cdog334 Samba Member
Posted: Fri Jul 09, 2010 2:26 pm Post subject: Trunk liner install info |
Has anyone ever replaced a trunk liner in a 1965 bug? If so can anyone show picture of how it looks installed?
I just got one on from Jbugs (heavy cardboard) and i can not figure how it make it fit.
Some instructions would be nice !
thanks |
stale air Samba Member
Joined: August 23, 2007 Posts: 5154 Location: Senoia Ga, formally NorCal
Posted: Fri Jul 09, 2010 2:46 pm Post subject: |
Im not sure what Jbugs liner looks like, but this is how WW sells theirs. It should just sit down on top of the gas tank just like in the picture below.
_________________ WANTED: Henry Veale Santa Rosa plate frames
Blu67Bug Samba Member
Joined: March 01, 2004 Posts: 1011 Location: 50 Minutes N of the Big Apple
Posted: Fri Jul 09, 2010 3:01 pm Post subject: |
Firstly, you have to fold the Front End into a triangular shaped tube like that picture above.
Then you have to CAREFULLY bend & wiggle the cardboard piece into place. The area around the trunk hinges is the hardest, but if you go slowly, you'll figure it out.
By the way, removing it, is the same idea, go slowly, and remove the area around the hinges/springs first, and it will go fairly smoothly. _________________ '67s Rule & '71 Buses Too! |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Fri Jul 09, 2010 3:43 pm Post subject: |
A little trick that I just did on my wifes 61 was to insert a strip of 1/2" plywood in the front strip to give it a little more "form".
Something else - I had sprayed the liner on my 65 with several coats of Krylon clear to make it easier to keep clean - first one or two soak in, but by the third coat you get a gloss and its held up for several years on the 65. Wish I had not been so anxious to get the liner in her 61 or I would have done the same thing. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Fri Jul 09, 2010 5:00 pm Post subject: Trunk liner install info |
Does anyone have any picture with the liner installed?
thanks
Thank to all who have replied |
Posted: Fri Jul 09, 2010 6:47 pm Post subject: Re: Trunk liner install info |
cdog334 wrote: |
thanks
66 Bahama Blue _________________ WANTED: Henry Veale Santa Rosa plate frames
Posted: Fri Jul 09, 2010 11:43 pm Post subject: Trunk liner install info |
Thanks to all who replied i got it now ! I had to glue the carpet to it, to keep the carpet in place.
Thanks |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
eagle5127 Samba Member
Posted: Sat Jul 10, 2010 6:10 am Post subject: |
please don't say you glued carpet on top of the new trunk liner .. |
Posted: Sat Jul 10, 2010 7:17 pm Post subject: |
yes i did !
Any reason why i sould not have?
I found it keeps it looking uniform and stays in place nice.
i'm a newbie ...... |
old_n_slo Samba Member
Joined: August 08, 2009 Posts: 269 Location: Air-id-zona
Posted: Sun Jul 11, 2010 3:32 pm Post subject: |
cdog334 wrote: |
Any reason why i sould not have? |
Ok, I'll come out and say it. Ewwww. Sorry to pass on personal opinion. I guess it's that keeping it as original as possible would be the choice of many.
I'll all about how YOU want it to look though. I just hope you didn't tack my parents orange shag from the living room from when I was a kid...cause then we would have to.....oh..never mind.
Posted: Sun Jul 11, 2010 4:14 pm Post subject: |
cdog334 wrote: |
yes i did !
be very careful when you put gasoline in your gas tank newbie. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Sun Jul 11, 2010 5:52 pm Post subject: |
The carpet i put in is the preform kit from TMI. I found it makes the whole thin more ridgid and a better fit.
i trimmed off the wire cover part, it was too tall. plus i had a empi one already painted.
i will post pictures this comming week.
thanks
ps any orange shag carpet left over ? I need to do the interior ! let me know. Green would be ok... |
buggeezer Samba Member
Posted: Wed Oct 01, 2014 1:46 pm Post subject: |
Spraying clear on that liner seems like a good idea. Maybe I'll do mine with PPG clear with a gun. I am so afraid it will stain easily without some protection. |
Posted: Thu Oct 02, 2014 3:43 am Post subject: |
buggeezer wrote: |
This is something I have been debating to ever do again. The clear helps seal and make it look pretty, but if you use the trunk (which I do - a lot), the scuffs seem to show up worse. _________________ D-Dubya Manx clone - 63 Short pan,1914.
cyclehobby Samba Member
Joined: August 29, 2013 Posts: 156 Location: North Jersey
Posted: Thu Oct 02, 2014 6:35 am Post subject: |
My 67 has the original trunk liner (and dash back cover), but it's in really horrible shape. Someone, sometime long ago, must have spilled motor oil right in the middle of it and I guess over time, even though they cleaned it as best as they could, it started to split and kind of rot.
So, based on that scenario, perhaps clear coating it would protect it some.
I just hate to get rid of it. So, I've laid some black auto carpet down to kind of disguise it. The carpet stays in place due to my canvas tool bag, California Car Duster, extra belt and lug wrench sitting on it. The folded lip of the trunk liner still shows its there and it's not in as bad shape as the liner itself, so everything looks nice.
At the recent Flanders (NJ) air cooled show, Chris Vallone (Classic VW Bugs) had a really nice liner in his new 51 Bug. Instead of the large staples that hold the stock mult piece liner together for that year, he used brass rivets which looked great. Not stock from the purest's point of view, but very, very nice. It looked like it could have come that way from the factory. _________________ 1967 Beetle
Northern NJ |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Thu Oct 02, 2014 8:00 am Post subject: |
I have a new repro liner and wiring cover from WW. It fits great, but has a very dull, flat appearance, and does show some scuff marks. I've actually thought about waxing it to give it that semi gloss look (closer to original) and maybe give it some protection from scuffs. Has anyone tried anything like this?
I almost imagine a wax coating, like you get on some vegetable/produce boxes. _________________ Plate of shrimp |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Oct 02, 2014 9:55 am Post subject: |
holy crap Batman, it's just a trunk to throw stuff in _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
grandpa pete Samba Member
panicman wrote: |
I almost imagine a wax coating, like you get on some vegetable/produce boxes. |
try the wax on an inconspicuous corner....some car waxes will seep into non metallic surfaces and leave a milky white sheen that won't come off.....I made that very expensive mistake back in my 56 chevy days _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Posted: Thu Oct 02, 2014 10:12 am Post subject: |
I don't think I'll clear coat it because it will be shiny and even with a flex agent it might chip off. Since this is a show car I guess I'll leave the liner out until car shows. My son said the tank and trunk look so good that I should show it that way. Undecided. |
