1975 Kombi Samba Member
Joined: August 12, 2007 Posts: 2452 Location: Acton, Ontario, Canada
Posted: Wed Jul 21, 2010 7:14 am Post subject: Had an odd brake issue but solved - Just info |
I had a front brake caliper hanging up on me. The rim was hot every time I came back from a trip. So I started tracing the problem. First the caliper bleeder was loosened and brake fluid shot out and released the caliper which moves freely when the pushing the cup while bleeder open. If the bleeder is closed it will not release the brake. I took apart the caliper and replaced - same thing. I replaced the caliper - same thing. OK not the caliper. Onto the the master and decided to reverse the lines just to see if there was any change in the behavior. Seemed to bleed ok and and tried it a bunch of times. So I went to the local shop and the first thing out of his mouth was rubber flex line. Apparently there has been a rash of inner rubber failure on rubber flex lines in the last few years. So changed up the relatively good looking flex line at least from the outside and sure enough the hang up disappeared. From what I gathered from the shop guy is that the inner portion of the hose cracks and flaps down to block off the fluid from returning. It starts to work as a one way check valve. _________________ Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jul 21, 2010 7:24 am Post subject: Re: Had an odd brake issue but solved - Just info |
1975 Kombi wrote: |
So changed up the relatively good looking flex line at least from the outside ......... |
I hope that was a new line you replaced it with, any plans on doing all of them soon? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
71whitewesty Samba Member
Joined: February 25, 2010 Posts: 1544 Location: oregon
Posted: Wed Jul 21, 2010 7:47 am Post subject: |
I just had the exact same experience. Replaced both front calipers and it ended up being the rubber hoses. You can also isolate that part by cracking the break line at the top of the rubber hose and see if it releases the caliper and if not try cracking the break line below the rubber hose. If it then releases, it's the rubber hose. Oh well, replacing the calipers too probably wasn't a bad idea. |
