gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1112 Location: San Carlos, CA
Posted: Mon Apr 30, 2012 7:25 am Post subject: |
 _________________ My dog's vet has all my car money (http://sagecenters.com/) |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2190 Location: preskitt az
Posted: Mon Apr 30, 2012 8:20 am Post subject: |
WOW those are a piece of art _________________ (o\!/o)
58' pg/sg sub hatch westy
90' doka 1.6td jx import from germany |
grueni Samba Member
Joined: November 03, 2008 Posts: 547 Location: Germany
Posted: Mon Apr 30, 2012 9:45 am Post subject: |
looks very nice specially the rockers itselfe.
pricing for 1,4:1 ? _________________ 1956 oval 1192cc 36hp Supercharged 70HP at 3900RPM / 150NM at 2000RPM @ 13 psi
1960 1641cc Twin scroll turbocharged, intercooled @17 psi 318nm/3430rpm 160hp/4790rpm
with cb2280 cheater cam 222°@ 0.05" |
gt78 Samba Member
Joined: November 21, 2009 Posts: 49 Location: Pori, Finland, Europe
Posted: Mon Apr 30, 2012 10:54 am Post subject: |
Yeah saw those in the UK and thought to myself thats it!
And they were cheap too, under 350$ pair?! |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5817 Location: back to living where hell meets the suface
Posted: Wed May 02, 2012 7:01 am Post subject: |
 _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
leeezard7 Samba Member
Joined: November 13, 2011 Posts: 262 Location: oklahoma
Posted: Wed May 02, 2012 7:53 am Post subject: |
| very nice looking assembly. im sure they are fine, but the offset shaft concerns me a bit. i understand why they did it. but still a quality looking part. |
Posted: Wed May 02, 2012 9:11 am Post subject: |
Hello-
| Quote: | | The offset shaft concerns me a bit. |
I have to admit I have the same concern. More specifically, I'm wondering if I took the money it would cost to install these ratio rockers, and put it into head porting, could I achieve the same results? Hmmmm.
Cheers,
Paul _________________ My dog's vet has all my car money (http://sagecenters.com/) |
Tom Simon Samba Member
Joined: August 10, 2009 Posts: 405 Location: Napa, CA
Posted: Wed May 02, 2012 10:06 am Post subject: |
Sweet!!!
what ratios are they available in?
what is the retail price?
I'm not worried about the offset shaft for one simple fact: Put enough valve spring on a 36hp enigine to break those shafts, and you'll wipe out the cam and lifters, first
Bonneville Tom made a set of offset shafts very similar to these several years ago, has run them with very good luck. Maybe he will chime in. |
Posted: Wed May 02, 2012 10:13 am Post subject: |
| gimmesomeshelter wrote: | Hello-
Cheers,
Paul |
Tom Bruche ran the same style on his bonneville car with 0 issues, I have them on one of my engines, no problem so far and I have some pretty heavy spring pressures.
Just an easier way to get some more poop from your 36 hp engine with-out splitting the cases to put a bigger came in _________________ Stocking distributor of "The Funky Green Panels"
Posted: Wed May 02, 2012 12:53 pm Post subject: |
| PLZ DONT MISINTERPRET MY EARLIER REPLY... THEY DO LOOK LIKE A QUALITY PRODUCT. |
Posted: Wed May 02, 2012 3:28 pm Post subject: |
Cheers,
Paul |
You could try... but at some point, you will want to increase lift of those valves to take advantage of a better port. With cam lobe height being limited by the 36hp lifter design and lack of available cam blanks... |
Posted: Wed May 02, 2012 6:36 pm Post subject: |
| Tom Simon wrote: | | gimmesomeshelter wrote: | Hello-
Cheers,
Paul |
machine case for cam bearings, machine the lifter bores in the case to accept the 356 lifters in a straight shot instead of angled like they are, then run custom .080 cromoly 1pc pushrods, then weld up the cylinder stud holes in the case and machine case to accept 90.5 p/c's, porsche rods have 22mm wrist pins , use type 1 heads and rockers... oh sorry got carried away didnt i...lol.  |
grueni Samba Member
Posted: Thu May 03, 2012 1:04 am Post subject: |
| leeezard7 wrote: | | Tom Simon wrote: | | gimmesomeshelter wrote: | Hello-
Cheers,
Paul |
type 1 heads will not fit (other hole pattern), try to weld that old aloycase good luck but for sure you can use a pre 50 case
and why all the work on the case for the lifters. i had a rev limiter at 7800 rpm because my engine wanted more on a 36hp.....there are different ways easyer and cheaper to make a engine breath. had 12,x mm valvelift a lighter valvetrain as every formulaV engine and this out of stock parts with just some tricks and porsche 1,3:1 rockers. and drove it 1000km+ autobahn, berlin city +++ and the cam and lifters and all the other stuff is in perfekt shape like on the first day.
the speedwell rockers are a good part. the price is still interesting for me. 1.6:1 would be nice too. but 1.4 is for the raver a very good deal. i had 1.35:1 ratio with the porschelifters but hte time and coast was huge. cost about 250 euros but machining time and searchtime amazing high.
so what is the price for a set of 1.4:1 ??? _________________ 1956 oval 1192cc 36hp Supercharged 70HP at 3900RPM / 150NM at 2000RPM @ 13 psi
Posted: Thu May 03, 2012 9:39 am Post subject: |
hey gruni, how have you been? when i said weld up the cylinder stud holes in the case i was refering to redrill them in the type 1 pattern so you could use type 1 heads. if you do that you open up worlds of possibilities with a 36hp case. use a offset ground 76mm or 77mm crank, 90.5 p/c's, and you have a 2liter plus sized 36hp motor... again i talk about and do these things because i can not because i should or shouldnt happy motoring |
grueni Samba Member
Posted: Thu May 03, 2012 10:11 am Post subject: |
| leeezard7 wrote: | hey gruni, how have you been? when i said weld up the cylinder stud holes in the case i was refering to redrill them in the type 1 pattern so you could use type 1 heads. if you do that you open up worlds of possibilities with a 36hp case. use a offset ground 76mm or 77mm crank, 90.5 p/c's, and you have a 2liter plus sized 36hp motor... again i talk about and do these things because i can not because i should or shouldnt happy motoring |
the stud holes is one thing the cyinder holes another thing typ1 is wider. but you could use superexpensive porsche 356 heads after redrilling them to porsche 356 because they are the same.
with 1.4 -1.6 :1 rockers a 77 or 78 mm crank could be make sense.
if you have the money the physics and are your only limit.
you can't change the point between one rod and another so you have to keep the hole pattern of the cylinders. and cut the cylinders is also not good. but plit ports hardly changed could work if you do a new rockerdesign. that is same work than do new billet 36hp heads.
here is a link to the motor you wish to have:
http://www.rs-motor.at/
they have a billet 356 head. with 48/xx valves 1,6:1 rockers and build for 90.5 cylinders...its about 3500 euro if i am right.
contackt them.
use a alloy case up to '50 redesign it for 90.5mm pistons
use a 78.4 porsche 356 crank (saw last year on maikäfertreffen one)
and you have a high potential preA looking porschemotor based on a vw bug case.
btw i have a project laying around that open limits like typ1 and its pure vintage stuff. _________________ 1956 oval 1192cc 36hp Supercharged 70HP at 3900RPM / 150NM at 2000RPM @ 13 psi
Posted: Thu May 03, 2012 12:30 pm Post subject: |
| thank you for the great info gruni. the motor i am talking about is just in planning stages right now. i absolutely dont have any parts or have tried anything yet. it is just in my mind so far. your info is greatly informadable and appreciated as is anyone elses info on the subject. i have been looking for a pre 50 case tho. happy motoring |
Posted: Thu May 03, 2012 12:34 pm Post subject: |
| ps... i dont mean to hijack this thread either... back to business of the aforementioined rockers... happy motoring to all |
phil1957 Samba Member
Joined: July 10, 2006 Posts: 215 Location: montreal, Quebec
Posted: Mon May 07, 2012 1:49 pm Post subject: |
| so were can i get a set of these ? |
slalombuggy Samba Member
Joined: July 17, 2010 Posts: 3717 Location: Canada 306
Posted: Tue May 15, 2012 9:25 am Post subject: |
What's the word Ronnie. any news on the rockers yet. We're diein' for a set of 1.4's when they come in.
brad _________________ BB Buggy 121.253mph @ Bonneville 2012
http://www.youtube.com/watch?v=57hMyJmIU10
Raisin cookies that look like chocolate chip cookies are the main reason I have trust issues |
Posted: Tue May 15, 2012 11:23 am Post subject: |
| slalombuggy wrote: | What's the word Ronnie. any news on the rockers yet. We're diein' for a set of 1.4's when they come in.
brad |
Talked to Ray yesterday, they are almost ready _________________ Stocking distributor of "The Funky Green Panels"
