E- brakes cables
volkyrican
volkyrican is offline
PostPosted: Tue Jul 20, 2010 2:36 pm    Post subject: E- brakes cables Reply with quote
How difficult is it to install new e-brake cables on a 66 bug?
58Dub
58Dub is offline
PostPosted: Tue Jul 20, 2010 2:58 pm    Post subject: Reply with quote
Normally they are pretty straight forward. Just disconnect both ends, and pull them out. Feed the new ones in....connect and adjust.
58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project
drscope
drscope is offline
PostPosted: Tue Jul 20, 2010 3:10 pm    Post subject: Reply with quote
I find it's easier if I take the seats out.
61SNRF
61SNRF is offline
PostPosted: Tue Jul 20, 2010 5:58 pm    Post subject: Re: E- brakes cables Reply with quote
How big is a rock?
Seriously though....
You have to remove and install the rear drums, for some this is difficult.
Where the cable clamp enters the backing plate it's like a chinese puzzle, only fits one way but finding the sweet spot can be agravating.
Like Doc said, take the seats out for sure.
Taking the handle out makes it easier too.
Make sure to match the old and new to be sure you've gotten the right ones.
Grease the S out of them as you feed them in.
Adjust brakes first then adjust handle for 4-5 clicks.
Be prepared to re-adjust them too because they will stretch a little when they are used for a while.
delliott101
delliott101 is offline
PostPosted: Wed Jul 21, 2010 7:57 am    Post subject: Reply with quote
I had to do this when I was revamping my Bug when I first got it... It was a bit of a chore, but the chore was running the cable into the drum correctly. Leave one side connected so you can see how it connects.
I was able to do it without any prior knowledge of how to replace them, so it isn't too bad!
Like 61SNRF said, take the e-brake handle out first... it will make it easier!
Transplanted Jersey Boy living in Idaho by way of Northern California!
We don't own old VWs, we just take care of them for the next driver
jettaway03
jettaway03 is offline
PostPosted: Wed Jul 21, 2010 7:39 pm    Post subject: Reply with quote
It's not bad. Make sure you have the correct length cable. I had posted a picture a few weeks back it you need a visual of how it looks installed.
Copyright © 1996-2015, Everett Barnes. All Rights Reserved.
