Fox Shox all around, full cage front to rear, Starburst blue and Briar brown paint, Douglas Aluminum Wheels, Pioneer components |
pafree Samba Member
Joined: August 16, 2005 Posts: 2166 Location: dayton, the one in texas
Posted: Tue Sep 07, 2010 10:10 am Post subject: |
[quote="joescoolcustoms"] | Quote: | | If they take special gaskets, they will go back to swap meet material in the future. |
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D5115G they have leaked for me and have read about others having leaking problems and the bales failing or loosening. they might work for some, just telling you what i know. _________________ 1972 vw hunting truggy
sand it, fill it, paint it, throw some mud on it and then baja it. |
joescoolcustoms  Samba Member
Joined: August 08, 2006 Posts: 6326 Location: West By God Virginia
Posted: Tue Sep 07, 2010 10:41 am Post subject: |
[quote="pafree"] | joescoolcustoms wrote: | | Quote: | | If they take special gaskets, they will go back to swap meet material in the future. |
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D5115G they have leaked for me and have read about others having leaking problems and the bales failing or loosening. they might work for some, just telling you what i know. |
Thoses are differrent than the ones I picked up. They use the channel rubber gasket. I had a set of those, and YES THEY LEAK!!! They are PITA's. I sold them at a swap meet about 3 years ago, will never use them again. These look to use a stock cork gasket, but I will let you know. _________________ The early bird might get the worm, but the second mouse gets the cheese.
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Member of Wagenfolks
http://images.thesamba.com/vw/gallery/pix/870707.jpg
http://www.thesamba.com/vw/forum/viewtopic.php?t=479740 |
Posted: Tue Sep 07, 2010 11:07 am Post subject: |
Thanks for the props guys! It does help motovate and give ideas.
I am trying to document the things that I have not seen in a typical baja build so others can see something different than just welding pans in a car. I am not building a hardcore offroad baja, but something to run the backroads of West Virginia. But still, some things I am documenting may help others in a small portion of their build. I often use unconvential tools or a backwards approach to get things accompolished by myself or with what I have on hand.
The trans is in for the final install. I have strapped it well in rubber to help reduce the vibrations that solid mounting produces. I may very well use it for work doing sales calls when the time is approiate.
The White KYB's where purchased at a swap meet about 2 years ago for $ 3.00 and they were new. So I have a combination of grey KYB's on the front and white ones on the rear. But a total of $ 17.00 in four new shocks is hard to pass up using. I also sand blasted and painted the lower strut bars that had been tossed around and had some minor surface rust. I tried the "Fake" cad plate paint and was not impressed, but they are protected.
Ever had a brake problem even after installing all new braking components? Just could not get the proper feel that the stock had but you knew it should be better? Maybe this might be a problem that gets overlooked a lot in old VW's.
The backing plates hold all the braking hardware and provide a guide for the shoes to expand and contract on as they move out to the drum and back. The shoes rub the backing plate and can rub a ledge on the plate that the shoe will not travel over. I have found this the norm rather than the exception on old used backing plates. Since I am regulated to useing the large nut backing plates, I just cannot just go search for a good set to use in my parts pile.
I weld up the contact area and grind it back down to the stock level to provide a new wear area for the shoes to slide over. It does not look pretty, but I have done it more times than I can count, not only on VW's but Chevy's too.
You may not be able to see the ledge created by the rubbing, my camera is not good at taking closeup detail pics, but you can see the raised bumps that the shoes ride on.
I welded them up and added a little extra weld to grind back out. On almost every one of them I burned through because the metal was so thin were it had worn off.
Then grinded them back down to the stock level. It does not look that pleasing to the eye, but is very effective.
tanner_122 Samba Member
Posted: Tue Sep 07, 2010 3:12 pm Post subject: |
looks great joe!
those spring plate covers are awsome!
do u know how much travel u will get? _________________ 91 jeep Cherokee "TANK" |
thefladge Samba Member
Joined: July 25, 2005 Posts: 896 Location: Long Beach, CA
Posted: Tue Sep 07, 2010 6:46 pm Post subject: |
| tanner_122 wrote: | looks great joe!
do u know how much travel u will get? |
Those are cool spring plate covers. I had a pair I was planning to install on my Baja, but they were destroyed in a garage fire.
Who makes those? _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers, Engle 120 cam, Bugpack Street Pro Heads, 12.5 pound Flywheel. Spare 1641cc engine.
Attention vendors! Don't send me racist political spam and expect to keep me as a customer. |
Posted: Tue Sep 07, 2010 7:15 pm Post subject: |
tanner I am expecting about 8.5 to 9 inches of total travel at the wheel. Nothing in comparison to the desert runners, but mine will never leave the ground without a jack under it.
The torsion covers are way cool looking. (I clear coated them in hopes of keeping them looking nicer longer) I could not find any marking on them at all. They came in a box that was clearly not the OG packaging. Looking at the quality of these and quality of other parts I have run across, they are medium-upper quality sand castings. They are not Claudes Buggys because everything I have had from them has their name on it. I have only seen one other set. It would be a tight fit using them without a positive offset rim to pull the tire farther away from the cap as it is about 3/4 inch thicker than stock.
I have completed the rear brakes. Blasted and painted everything. Lubed all pivit/slide points and ready to go.
These are monsters compared to the '69 - '78 rear type one set up. On the bus, they are rated for 1 ton (I say BS, but that is what VW showed) so they should really help stop a 31 inch tall tire nicely. Notice the brass adjuster. Cool addition from VW (I think). Will help from freezing up and rendering useless.
Posted: Tue Sep 07, 2010 10:01 pm Post subject: |
Because of useing the Large Nut RGB out of a bus, Type 1 parking brake cables will not work, (type 1 may work on a small nut or type 3 may work on the small nut). The bus E-Brake cable for a large nut has a special end on it that fits into a sleave that is factory welded onto the backing plate and the 1 ton brakes are larger in diameter requiring a longer cable inside the drum.
So I am starting out with a '64 to '67 bus E-Brake cables. They are WAAAYY to long, but fit the brakes and the pan.
Two or three years ago I scored a old set of Poor Mans steering brake handels. If you do not know what these are, they go on over the stock E-Brake handel and use the cables to lock up one wheel at a time and still allow the use of the stock E-Brake system.
I have picked a E-Brake handel that has been abused and the centering stud broken off on the cable distribution bracket. The cables go direct to the steering brake handels, then I will weld a cross brace to the stock handel that when pulled up will hit the bottom of the two handels picking them up also applying the parking brake evenly. More finished pictures will follow.
andychrist77 Samba Member
Joined: June 20, 2009 Posts: 158 Location: klamath falls, oregon
Posted: Tue Sep 07, 2010 10:56 pm Post subject: |
I like how you braced those transmission horns. Cool stuff _________________ only the dead have seen the end of war
69 baja,07 dodge ram,99 cbr 1100xx,88 V-max |
Lotrat Samba Member
Joined: December 08, 2007 Posts: 2510 Location: Carlsbad, CA
Posted: Tue Sep 07, 2010 11:24 pm Post subject: |
Sweet build. I like all the old school parts you got on so far. I'm running those valve covers too. Stock cork gaskets and some Gasgacinch to prevent the gasket from slipping off the edges is all you need. Leak-free since May for me. The bales are specific to those covers. Covers are Empi 9138, bales are Empi 9089, gaskets are 9907 (stock gaskets).
I'm also using the same strap. Love it.
And the same shocks. Hate them. Should have saved for some Bilsteins. |
Posted: Wed Sep 08, 2010 7:43 am Post subject: |
| Quote: | | And the same shocks. Hate them. Should have saved for some Bilsteins. |
Maybe that is why I got such a good deal on them at the swap meet. I had a set on the rear of the buggy I built that is my avatar, but don't remember them being to bad, but did not drive it very much before selling.
Can you expand on why they are not very good? I plan on keeping this ride for myself, so it will get upgrades later in life and shocks will most likely be on the short list. _________________ The early bird might get the worm, but the second mouse gets the cheese.
Lotrat Samba Member
Posted: Wed Sep 08, 2010 8:48 am Post subject: |
| joescoolcustoms wrote: | | Quote: | | And the same shocks. Hate them. Should have saved for some Bilsteins. |
Can you expand on why they are not very good? I plan on keeping this ride for myself, so it will get upgrades later in life and shocks will most likely be on the short list. |
Sorry, I should have qualified my comment. They are fine for street and trail use, but 5 minutes of rough stuff and they heat up and fade fast. The rebound rate on them is very light too. The back end becomes a pogo stick for most of your offroad trip. I went to 26mm torsion bars which stiffened up the ride. I don't bottom out as much, but the rebound is even worse now. Again, street and trail use they will probably be ok. |
STOICH Samba Member
Joined: November 26, 2004 Posts: 1098 Location: vista, CA
Posted: Wed Sep 08, 2010 9:21 am Post subject: |
| Lotrat wrote: | | joescoolcustoms wrote: | | Quote: | | And the same shocks. Hate them. Should have saved for some Bilsteins. |
Up till now, I was defending the KYBs... but he does have a point about them fading out when hot... _________________ my build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...;start=560 |
Posted: Wed Sep 08, 2010 9:23 am Post subject: |
| STOICH wrote: | | Lotrat wrote: | | joescoolcustoms wrote: | | Quote: | | And the same shocks. Hate them. Should have saved for some Bilsteins. |
Up till now, I was defending the KYBs... but he does have a point about them fading out when hot... |
What is the difference between the Grey KYB's and the White KYB's? _________________ The early bird might get the worm, but the second mouse gets the cheese.
Lotrat Samba Member
Posted: Wed Sep 08, 2010 9:38 am Post subject: |
| joescoolcustoms wrote: | | What is the difference between the Grey KYB's and the White KYB's? |
About $13 bucks.
The grey GR-2 are for a soft ride.
The white ones are for a firm ride. |
Posted: Wed Sep 08, 2010 9:42 am Post subject: |
| Lotrat wrote: | | joescoolcustoms wrote: | | What is the difference between the Grey KYB's and the White KYB's? |
About $13 bucks.
Cool! My front/Grey, rear/White combo should work decent on mostly street and mild off road. Even a blind squirrel will find a nut every now and again. _________________ The early bird might get the worm, but the second mouse gets the cheese.
Last edited by joescoolcustoms on Wed Sep 08, 2010 12:38 pm; edited 1 time in total |
LouisB Samba Member
Joined: August 16, 2004 Posts: 1034 Location: Tallahassee, FL
Posted: Wed Sep 08, 2010 12:16 pm Post subject: |
Great build. Did you make any mods to your front beam other than adjusters?
Thanks,
--louis _________________ Louis Brooks
'67 Manx II
Old people at weddings always poke me and say "Your next." So, I started doing the same to them at funerals. |
Posted: Wed Sep 08, 2010 12:41 pm Post subject: |
| LouisB wrote: | Great build. Did you make any mods to your front beam other than adjusters?
Thanks,
--louis |
Thanks Louis!
I installed the adjusters and welded the seams on the shock towers. I will change out the Type 1 trailing arms and brake hardware for Thing trailing arms and disc brakes. I am contimplating welding in some bracing on the shock towers for added strength, similar to the Thing beams. _________________ The early bird might get the worm, but the second mouse gets the cheese.
LouisB Samba Member
Posted: Wed Sep 08, 2010 1:00 pm Post subject: |
I don't envy the rust repair you have ahead of you. I had a '67 in about the same shape and ended up making it into a Manx buggy lol. (Though an Oval may be worth it.) Good luck oh, and your going straight to 'ell for cutting up an oval into a baja. (Coming from a guy who cut up a '55 RHD ragtop car in about the same shape)
'67 Manx II
