woofer Samba Member
Joined: September 18, 2008 Posts: 26 Location: Suffolk England
Posted: Tue Aug 24, 2010 1:29 pm Post subject: T4 Eurovan chassis number |
Hi i have just brought a 1994 T4 transporter eurovan westfalia that went from germany to canada and then onto japan. possibly owned by a serviceman do you think? anyway it was imported into the uk in 2007 but it seems to have 2 chassis numbers? there is the vw (germany) number stamped onto the panel below the front screen (as has my t4 crewcab), but then on the drivers side b post there is a canadian vehicle id sticker with some weight details plus the chassis no: almost identical to the proper one but the zeds are replaced with other letters.
WV2ZZZ70ZRH****** is the vw one
WV2PD0707RH****** is the canadian one
why is this does anybody know?? |
Mzwo Samba Member
Joined: November 11, 2009 Posts: 195 Location: Vienna, Austria
Posted: Wed Aug 25, 2010 4:09 am Post subject: |
| cut 'n' shunt? |
woofer Samba Member
Posted: Wed Aug 25, 2010 12:24 pm Post subject: |
| no, got fsh, never welded no rust vin number clearly stamped on panel where it should be, just this sticker on b panel which looks like the sort of conformity sticker you get in california, but its canadian. the * at the end represent numbers which are the same on both accounts....come on you canadians someone must have an idea |
snowsyncro Samba Member
Joined: January 11, 2009 Posts: 934 Location: East Preston, Nova Scotia, Canada
Posted: Wed Aug 25, 2010 1:40 pm Post subject: |
Zs are used as a filler character; sometimes they have meaning but most times they do not. The only legit example I have seen is the 4th digit in the 83-92 Vanagon (T3) where a value of Z means a camper. I think a lot (all?) German T3s have a "Z" as digits 3, 4, and 5. I have a German T3 here that does( it is not a camper,( and the ones I have seen on eBay did as well, I think. I don't have much experience with that.
The German VIN on your T4 decodes as:
W = Europe
V = Volkswagen
2 = multi-purpose vehicle
Z = 4th digit, vehicle series, no meaning for T4 H = Eurovan CL, K = GL
Z = 5th digit, engine, no meaning
Z = 6th digit, restraint system, no meaning
70 = model = Eurovan (T4)
Z = 9th digit, filler, no meaning
R = year, 1994
H = assembly plant = Hanover
The Canadian VIN decodes as:
WV2 = same as above
P = nonsense to me, means a 4-door base Jetta I think
D = petrol engine of some description
0 = active restraint system (manual seatbelts)
I have a 1994 T4 here, and the values for those 3 digits are (not a camper though)
4th digit = K = Eurovan GL
5th digit = E = highest power petrol engine
6th digit = 0, as for yours
I have a 92 and 95, they agree except on one the engine code is C
The P could mean a T4 camper, but I have not seen this before. I have a 97 T4 Transporter, series code is 1=pickup/truck, and body style is E = 2-door, and engine code is G = diesel.
I have a 1990 T3 camper, built in Germany and delivered in Luxembourg for a Canadian serviceman, then brought to Canada. It has a proper Canadian VIN, body style is "Z" = camper in this case, engine is "B" (petrol), restraint is "0". The conformance sticker on the B pillar matches the VIN plate on the dash.
I have a 1985 T3, German vehicle later imported to Canada. There is no VIN plate on the dash, and no Canadian conformance sticker.
All the Canadian vans have a conformance sticker on the B pillar, with a matching VIN. This is not something that is just done for imported vehicles -- it is on all Canadian-delivered vehicles as well.
Hope this helps,
RonC |
woofer Samba Member
Posted: Fri Aug 27, 2010 4:17 am Post subject: |
thanks for your help RonC, that was more constructive  |
kdane2 Samba Member
Posted: Wed Sep 19, 2012 8:04 pm Post subject: This might be helpful. |
http://www.thedieselgarage.com/projects/VW/VWvin.pdf
I have a problem with my 1993 GL T4, the car insurance computers, and this has happened twice now, say my vin doesn't exist. The difference is this for mine, WV2KD0701PH064173 is my VIN, if you change the D to a C it comes up, all it is is a different engine but it says its the same engine on that vin link (displacement and HP). But my engine doesn't have EGR, so I was told it's Canadian. Any thoughts? |
Posted: Wed Sep 19, 2012 9:21 pm Post subject: |
I have both C and D engine codes here, but as far as I know they are the same engine. I will see if I can find any clues as to what the difference might be tomorrow. That 9th digit is a check digit, maybe they actually are using that when they do the insurance company check? I don't know how that is calculated, but it is probably some kind of checksum. That link you provided says it is done according to NHTSA, maybe that formula is online somewhere.
One other possibility that has just occurred to me. On the two vans here (92 and 95) that have the C and D engine codes but (I think) the same engine. One is manual and one is automatic, so they would have different ECUs. Maybe that triggers a different engine code.
That would not have any effect on your situation though, I don't think. If the insurance company computer is checking the check digit, then possibly any change in any of the numbers might fix it, and the engine code change working might just be a red herring.
You don't say where you are, but all Canadian vehicles will have a sticker with the VIN on it as well as the dash-mounted VIN, as noted earlier in this thread. Does yours have that compliance sticker?
RonC |
kamzcab86 Samba Member
Posted: Wed Sep 19, 2012 10:40 pm Post subject: |
| snowsyncro wrote: |
| That 9th digit is a check digit, maybe they actually are using that when they do the insurance company check? I don't know how that is calculated, but it is probably some kind of checksum. |
When a VIN comes up as screwy, I always check the check digit. Sure enough, this one WV2KD0701PH064173 is incorrect. If every other digit is right, the check digit should be an 8. Here are the results of me playing around entering VINs into AutoCheck:
WV2KD0701PH064173 = invalid (incorrect check digit)
WV2KC0701PH064173 = invalid (incorrect check digit)
WV2MD0701PH064173 = invalid (correct check digit)
WV2KD0708PH064173 = valid, but no records (correct check digit)
WV2KC0704PH064173 = valid, but no records (correct check digit)
There's a '93 GL on AutoTrader; it's VIN WV2KC0708PH095443 contains a correct check digit and is valid in AutoCheck and results in records found. So, something is amiss with WV2KD0701PH064173. Be sure the digits are correct (sometimes they don't appear to be what they actually are: that check digit could very well be a 4, but it has faded into looking like a 1). Verify the VIN by checking all VIN locations (do EVs have VIN stickers on body parts like the later Cabriolets?) and verifying that they all match.
| snowsyncro wrote: |
| You don't say where you are, but all Canadian vehicles will have a sticker with the VIN on it as well as the dash-mounted VIN, as noted earlier in this thread. Does yours have that compliance sticker? |
All USA vehicles have a compliance sticker as well: VIN + bar code starting in 1990 (maybe even a year or two earlier, not sure) on the B-pillar door jamb, usually driver's side. _________________ ~Kamz
2000 Jetta VR6 |
Posted: Thu Sep 20, 2012 5:17 am Post subject: VIN Locations |
As far as I know, there are only the two VIN locations; the dash and the left door jamb sticker (driver side 'B' pillar).
I checked my engine codes. All engines are gasoline, 2.5L 5-cylinder:
'92 manual C
'94 auto D
'95 auto E
Doesn't reveal much, to me anyway.
RonC |
kdane2 Samba Member
Posted: Thu Sep 20, 2012 1:30 pm Post subject: |
| I am in California, and I have both VIN locations. Thanks for the info. I can't quite remember what happened 3 years ago when my old insurance ran the VIN, I had her change I believe the D to a C and it came up. Odd. |
