Jim Clark Samba Member
Joined: January 29, 2004 Posts: 138 Location: Lincolnshire U.K.
Posted: Tue Jul 20, 2010 1:24 am Post subject: Rust in fuel tank. |
I may have rust particles in my fuel tank (twin carb engine).
I will remove sender and have a look with torch.
If so do I drain all fuel and remove tank from car?
Cheers
Jim |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Tue Jul 20, 2010 2:57 am Post subject: Re: Rust in fuel tank. |
Jim Clark wrote: |
Cheers
Jim |
I know in the UK a torch is a flashlight - correct?
Yes -- you'll need to drain the tank and remove it; send it to a radiator shop to have it boiled out... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Tue Jul 20, 2010 1:52 pm Post subject: Tank |
Hi
Yes we call a flash light a torch.
Tank is now out, is there any other way to clean the inside, it doesn't look to bad and I dont know of any rad shops to boil it.
I think I saw on here someone had used a pressure washer or a chain?
Cheers
Jim |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue Jul 20, 2010 1:58 pm Post subject: |
A piece of chain like used with swing sets. Needs some kinda sharp edges.
Put it in the tank, and shake it around. Rinse with water and repeat.
When you think it is clean, rinse with a little diesel fuel. That will keep it from rusting until you get it back in the car. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
rustyinms Samba Member
Joined: March 20, 2010 Posts: 7 Location: Tupelo, Mississippi
Bobnotch Samba Member
Posted: Tue Jul 20, 2010 8:58 pm Post subject: |
Russ Wolfe wrote: |
When you think it is clean, rinse with a little diesel fuel. That will keep it from rusting until you get it back in the car. |
The Blue Bentley recommends doing the same thing, except using soluable oil to coat the tank with after cleaning to keep it from rusting. You could always take the tank to a self serve car wash, and spray it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Jul 20, 2010 9:14 pm Post subject: |
Do not use sealers on T-3 gas tanks. There are some fine baffles in there, that the sealer will plug.
Here is a cross section of a T-3 gas tank.
Posted: Tue Jul 20, 2010 9:17 pm Post subject: |
Russ Wolfe wrote: |
There are some fine baffles in there, that the sealer will plug. |
Good to know! _________________ --------------
1963 Beetle |
Posted: Wed Jul 21, 2010 4:25 am Post subject: |
Hi Russ
I must have a F I tank as there is a return pipe next to the outlet that has been blocked off. The return pipe had a piece of hose attached with a bolt bunging the end, the pipe was solid with rust! I will bung it up properly, clean and re-install.
Cheers
Jim |
Aaron M265 Samba Member
Joined: March 31, 2008 Posts: 656 Location: Adelaide, South Australia
Posted: Wed Jul 21, 2010 6:06 am Post subject: |
I am doing this exact same thing this weekend with my Plymouth fuel tank- it's got rusty crap etc in it and has blocked up 4 x fuel filters.
Bastard thing but I got it out of the car and I will throw a chain etc inside and shake it all about (and do the hokey pokey).
I will also pressure clean it of course.
Although it's not a VW tank, similar principles apply. I will give you an update in a few days. If it still looks bad, I will discuss the problem with a friend that runs a chemical cleaning company (chemicaly dips whole cars- and in fact dipped my black panel van many years ago). _________________ Aaron
http://1500notchback.blogspot.com/
Need to contact me? Email is faster than a PM - [email protected]
For T3 Panel Van information:
http://www.thesamba.com/vw/forum/viewtopic.php?t=389465 |
71'Squareback Samba Member
Posted: Sat Jan 30, 2016 3:52 pm Post subject: Re: Rust in fuel tank. |
Whats up guys,
Im in the middle of cleaning up my fuel tank and ive read most of the posts on Fuel tanks on here. I know that you shouldnt use tank sealers in Fuel Injected type 3s because of th baffles that would get sealed. But has anyone ever used Ospho to convert the rust inside? It wouldnt seal the tank just convert the iron oxide into iron phosphate. So it will not continue to rust. I dont think this would have any ill effects on the baffle inside the FI fuel tank.... I tried doing a search for ospho to see if anyone has tried but not to many search results came out. My tank isnt too rusty. I was thinking of just throwing some in there, sloshing it around and rinsing it out with water after the chemical reaction has finished |
68vwfasty Samba Member
Joined: March 26, 2014 Posts: 277 Location: Portland, OR
Posted: Sat Jan 30, 2016 4:46 pm Post subject: Re: Rust in fuel tank. |
I used Muriatic Acid to clean and then Ospho to convert the residual surface rust.
I read many threads prior to doing mine and this was at least one of the methods described.
It has been a year and half since I did mine and no issues. Fuel filter looks brand new. I just looked in the tank today because I was replacing my sender and it looked good. |
Posted: Sat Jan 30, 2016 5:31 pm Post subject: Re: Rust in fuel tank. |
Awesome thanks 68vwfasty ive had my tank sitting with acid to get most of the rust off and im going to clean it all out tomorrow and finish it up with some ospho I just finished picking up |
Chino_UK Samba Member
Joined: January 08, 2014 Posts: 159 Location: Manchester, UK
Posted: Mon Feb 01, 2016 3:38 am Post subject: Re: Rust in fuel tank. |
I bought a bulk load of white vinegar off Ebay when I did mine, left it standing with the occasional swill around, then emptied after a week, jet washed through the holes to help any remaining gunk along then used a treatment to kill of any rust. It came up pretty clean after all that.
_________________ 1971 Iberian Red UK Type 3 Fastback
http://www.thesamba.com/vw/forum/viewtopic.php?t=584656 |
Posted: Mon Feb 01, 2016 5:29 pm Post subject: Re: Rust in fuel tank. |
Thats what I'm using to marinade the tank when i referred to "acid", gallons of vinegar picked up at BJs in bulk . Gunna use the pressure washer at my girls job after sanding down the outside to clean both the outside and inside real good before using osphos, master series silver, and black paint on it. |
joshivore Samba Member
Joined: August 12, 2013 Posts: 83 Location: United States
Posted: Thu Feb 04, 2016 5:36 pm Post subject: Re: Rust in fuel tank. |
What were the symptoms that led you to think you have rust in the tank? |
Posted: Fri Feb 05, 2016 8:23 pm Post subject: Re: Rust in fuel tank. |
Joshivore if your asking me, my car had been sitting for 2 to 3 years. I replaced the fuel filter before i got it running again. I guess the fuel filter got clogged because it was dripping out orange colored gas. So i took off the fuel sender and saw little patches of rusty areas and debries so i decided to pull out the tank to do a little cleaning. |
Posted: Fri Feb 05, 2016 8:36 pm Post subject: Re: Rust in fuel tank. |
thanks 71'Squareback. i've got some strange issues with chattery, chuggy driving intermittantly, which i (probably wrongly) think is water or crud in the bottom of my gas tank. i think it's this because it seems to happen when i'm low on gas, which makes me think it's stuff down low in there. i'm going to use your tip about vinegar to clean mine out, change the filter, and hope for the best. |
Posted: Mon Feb 08, 2016 7:19 am Post subject: Re: Rust in fuel tank. |
joshivore wrote: |
I swapped mine as it had been fitted with the wrong style tank, however, after fitting the correct, cleaned out tank and fresh filters, mine ran so much smoother. _________________ 1971 Iberian Red UK Type 3 Fastback
