Build a new 2387 - please advise -- now 88 stroke TF-1 case?
markhuebbe
markhuebbe is offline
PostPosted: Wed Jan 09, 2013 2:11 pm    Post subject: Build a new 2387 - please advise -- now 88 stroke TF-1 case? Reply with quote
Let's first get a few things out of the way. 1. already searched. 2. Not a newb.
OK I'm thinking of building a 2387. I finally cracked my mag case on my 2276. So what better time to go bigger? Laughing I'd like to reuse some existing components and buy only whats needed.
I've got:
044 wedge ports 44x37.5
FK45 cam w/1.4:1 rockers
5.5 rods vw
Plan to buy:
CB raised roof alum. case
94mm long barrel AA cylinders
5.6 chevy rods
So what crank should I get? After some research I think at a minimum it would be T4 center main. I'd like to use my existing flywheel so no wedge or flange (remember I'm not drag racing).
Should I go DPR 86mm with T1/T4 center main, chevy rod? Full circle needed?
I'd also like to keep the engine narrow. Thinking of Wiseco or JE pistons in "C" comp height. Does pin comp height neglect any gains of using 5.6 rods when figuring rod ratio & minimizing wear to the piston skirts? I'm calculating that 86 stroke + 5.6 rod + C pin = 8.348" and my 82 stroke + 5.5 rod + B pin = 8.494". So it might be narrower. That correct? Stock 69mm is 8.319"?
1970 Beetle - Rally car
http://www.Rally-America.com
http://www.HuebbeRally.com
Dan Ruddock
Dan Ruddock is offline
PostPosted: Wed Jan 09, 2013 2:26 pm    Post subject: Reply with quote
What 82mm crank do you have now? I have a preferance for the six circle demello cranks. Dan
DarthWeber
DarthWeber is offline
PostPosted: Wed Jan 09, 2013 2:34 pm    Post subject: Reply with quote
Are you a newb? Or are you serious?? Very Happy
http://m-specmotorsports.com/M-SpecProducts/M-SpecProducts.htm#BilletCranks
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
58Dub
58Dub is offline
PostPosted: Wed Jan 09, 2013 2:35 pm    Post subject: Reply with quote
the shorter pistons will not change your rod ratio.
58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project
markhuebbe
PostPosted: Wed Jan 09, 2013 2:36 pm    Post subject: Reply with quote
DRD
Ian Godfrey
Ian Godfrey is offline
PostPosted: Wed Jan 09, 2013 2:37 pm    Post subject: Reply with quote
I went 86 crank, type 4 centre main, porsche 5.5 rod, custom JE pistons. It is stock width, all tin just bolted on, studs work etc.
I don't see any advantage in the longer rod, with 5.5 rod the oil rings are still just above the piston pin, 5.6 I think you would be over the piston pin, which makes assembly a bit harder.
I am sure you could use chev journal rods, the porsche journal gives more overlap with the mains (stronger).
You will ned a clearanced cam. Or clearance the one you have.
I have had very good quality and service from DPR. I'm in OZ
markhuebbe
PostPosted: Wed Jan 09, 2013 2:38 pm    Post subject: Reply with quote
I'm not made of money. Razz Just trying to figure out a way to get a bit more torque. The thought crossed my mind just to replace the case, but if I'm rebuilding the whole thing why not go a bit bigger while I've got it apart?
markhuebbe
PostPosted: Wed Jan 09, 2013 2:51 pm    Post subject: Reply with quote
Ian Godfrey wrote:
...with 5.5 rod the oil rings are still just above the piston pin, 5.6 I think you would be over the piston pin, which makes assembly a bit harder....
How does rod length have anything to do with where the oil rings are positioned on the piston in relation to the pin?
Am I not following you correctly?
Does anyone have specs for "C" pistons? Would I just give them specs for a shelf stock "B" piston but with a different compression pin height?
If I'm using custom pistons does it make sense to spec a different ring package? 2x2x4, 1.5x2x4, etc....
58Dub
58Dub is offline
PostPosted: Wed Jan 09, 2013 2:53 pm    Post subject: Reply with quote
Aircooled.net lists the compression height of the C piston at 1.055. by moving the pin up, you can also make the piston shorter, so lighter. I havent purchased a C set yet, but do plan to in the near future
markhuebbe
PostPosted: Wed Jan 09, 2013 2:59 pm    Post subject: Reply with quote
Yes I think they list a "C", but it's their squishy one. I thought you needed a wider base circle cam and possible head work? I'd like to use my existing cam and heads.
58Dub
58Dub is offline
PostPosted: Wed Jan 09, 2013 3:05 pm    Post subject: Reply with quote
I'm not sure on the cam, but I was told through their tech email that they did not require a specific head. With the compression height spec, you could have most any piston company make up a lightweight piston.
Ian Godfrey
PostPosted: Wed Jan 09, 2013 3:30 pm    Post subject: Reply with quote
Markhuebbe, if you decide on the engine width (barrel length), deck and stroke, the 2 variables left are rod length and pin height in the piston. I found a good compromise with 5.5 rods and custom pistons.
markhuebbe
PostPosted: Wed Jan 09, 2013 3:42 pm    Post subject: Reply with quote
unanswered questions:
Specs for "C" pistons? Would I just give them specs for a shelf stock "B" piston but with a different compression pin height?
Does it make sense to spec a different ring package? 2x2x4, 1.5x2x4, etc....
Full circle crank needed? Help with crank flex?
Dan Ruddock
PostPosted: Wed Jan 09, 2013 3:57 pm    Post subject: Reply with quote
There is a wrong way to do full circle and a right way. The thick cheek can be full circle but the thin cheek should still have the counter weight shape. If done in a complete circle you lose the counter weight effect. The crank in the center of this pic is done the right way. It is by Demello. Even better is a porsche rod forged berg or okrasa because the narrow rod makes the cheeks thicker. The longer the stroke the more crank flex you will have so it is important to get something strong. Dan
mark tucker
mark tucker is offline
PostPosted: Wed Jan 09, 2013 4:40 pm    Post subject: Reply with quote
dan those are just counterweighted not full circle, but like you stated you loose some of the counterweighting affect.but that can be addressed in other ways, but it's just a vw so why bother Shocked .....depending on the oiling of the crank the throws can be drilled,some more than others.and or heavy mettell added to the crank counterweights.the full circle does give some added strength & cross section too.also windage is reduced somewhat.
Dan Ruddock
PostPosted: Wed Jan 09, 2013 4:53 pm    Post subject: Reply with quote
The thick cheek that connects the two rod journals are full circle but the rod to mains are not. Dan
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Wed Jan 09, 2013 7:34 pm    Post subject: Reply with quote
Considering that boxer engines are inherently balanced because of their design, it matters not if the crank has counterweights or not. So long as the parts connected to it are all the same weight, you would not be able to tell the difference between a non c/w and one that has them. Now if material is being added as a strengthening means, that's a perfectly logical thing to do. I wish someone would come out with a VW crank that was just plain stronger, the gimmicks are real old at this point. Especially the heavy 6 circle thing, totally pointless.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
Dan Ruddock
PostPosted: Wed Jan 09, 2013 8:13 pm    Post subject: Reply with quote
I guess porsche was wasting there time when they counter weighted the 912 crank. Your position amazes me. Dan
Words from Berg
Why a Counterweight Crankshaft? The VW air-cooled engine is designed for low RPM, low power output and high mileage use. When used that way it gives many years of trouble free service with little or no wear. However, the higher the RPM, power, or the quicker the acceleration, the more the centrifugal force bends the crank at the center main. This bending force occurs because the two center rod journals are on the same side, putting all the weighted forces on one side of the crankshaft. This pounds out the case at the center main saddle, plus makes the pulley and flywheel run out often damaging the case at the pulley end.
modok
modok is offline
PostPosted: Wed Jan 09, 2013 8:32 pm    Post subject: Reply with quote
Dan Ruddock wrote:
The counterweight/gusset welded all the way around is what Bob calls his "raceweight", you can have him just do those or do the middle webs too. $$$
they gussets/weights are seamless, unlike some other crank guys Wink
vwracerdave
vwracerdave is offline
PostPosted: Wed Jan 09, 2013 8:40 pm    Post subject: Reply with quote
miniman82 wrote:
I wish someone would come out with a VW crank that was just plain stronger.
There are stronger cranks out there, most people just won't pay $1500-$1800 for them. You're not going to find a stronger Chinese crank for $300, and your not going to get srtonger by welding up a stock crank..
