intake and generator stand gaskets
Forum Index -> Performance / Engines / Transmissions Share: Facebook Twitter
bpritchert87
The Idea Man
bpritchert87 is offline
PostPosted: Tue Jul 20, 2010 6:11 am    Post subject: intake and generator stand gaskets Reply with quote
Yes! I researched....
couldn't find what im looking for...
1) THe generator stand metal gasket is to point to the "right" loovers down?? right?? ok check....
2) the intake metal gaskets are to have the ridge facing upward when installing???
3) metal or thicker fabric like intake gaskets...
4) there is too different sizes for the gen/alt stand (1) gasket that has smaller loovers and on that has larger..(was thinking of putting the smaller loover'd one in becuase i had issues when it the larger one was installed correctly..) which one!!
I ask these because after starting up my "new/rebuild" engine it only ran on the "left" side.. so we knew it was an intake leak.. (because it ran great when rev'd higher..)
and we also had lots of oil coming up from the gen/alt stand into the air cleaner.... YES THE ALT/GEN STAND GASKET WAS INSTALLED CORRECTLY!! im 100% positive (researched on here seen multiple posts about it and had my friend (30 yr vw mechanic) come over and he said it was installed correclty...
Thanks again Guys!!!
Knowledge is Power Read and Learn !!!
The Intelligence of a Man should not be measured by his age....
check out my sand rover t bug build! http://www.thesamba.com/vw/forum/viewtopic.php?t=287204
bpritchert87
The Idea Man
PostPosted: Tue Jul 20, 2010 8:03 am    Post subject: Reply with quote
im pretty sure that the ridge on the metal intake gasket goes up according to the book i have at home....
any insight?
turboblue
turboblue is offline
PostPosted: Tue Jul 20, 2010 8:09 am    Post subject: Reply with quote
Down and toward the rear.
Rear being pulley end.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=932253
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
My Website
Shop Facebook Page
bpritchert87
The Idea Man
PostPosted: Tue Jul 20, 2010 8:26 am    Post subject: Reply with quote
thanks..
seen that picture when searching... so i have it in the right postion.... what about the size of loovers??
have a couple gasket kits with 2 dif. size loovers in it..
jfats808
jfats808 is offline
PostPosted: Tue Jul 20, 2010 9:35 am    Post subject: Reply with quote
The louver size doesn't make a difference. Main thing it prevents oil from foaming or coming up the neck.
bpritchert87
The Idea Man
PostPosted: Tue Jul 20, 2010 9:42 am    Post subject: Reply with quote
im asking because i had the gasket installed correctly and i had oil still coming up the neck and into the line that goes to the air cleaner....
when i took apart everything (to fix an intake leak) and this issue i verified i had the correct direction etc... and then got out my gasket kit sets..
and bam! (2) different sized loovers same gasket both fit.. didn't know if there was a larger one or a smaller one....
figuring that a larger one would be the root of my problem..
Thanks!
bpritchert87
The Idea Man
PostPosted: Tue Jul 20, 2010 11:16 am    Post subject: Reply with quote
well im going to use the smaller loover'd gasket....
hopefully that will solve the oil blow by in air cleaner...
and i believe ridge up is the correct way to postion the intake metal gaskets...
ill be careful when installing them to torque one bolt then the other...
nice and even to get a good squish....
i also have the fabric style that i will use instead if i can find them both.... jeez where did i put the other gasket....
Thanks!! please post if you have ANYTHING to contribute...
turboblue
PostPosted: Tue Jul 20, 2010 2:14 pm    Post subject: Reply with quote
You can install them that way but louver down is the correct way.
The louver down way deflects the oil down before it ever enters the generator/alternator stand.
Gary
My Website
Shop Facebook Page
bpritchert87
The Idea Man
PostPosted: Wed Jul 21, 2010 5:24 am    Post subject: Reply with quote
yep got that... just that there is two different sized loover'd sections....
ill get a picture... i used the smaller one and put it back together and still getting some (not that much) oil squirting into the air cleaner...
Dale M.
Dale M. is offline
PostPosted: Wed Jul 21, 2010 8:35 am    Post subject: Reply with quote
Louver size will not do a thing to help your problem, if you are getting oil pushed up through breather tube its probable because of to much pressure in case maybe to much blow by at rings..... You are trying to cure a symptom and maybe not the problem....
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
mcmscott wrote:
...... and not keyboard jockeys that just have high post counts
bpritchert87
The Idea Man
PostPosted: Wed Jul 21, 2010 9:14 am    Post subject: Reply with quote
Dale M. wrote:
Louver size will not to a thing to help your problem, if you are getting oil pushed up through breather tube its probable because of to much pressure in case maybe to much blow by at rings..... You are trying to cure a symptom and maybe not the problem....
Dale
ok... Thanks ill check into the oil pressure side of your statement...
to be honest when the engine started for the first time the oil pressure gauge wasn't working..(still isn't) so i will look into getting it wired correctly and report back what i get....
i ended up going with the "felt" intake gaskets and used the smaller "looverd" gasket face down to the right...
after start up ( didnt get a chance to break it in since it wasn't running on both sides last time) i got a milkly oil mixture coming up still from the alt/gen stand... def. not as much....but still a little
seemed really hot but i haven't been around an aircooled engine that ran for quite a while.. (will get a thermometer and oil pressure gauge fixed before next start up)...
also want to note that i got a "white" smoke coming out of the exhaust after shut down and it smelled weird... i figure it might be the grease that i put on the gaskets (only a light film..)
any ideas?
[email protected]
roy@mofoco.com is offline
PostPosted: Wed Jul 21, 2010 9:54 am    Post subject: Reply with quote
The smaller the holes, the less breathing, the more oil will blow....
Reply to topic    Forum Index -> Performance / Engines / Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
