GARRICKCLARK Samba Member
Posted: Tue Jul 27, 2010 1:47 pm Post subject: Alloy wheel narrowing |
Hi guys.
Just a quick question for ya.
I have just fitted a 2 inch narrowed beam to my bug and have a set of eagle 520 rims that i want to use .
My question is, is it possible to narrow these wheels by a couple of inches so i can get my steering to have the same turning circle,and also as i think it would look kinda cool also.
Is it a big job and would it be expensive.
Thanks |
envycustoms Samba Member
Joined: June 20, 2006 Posts: 324 Location: Oakland - Nor*Cal
Posted: Tue Jul 27, 2010 3:14 pm Post subject: |
With the right amount of MONEY.. anything can be done.. finding a machine shop in your area that will do the job for you will be the though part.. keep in mind that the section you plan to narrow should be the same diameter on both ends, or else you will not be able to mate the two sections back together  _________________ 56 SunRoof (o\U!U/o) "Hood Fellas"
Damn.. not another car on earlies!
www.EnvyCustoms.Tumblr.com |
RafCarre12 Samba Member
Joined: January 06, 2008 Posts: 993 Location: Glen Rock, NJ
Bruce Samba Member
Posted: Tue Jul 27, 2010 11:08 pm Post subject: |
Post a pic of your wheel's drop center (without a tyre on it). _________________
| Glenn wrote: | | ..... and like them better than Bosch. |
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 990 Location: Henderson Nevada
Posted: Wed Jul 28, 2010 3:43 pm Post subject: |
To narrow a rim is easier than widening just due to the simple fact of less machining and welding. The only problems I have had is the quality of the metal cast vs. forged. Forged is like welding billet it has less impurities and is stronger.
But like the post above its all about the money. I like the Weldcraft sight they say they Tig weld the wheels but the welds look more like they were welded with a spool gun. |
Bruce Samba Member
Posted: Wed Jul 28, 2010 11:35 pm Post subject: |
| flyinglow94 wrote: | | To narrow a rim is easier than widening just due to the simple fact of less machining and welding. | However, not all wheels can be narrowed. If the drop center has a taper to it, you can't narrow it. _________________
Posted: Thu Jul 29, 2010 10:47 am Post subject: |
Thanks for all the input guys .
1st thing i will do is get the tyres off and look for a taper.
Also i was wondering what 4 lug alloy rims were the lightest.
Not sure what these eagle 520's weigh. |
grifspop Samba Member
Joined: May 16, 2007 Posts: 105 Location: Someplace you wouldn't think to look
aka pip Samba Member
Joined: September 15, 2004 Posts: 1930 Location: LongBeach Fool
Posted: Sat Jul 31, 2010 11:53 pm Post subject: |
| GARRICKCLARK wrote: | Thanks for all the input guys .
You can narrow a mismatch and a taper rim.. You just need to know what your doing.... _________________ http://www.dbkvw.com/ |
iain2503 Samba Member
Joined: December 08, 2008 Posts: 27 Location: New Zealand
Posted: Sun Aug 01, 2010 10:17 pm Post subject: |
Loving the narrow 17's I want to do it to a set of 17 BRM's but the transport authority here don't allow it  |
Posted: Sun Aug 01, 2010 10:45 pm Post subject: |
| iain2503 wrote: | Loving the narrow 17's I want to do it to a set of 17 BRM's but the transport authority here don't allow it  |
Posted: Mon Aug 02, 2010 12:39 am Post subject: |
| Yip your work there is why I want some, they look mean. What is the cost of doing that if you dont mind me asking? |
chickengeorge Samba Ricer
Joined: August 18, 2004 Posts: 5286 Location: Spokane Warshington
Posted: Mon Aug 02, 2010 7:15 am Post subject: |
| And what size tire? |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 283 Location: North Carolina
Posted: Fri Dec 03, 2010 11:07 am Post subject: |
| Does anyone know of a shop on the east coast capable of narrowing an aluminum alloy wheel? I would like to have a Porsche 19"x8" or 18"x8" alloy narrowed to 7" for the front of my germanlook dub. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 12426 Location: Eugene, OR
Posted: Fri Dec 03, 2010 11:39 am Post subject: |
I'd narrow them to 5-6" to make them fit/lower/turn/not rub on the front. _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500 |
VeeDubDoug  The veedub thug!
Joined: August 27, 2008 Posts: 1412 Location: The Gutter, SoCal
Posted: Fri Dec 03, 2010 12:04 pm Post subject: |
| chickengeorge wrote: | | And what size tire? |
Ditto, and how narrow can you go with those 17" 205mm BRM's? Does anyone make 17x5" tires... for cars? _________________ Westküste
'66 Bug "Charlotte"
What's it to you...friendo? |
Typ3nut Samba Member
Joined: October 08, 2002 Posts: 395 Location: MI, MotorCity ManCave
Posted: Fri Dec 03, 2010 12:20 pm Post subject: Weldcraft Wheels |
[quote="RafCarre12"]Some info here:
http://www.weldcraftwheels.com/index-2.html[/quote]
Weldcraft is a Top Notch Company, I live in the area and have seen many a Custom Modified of various type Wheels done by them. Everyone has had Great comments about there Quality Work.
I'm in the process of having a set of wheels offset changed by them.
As mentioned, with the $$$ about anything can be done. |
Posted: Fri Dec 03, 2010 1:18 pm Post subject: |
| Mike Fisher wrote: | | I'd narrow them to 5-6" to make them fit/lower/turn/not rub on the front. |
My fenders are steel that have been widened 1" and I have a 2" narrow beam. My last set of wheels were 18x8" front and 9.5" rear. The fronts were a little tight regarding full turn. Those wheels were put on my wife's widebody speedster replica which has since been sold.
A 18" x7" front would be perfect. The narrowest late model 18" Porsche alloy is 7.5" for the Boxster which I may go with. The wheel I actually prefer comes in 19x8" front and 9.5" rear. |
rustin peace Samba Member
Posted: Sat Dec 18, 2010 1:44 pm Post subject: |
The Mahle 1.8 wheel from a 914 is the lightest that i have weighed.
the 520s should weight in at about 18-19 lbs _________________ If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat!
July 1952 Deluxe Hard Top Bug |
Matthew Tolbert Samba Member
Posted: Tue Jan 04, 2011 11:33 pm Post subject: |
Pip who does the narrowing for you? and what are the widths of the front and rears on the notch? _________________ Matthew Tolbert
53 L35 metallic blue oval
65 Notchback S would like to trade for 65 or earlier doublecab
Looking for one of the following
58 ragtop
58 convertible
59-65 doublecab
53 oval project
http://www.thesamba.com/vw/forum/viewtopic.php?p=6313249#6313249 |
