FuzzyVan81 Samba Member
Joined: October 09, 2013 Posts: 5 Location: Santa Cruz
Posted: Wed Oct 09, 2013 4:01 pm Post subject: 1981 Vanagon loss of power and over heating |
Hello everyone! As I've been restoring my 1981 Vanagon Westy for the last 8 months I've referenced The Samba many times so let me start by saying thank you
The question at hand is this, I bought the Vanagon after it sat, not running, for about 8 years. After changing the fuel lines, flushing the fuel system, replacing filters, lubing the cylinders, new spark plugs, hand cranking the engine, and starting it up it ran after three tries!!! I was really surprised and happy at the time.
Since then I've adjusted the valves, changed the oil cooler seals (what a pain), replaced the valve cover seals, and replaced the oil a couple times with high quality oil and so far no major leaks and the engine runs really well... for about 10 mins. Once it gets to about 180 degrees, it starts to loose power and once it hits about 200 plus degrees I might as well get out and start pushing.
My speculation is there's a cracked cylinder, leaking compression, that opens up as the metal gets hot, but what are your thoughts?
On a side note, the exhaust has holes after the Cat and I have one or two pieces of tin missing from under each cylinder head (would that effect the heat that much though?). It passed smog and seems to idle great.
Thanks everyone! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32602 Location: Reading Pennsylvania
Microbusdeluxe Samba Member
Joined: July 26, 2003 Posts: 980 Location: Bellingham, WA
Posted: Wed Oct 09, 2013 5:40 pm Post subject: |
Replace that tin!! Once you get this to run after it's warmed up you will fry the motor if you have missing tin. Try the classifieds & local junk yards. _________________ '69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig! |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Wed Oct 09, 2013 7:15 pm Post subject: |
Microbusdeluxe wrote: |
Replace that tin!! Once you get this to run after it's warmed up you will fry the motor if you have missing tin. Try the classifieds & local junk yards. |
Oh yes....replace that tin as soon as possible. Try Avery's Air Cooled out of Washington. They post here in the classified section and my experience with them is 100% positive. Good prices and fast shipping and good VW folks to boot. |
Posted: Wed Oct 09, 2013 7:36 pm Post subject: |
Have your checked the resistance of your TSII sensor? If it is shot, isn't grounded well, or the wire that connects it to the ECU is bad your engine will barely after it warms up, that is if it will run at all. |
Posted: Thu Oct 17, 2013 1:57 pm Post subject: Replaced tin and still overheating, whats the next step? |
So I replaced the tin and it's still overheating. I haven't tried removing the Cat yet because I don't know what to put in place of it (just a standard pipe, or exhaust pipe?).
I'm not sure what the TSII Sensor is either.
Any comments on doing those two things? Thanks again everyone! |
Posted: Thu Oct 17, 2013 2:18 pm Post subject: |
TSII=Temperature Sensor #2
It should be located in the left head just in front of where the manifold bolts down. When it or the wires to it fail it causes the ECU to hold the injectors open way too long flooding the engine out. The Bentley tells how to test it and what the correct specs are. |
midmo81 Samba Member
Joined: September 23, 2012 Posts: 114 Location: Columbia, Missouri
Posted: Thu Oct 17, 2013 5:37 pm Post subject: |
Just to review aircooled 101.
Upper tin and seals forms the box the fan draws cool air in from the side pillars. Lower tin forms the box the fan pushed the cool air over the hot cylinders along one side around the back and along the other side and down through the oil cooler.
This picture is not my engine but marked up for illustration. Note the edge seal and the heater tube being critical.
_________________ 1981 AC Westy |
Posted: Mon Nov 25, 2013 1:34 pm Post subject: Over heating fixed... sort of |
So I took it to my local shop (Old Volks Home, Santa Cruz) and they determined the main issue as a broken distributor. The part that's supposed to advance as the engine heats up and rpm's increase/decrease was broken. They rebuilt it and it runs waaaaayyyyyy better, maintains power at higher temps, and runs much cooler... However, it still gets to about 240.
So I installed an external oil cooler under the driver side rear wheel well with a fan, helped a lot, and now, on a cool day, it runs pretty consistent at 212 - 220.
With the oil cooler, is that going to be good enough on a hot summer day? Do those temps seem within the normal range?
Thanks again to anyone that can help! |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Mon Nov 25, 2013 1:42 pm Post subject: |
Your oil temps are fine, you need to worry about Cylinder head temperature.
That's a engine killer.
Never above 400 or you'll start dropping valve seats.
Put in a NEW stock oil cooler and it'll drop the oil temps. |
Posted: Mon Nov 25, 2013 2:06 pm Post subject: |
mightyart wrote: |
So how would I measure the head temp? I believe the after market temp gauge mounted on my dash is connected to the bottom of the engine (which I read was the most accurate place to measure temp). If I'm not mistaken, there are two head temp sensors, one located near cylinder 3 and one on the opposite side. They look like little silver bolts with a black wire coming out of them?
Do I need a separate after market gauge for that also? If so, any suggestions. Thanks again! |
Randy in Maine Samba Member
Posted: Mon Nov 25, 2013 2:14 pm Post subject: |
This is the one we use as it is the best one for monitoring CHTs.....
http://www.dakotadigital.com/index.cfm/page/ptype=...prd347.htm
buy the 18' long sender for 14mm plugs. It mounts around the spark plug.
The Temp Sensor 2 over my #3 cylinder is to allow the ECU to know what temperature the engine is to allow for the ECU to adjust the air:fuel mixture in order to lean out the mix as the engine temp goes up. |
Posted: Mon Nov 25, 2013 2:18 pm Post subject: |
You have the correct setup for oil temp.
In an air cooled vanagon the head temp is critical.
There is allot of debate as to the correct temp guage to use.
I just have the standard VDO CHT guage. it's sender is on #3 spark plug. not in the holes on the head.
Read more about CHT guages here:
http://ratwell.com/technical/VDOGauges.html#cht |
Posted: Sun Dec 15, 2013 11:57 am Post subject: CHT above 400 degrees |
After temporarily installing a VDO CHT gauge and driving it up a 15 mile incline (Hwy 17 in Santa Cruz) the oil temp stayed consistent at about 215 and the CHT went from about 350 at idle/start of climb to about 450/475 during the climb.
I've heard the VDO gauges are inaccurate and my engine seems fine and seemed good on the climb (gauge was returned). I'll probably get a more accurate one listed in this stream, but my question is that it's stated the normal CHT should be about 350-375 on an air cooled engine and it's also stated that going above 400 degrees is an engine killer, so there's only 25-50 degrees of wiggle room? That seems to small of a range based on my test (CHT rose pretty fast).
What is a dangerous CHT for my 1981 air cooled Vanagon? Thanks everyone! |
a1fa Samba Member
Joined: September 25, 2011 Posts: 585 Location: Central Arkansas, United States
Posted: Sun Dec 15, 2013 1:41 pm Post subject: |
Someone said 450-475 is dangerously high.... May want to ask in aircooled specialty forums such as Colin's IAC in Type2 forum or shoptalkforums.
IAC for stock stuff..
shoptalkforums for some crazy turbocharged stuff _________________ Learn to ride. Ride to learn. |
wolfej1 Samba Member
Joined: August 15, 2005 Posts: 679 Location: North Royalton, Ohio
Posted: Sun Dec 15, 2013 3:10 pm Post subject: Re: CHT above 400 degrees |
FuzzyVan81 wrote: |
I have tried everything under the sun to try and get my 82 Westy to run at 350-375 degrees on the CHT. The only way I can accomplish that is if I drive 54 mph and the road is completely flat. My van is in good tune, has good compression idles, at 17inches , and runs good. However, as soon as I get over 60 mph I am at 400 on the CHT and usually gets up to 430 or so if I am cruising at 65 or so.
That being said I have never got mine up past 440-450 and that was trying to do it by hammering it and trying to see how hot it would get.
Take that for what it is worth - which is probably a pinch of owl dung coming from me.
curious to know how things progress for you
_________________ 1982 Westy
2004 KDX200
2008 Kawasaki KLR 650
1979 Yamaha DT 175
1995 Toyota 4Runner |
a1fa Samba Member
Posted: Sun Dec 15, 2013 9:07 pm Post subject: |
I need to check on my CHT with microsquirt and very crazy timing... _________________ Learn to ride. Ride to learn. |
