joescoolcustoms  Samba Member
Joined: August 08, 2006 Posts: 6366 Location: West By God Virginia
Posted: Tue Jul 06, 2010 8:47 am Post subject: |
| VIN wrote: | | what do the no hops do and where do they go? |
Because the split window buses use a two gear reduction box, the axles have to turn backwards to make the bus move forward. Working in reverse fashion, the top gear wants to climb around the lower gear. When power is applied, the climbing action can make the rear wheel hop up off the ground in rapid fashion.
This John Johnson No Hop kit re directs the forces that cause the hop and focus it on moving the vehicle forward. _________________ The early bird might get the worm, but the second mouse gets the cheese.
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Member of Wagenfolks
http://images.thesamba.com/vw/gallery/pix/870707.jpg
http://www.thesamba.com/vw/forum/viewtopic.php?t=479740 |
Posted: Tue Jul 06, 2010 8:49 am Post subject: |
| thefladge wrote: | As the owner of a '57 Baja Bug with reduction boxes, I approve of this build.
It also looks like I am going to be running the same rear fenders as you have. But my rear deck/engine cover will be different.
I have always admired your baja! _________________ The early bird might get the worm, but the second mouse gets the cheese.
thefladge Samba Member
Joined: July 25, 2005 Posts: 896 Location: Long Beach, CA
Posted: Tue Jul 06, 2010 7:09 pm Post subject: |
| joescoolcustoms wrote: | | thefladge wrote: | As the owner of a '57 Baja Bug with reduction boxes, I approve of this build.
I have always admired your baja! |
Thanks. I might be changing my engine cover. I've located 2 Miller-Havans style engine covers that are pretty beat up. I plan to make one good one out of the 2 bad ones and install it on my Baja.
Here's a picture of one of the engine covers fitted loosely to my car.
 _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers, Engle 120 cam, Bugpack Street Pro Heads, 12.5 pound Flywheel. Spare 1641cc engine.
Attention vendors! Don't send me racist political spam and expect to keep me as a customer. |
VIN Samba Member
Posted: Wed Jul 07, 2010 5:31 pm Post subject: |
| joescoolcustoms wrote: | | VIN wrote: | | what do the no hops do and where do they go? |
This John Johnson No Hop kit re directs the forces that cause the hop and focus it on moving the vehicle forward. |
gotcha. |
Posted: Mon Jul 26, 2010 12:36 pm Post subject: |
Finally got some time to work on the '56.
Did some cutting, hacking, picking, pulling and general ripping apart.
The front fenders where so bad, I had to cut them off the car, then deal with the fender bolts.
The front lower wheel wells had been fixed with bread wrapper bags and roofing tar. Not kidding! I pulled about 8 Wonder Bread plastic bags out of the front firewall, wheel well area! No additional metal, no bondo, no pop rivited aluminum, just plastic bags and roofing tar. ????????
Made the first rough cuts of the front and rear to get the rusty aprons off of the car and see just how many and what rust repair panels that will be needed.
The rear was easy, just hack it off.
I can stick my hand flattened out into the interior of the car through these rust holes.
Initial front hack.
Pass front is rough. Not as many bread bags on this side tho...
The fender mount area is almost gone and will have to be replaced before fenders can go back on.
There was 7 bags stuffed up into the rusted out areas and then coated over with roofing tar.
PO had scrapped here to see what the Original color was. Small tag states "Made in West Germany". _________________ The early bird might get the worm, but the second mouse gets the cheese.
tanner_122 Samba Member
Posted: Mon Jul 26, 2010 12:43 pm Post subject: |
lol hungry for wonder bread?
cant wait to see the progress _________________ 91 jeep Cherokee "TANK" |
Posted: Mon Jul 26, 2010 7:29 pm Post subject: |
Wow! That is one rusty machine!
My Baja has a few rust problems here and there that I have been avoiding for many years. Eventually the body will have to be unbolted from the pan in order to do all of the repairs.
I think I will watch what you do before I try and do the same to my car. _________________ 1957 Vintage Baja Bug.
Posted: Mon Jul 26, 2010 7:55 pm Post subject: |
| thefladge wrote: | Wow! That is one rusty machine!
I think I will watch what you do before I try and do the same to my car. |
It is a major pile. If it was not an oval in distress, I would have never looked at it twice. But with all the rust repair required, the nazi purist can suck my rust before complaining I cut a oval to make a baja. Most purist would have cut it up to save another oval. I am saving a old bug, sort of.
Just took stock in what needs repaired/replaced/grafted on the body:
Both lower A pillers (Have from another cut up '62)
Both Heater channels (already bought for another project that never happened)
Both rear lower quarters (already bought for another project that never happened)
Right rear inner fender wheel well (New panel came with the car)
** All four fender mounting arcs/bolt holes ** (some new panels came with the car)
Lower portion of the front firewall (Have a new one from another project that I cut out of a dumped project)
Body-to-Pan/torsion housing bolt areas under rear seat
Right upper quarter panel where hood meets body (have sacrifical car as a donner)
I have some repair panels already and have a donner '73 body to graft the Right upper front quarter panel. I also already have the two heater channels (late model, but so what) and a new front fire wall. I had cut up a '62 beetle this spring and saved the lower A Pillers, (finally I had good foresite for once). So I have a hughe jump start on rust panels. Just have to get cracking.
My next decission is how to attempt the heater channels. I will weld in door opening braces before going any further, but try to replace on the pan (which to my amezement is in great shape) or remove the body and replace. My major concern is keeping the heater channels in one plane so they will match back up with the new '67 pan that is already done. My only good reference points are the front and rear humps. I may remove the body and place on the '67 pan with the heater channels already bolted in place.
Pictures will follow as to how I proceed. _________________ The early bird might get the worm, but the second mouse gets the cheese.
Posted: Tue Jul 27, 2010 7:16 pm Post subject: |
I traded some parts for a nice set of early pop outs for the rear quarter windows! Major score, had all the parts and in great shape.
I have soooo much rust to repair that I think I will bolt the heater channels onto the new '67 pan and then lower the '56 body on top of it until the forward and rear humps line up. It is the only way I see to make sure everything lines up once it is all welded. I will then pull the body back off to make the 2 inch lift.
So, the next step was to shut and shim the doors to creat the perfect gaps and weld in door braces out of 1 inch and 3/4 inch boxed tubing. I removed the rear quarter glass so as not to "weld Spot" the good glass and make it easier to weld the braces with the doors shut.
I then removed the doors. I was very suprised that the screws came out so easy.
I also installed a brace between each side to keep the bottom of the B piller stable.
Both quarters are rusted away from the heater channels.
The front of the heater channels and the front firewall lower section is gone also. _________________ The early bird might get the worm, but the second mouse gets the cheese.
Posted: Fri Jul 30, 2010 10:14 am Post subject: |
I put the Large nut Reduction Gear Box (RGB) transaxle on the stand. It will get a good going over. I will replace the syncros, any bearing that are questionable, all gaskets and seals. I will also make a custom longer throw out arm to ease the "clutchities" in my left leg.
First thing is to take the 46mm nuts off the axles and remove the drums. I have read where some drums get so stuck, they have to be cut off. Next is to drain the RGB box, romove the outer housing, then the gear/bearings stacks to get to the axle tube.
I will have to make my own tools to press the tubes out of the inner RGB box halfs so I can install the JJ no hop parts onto the tubes and re-press the tubes back into the box halfs. Also the inner box half has to be machined 1 5/8 inch off to make it fit up to a Type one torsion houseing spacing.
Posted: Fri Jul 30, 2010 1:48 pm Post subject: |
I have the trans pulled down. It is either a '65 or a '66. It is a large nut with a 6V bellhousing.
1.26:1 RGB's
4.375:1 Ring and Pinion
3.80 first
2.06 second
1.26 third
0.89 fourth
I will have a final drive ratio of 5.52:1
With 31 inch tall tires, I will run 56 MPH at 3000 rpm and 66 MPH at 3500 rpm. 70 MPH will be about 3750 rpm. My usable rpm range will be between 2000 and 3500 rpm, very sweet spot for a 2276 with 041 heads and a W110 cam. Major torque.
Everything looks to be in nice shape, but I will still change out the syncro's while I am in there. Have been playing around with the gear calculater to see what it would be like with a 4.12:1 ring and pinion, but if I stay where I am, I can run 32 inch tires and be OK at a later time.
I do think I will go ahead and install a superdiff in it while I have it apart.
Here is the gear calculater I have used for a number of years. It is a lot quicker than using the old TI-35. Scroll down to the bottom of the page and input your ratios and tire size for comparison.
http://www.shining-wit.net/rick/buggy/design/transmission/#Transaxle%20Ratio%20Calculator _________________ The early bird might get the worm, but the second mouse gets the cheese.
badseed74 Samba Member
Posted: Fri Jul 30, 2010 7:44 pm Post subject: |
this build reminds me of a jeff goldblum quote,"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should _________________ As the light changed from red to green to yellow and back to red again, I sat there thinking about life. Was it nothing more than a bunch of honking and yelling? Sometimes it seemed that way. |
Posted: Mon Aug 02, 2010 1:36 pm Post subject: |
| badseed74 wrote: | | this build reminds me of a jeff goldblum quote,"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should |
Uhm...
OK if you say so. _________________ The early bird might get the worm, but the second mouse gets the cheese.
Posted: Mon Aug 02, 2010 1:46 pm Post subject: |
Here is some of the most difficult part of this build for me. Installing the axle tube pivits of the JJ No Hop kit. The axle tubes have to be pressed out of the inner RGB box. This is not for a novice to take on.
I built a press jig to hold the RGB Box in a verticle position so the tube could be pressed out.
Then, crossing my fingers, set it up in my press.
That thing worked great!
Now I have both tubes pressed out of the RGB boxes.
One cool side effect of pressing the tubes out of the RGB Boxes is being able to use the completely sealed axle boots! lessons the likelyhood of leaks by leaps and bounds. No more bolt seams to contend with.
So the next step is to machine the RGB to accept the JJ No Hop pivit sleaves and then clean up everything and start pressing it back together. _________________ The early bird might get the worm, but the second mouse gets the cheese.
Gregorio Samba Member
Joined: March 29, 2006 Posts: 286 Location: Chico, CA
Posted: Tue Aug 03, 2010 7:20 am Post subject: |
| Looking great, keep up the good work! |
kadub Samba Member
Joined: November 04, 2004 Posts: 209 Location: Auburn, Wa
Posted: Tue Aug 03, 2010 8:05 am Post subject: |
Cool build project! Looks like you're gonna have your hands full with some rust repair on that oval, but what a great opportunity to build a baja .
Your gear combo looks just about perfect too. I wish I'd spent some more time on a gear calculator before having Rancho build my 091. I'll be @ 4,000rpm @ 66mph w/31's . Guess I won't be speeding much...
Best of luck with your progress! |
kadub Samba Member
Posted: Tue Aug 03, 2010 9:38 am Post subject: |
| joescoolcustoms wrote: | | kadub can you go with a taller tire? 32's maybe to get just a little extra. |
Ya, I might end up going with taller rear tires to see how it helps with highway rpms, there's room back there for 'em. I really should have just spent some more time figuring out exactly what I needed before calling Rancho. Of course I want to do everything with one setup, which is pretty unreasonable: putt around trails in 1st, tow a small trailer on trips, be able to pull 4th gear w/paddles in the sand, etc. High hopes . I've just got to try it out and see before I re-gear a brand new trans. And tires are definately cheaper than trans work . |
Posted: Tue Aug 03, 2010 7:35 pm Post subject: |
The next step on the chassis is to cut the inner RGB case to fit the JJ No Hop Kit.
The bus spring plates bolt right up to the RGB inner case under the axle tube. The JJ No Hop Kit keeps the Type 1 spring plate in the stock position (splitting the axle tube) by installing a rotating sleave on the RGB axle tube and bolting the T1 spring plate to the rotating sleave.
The modification to the RGB inner case is to trim the tube snout so the width matches the T1 measurement.
The outside of the bus spring-plate-to-spring-plate in exactly 3 inches wider than the T1 spring-plate-to-spring-plate outside dimension. Since I want the trans to be centered in the chassis, 1/2 of the difference needs to be taken off each side.
This may be hard to follow without installed pictures, but if you follow the build you will eventually see what I am talking about.
The T1 needs to be 1 1/2 inch narrower at the spring plate mount on each side than the bus spring plate mount. This picture I am marking the cut line 1 1/2 inch from the bus mount location.
This picture is after cutting the excess 1/2 inch (very close to 1/2 inch, but will vary due to casting differences) on a band saw.
Now that my modifications are done, the next step is to clean, blast, clean again and start putting the RGB's back together.
Cleaning and blasting starting tomorrow. _________________ The early bird might get the worm, but the second mouse gets the cheese.
Posted: Sat Aug 07, 2010 2:18 pm Post subject: |
I have worked media blasting about everything I could get my hands on for this build. Before blasting, all parts are scrubbed in the parts washer first, then scrubbed again to remove the dusting of grit before putting together.
So, after painting the freshly cleaned up parts, it is time to start asymbly of the RGB trans and axles.
Here I am pressing the axle tube back into the inner RGB box. Careful to line up the "notch" with the "pin". The pin pressing into the housing and clocks into the tube to hold the tube in and from spinning.
Both sets pressed together and ready for the reduction gear sets and the 8 wheel bearings. I had one NOS axle tube retaining ring that I finially used to replace the worst beat up retaining ring.
