wythac Samba Member
Posted: Sat Nov 06, 2010 9:57 am Post subject: |
Having indulged in some of those sorts of diversions you describe during my builds, I think I might be able to answer that;
Sometimes I didnt feel like taking on a big project, or wanted to see something done that would provide some immediate gratification. I would pick some little BS thing that I could see completed in a few hours.
Another thing I would do is spend some time assembling things that I knew would have to be disassembled before final install. In many instances during the mockup process, I just wanted to see if something was going to look as I envisioned. Other times, I just wanted a taste of what the completed car was going to look like, and I would spend a few hours working again on stuff I knew was, in the grand scheme of things, a waste of time. One thing these sort of diversions did provide was inspiration to continue, a whetting of the appetite for getting the car done. |
gr8cobbler Samba Member
Joined: May 04, 2006 Posts: 740 Location: Midlife Crisis, Midwest
Posted: Sat Nov 06, 2010 10:22 am Post subject: |
Well said Wythac, The big jobs need significant time commitments, the wife & kids, and job make those chunks of time pretty hard to find, at least for me. Most of my build time is comprised of 15 minute bursts unfortunately. I don't want to screw up an engine rebuild by not being able to focus uninterupted and do it right the first time.
Being able to complete any part or aspect keeps the momentum, small though it is, going in the right direction. On a build like this one I imagine there are many problems that take some real head scratching and if allowed to cook over time produce better answers. A side project, spare tire mount with matching lug wrench, is low stakes progress during the mental simmering time for the major problems.
I think JSB's point is also understandable and I wish my life afforded me the ability to keep the horse in front of the cart all the time.  _________________ Gary
Being a cheap old fart is just a front for my actual lack of money.  |
jspbtown Samba Member
Posted: Sat Nov 06, 2010 2:14 pm Post subject: |
gr8cobbler & wythac:
Interesting perspectives...thanks.
Maybe I should try that on the Avenger. I even chose cutting back all the dead plants and mulching leaves today instead of sanding primer. I did get the inspiration to apply the guide coat....not much of a project...but maybe I will assign it into one of those "inspirational diversions" tasks.
Who knows...maybe I will feel like sanding all day Sunday!
Thanks guys. |
dsmbuggy Samba Member
Posted: Sat Nov 06, 2010 3:53 pm Post subject: |
For me it is more important to do little things than not doing anything on the project.
There is so many little things to do.
when they are done I cross them off my list and move to the next.
I sometime need those instant gratification one hour jobs to keep me going when motivation is low.
Don't worry I get back to bigger stuff soon. _________________ New ideas do not scare me, old ones do.
Thanks: TANGO, MATTY, JE, MEMER.
http://www.1aauto.com/blog// |
GS guy Samba Member
Joined: December 03, 2007 Posts: 450 Location: Maryland
Posted: Sat Nov 06, 2010 6:50 pm Post subject: |
I find that it's largely a matter of "this needs to be fleshed out before I can fit that". For instance I was recently working on "tabbing out" the rear of my chassis to mount engine wiring. Sounds simple enough? But found I needed to complete the engine wiring harness to figure out where the tabs needed to be. That wasn't so simple! But once the wiring was in place and hooked up (not insignificant on an EFI/turbo motor!) I could find perfect placement on the tabs.
Then there's the other ideas that pop up when you're working on something else - and realizing that if you're going to follow through on that idea - it needs to be done now rather than later. At least that's what I run across.
Even small or relatively simple accomplishments bring a lot of satisfaction! _________________ 70's vintage Deserter GS buggy - undergoing transformation to Super GS! |
Raketemensch Samba Member
Posted: Tue Nov 23, 2010 7:15 pm Post subject: |
Just gotta say.... I had kicked the Samba habit, I hadn't logged on for almost two months, until this afternoon when your build jumped into my head.
I love this thing, and it's good to see all the progress you've made. |
superman73 Samba Member
Joined: December 21, 2006 Posts: 1967 Location: Crystal Springs, Mississippi
Azsilverbug Samba Member
Joined: August 08, 2007 Posts: 283 Location: Tucson, AZ
Posted: Sat Dec 18, 2010 10:10 pm Post subject: |
I like it. _________________ You can tune a piano,but you can't Tuna Fish
1962 Bug
1968 Bug
1976 Bug
Manx clone on 65 pan |
Posted: Sun Dec 19, 2010 7:49 am Post subject: |
Sorry for the lack of updates.
The last couple of month I focused on getting the car started again.
That means redo the fuel system, coolant lines to the back, and water to air intercooler system.
Bosh 044 fuel pump, big filters and AN8 braided lines.
The mounting straps for the 12 gallons aluminum fuel tank and the fuel pump wiring underneath the tank. (notice the cooling Jug for the beer)
I actually use the cooler as an ice chest for the water to air intercooler.
I also received my new turbo: Forced performance DSM 82 HTA.
Should be good for around 700hp.
With this I ordered this beautifully crafted JMF drag manifold.
This thing is a beast.
The engine bay coming along.
Notice the waste gate dump BOSOZOOKU STYLE
The office.
My friend Tango also started the fab of the aluminum sides.
His fab table.
Complex shapes.
The front half in place.
The complete side pods.
That is all for now. _________________ New ideas do not scare me, old ones do.
EODinert Samba Member
Posted: Fri Dec 24, 2010 8:51 pm Post subject: |
This car is so bad-ass. _________________ '61 rag top beetle, '73 type 181, '66 13 window deluxe |
portlyparatroop Samba Member
Posted: Thu Jan 13, 2011 8:19 pm Post subject: |
whew.... what an inspiring 10 page read! (nice to see someone else thinking outside the box)
*also* glad to see you plan on helping that little 4G63 a bit... think they were only around 190hp. stock - KEEP AFTER IT (wish I was closer to help) |
OutCasted Samba Member
Joined: November 06, 2010 Posts: 133 Location: Southgate,Mi
Posted: Thu Jan 27, 2011 8:24 pm Post subject: |
| superman73 wrote: | | any progress? |
X2 |
Posted: Sat Jan 29, 2011 2:13 am Post subject: |
Wiring.....wiring..... cables.... relays..... switches....more wiring...
It is cold in here (28º in the garage) _________________ New ideas do not scare me, old ones do.
adriaan pienaar Samba Member
Joined: February 17, 2003 Posts: 649 Location: George, South Africa
Posted: Sun Jan 30, 2011 7:20 am Post subject: |
28º Fahrenheit.
I was getting bored with wiring so I decided to build the member brace.
The front subframe on DSM is prone to crack when removing some of the engine bay OE bracing.
I decided to build this brace because I remove quiet a lot of material up front.
I used part of the existing braces for mounting points but my brace connects the A arms mounting points.
I used square tubes but skinned them to avoid flexing.
I love my flaring dies.
All tack welded.
fully welded and painted.
TC/TeamEvil Samba Member
Posted: Sun Jan 30, 2011 9:14 am Post subject: |
| OK . . . . where'd you get those cool flairing dies ? |
Posted: Thu Mar 31, 2011 12:51 am Post subject: |
This thread seriously needs an update...with lots of pics, please. _________________ '61 rag top beetle, '73 type 181, '66 13 window deluxe |
