nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Tue Aug 31, 2010 10:24 pm Post subject: 1949 Restoration |
After several years of collecting the proper parts, rebuilding of some I had, and saving my pennies, I finally have the engine for my October 1949 nearly complete.
The car arrived with a Swedish factory replacement engine that was rotted through the bottom, and I had this August 1949 block as well.
We want to drive this car so it was important that the foundation of the engine was solid. I sent the long block to Joe Ruiz and a few months later I got this back:
Things like the carb, fuel pump, and distributor I left to a professional (Thanks Ed Fall at Vintage Werks)
The generator was restored by another professional (Glenn Cheaney at Ace Alternator)
Star coil is from Ricardo at Split Parts Unlimited.
Over time I had collected all the proper sheet metal and repaired and refinished it myself.
There are a couple of details I need to change or complete:
1. Metal plate between the shoe boxes is not installed.
2. Different fan belt (the one on there is a test one for size and pulley alignment test purposes)
3. Fuel lines are old originals and need to either be replaced or straightened and re copper plated.
4. Miscellaneous bolts to tighten to proper torque.
5. Front sheetmetal piece is not yet installed
When all is said and done, I should have a very nice stock 1949 engine for my 1949 deluxe.
I welcome all comments and suggestions. Not bad for a girl, huh?
Nancy |
Rometsch2880 Samba Member
Joined: August 15, 2004 Posts: 583 Location: St. Albans, WV
Posted: Tue Aug 31, 2010 10:27 pm Post subject: |
very nice. |
twinwindows Samba Pimp
Joined: December 08, 2000 Posts: 4086 Location: So.Cal. Highland Park GFK!
Posted: Tue Aug 31, 2010 10:42 pm Post subject: |
Just by looking at your motor I can tell the rest of the car is going to look just as nice. It`s all in the details and that motor has it. _________________ CRG
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
myzamboni wrote: |
Yeah, everyone's now doing it GFK style . . . everythinig is covert until the finished product is revealed. |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
Posted: Tue Aug 31, 2010 11:44 pm Post subject: |
Very nice piece of art
Some over-restoring if I can say, almost all nuts and screws were originally black zinc coated and generator cadmium plated? |
52HoffmanSplit Samba Member
Joined: April 07, 2006 Posts: 1272 Location: Lamorinda CA
Posted: Wed Sep 01, 2010 1:13 am Post subject: |
Beautiful!! Wait til you see how bright your headlights are with that Glenn Cheaney Generator with perfectly matched and balanced Regulator........ People think I'm running 12 Volts.
Glenn is a unique individual.....Really a professional and entertaining guy. _________________ DB
9/1950 Hoffman Standard
11/1966 Porsche 912
10/1966 Porsche 912
7/1968 Type 265 Double Cab
10/1958 Type 117 |
Wannasplit Samba Member
Joined: February 18, 2009 Posts: 30 Location: Maryland, USA
Posted: Wed Sep 01, 2010 5:29 am Post subject: |
Best thread of the week, maybe of the month!
Nice job. |
Rich's 50 Samba Member
Joined: February 18, 2004 Posts: 10781 Location: San Diego, CA
Posted: Wed Sep 01, 2010 6:36 am Post subject: |
Sweet man.... |
ProjectX Accessory Nut
Posted: Wed Sep 01, 2010 9:22 am Post subject: |
I'm currently building a January 1950 motor, and all I can say is you are doing a very nice job. Those heater boxes are super rare, and very correct. Nice attention to detail _________________ Even my nuts are plated.....
195? Project "X"
1954 Oval Convertible |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Wed Sep 01, 2010 10:00 am Post subject: |
Wow!
VERY nice, although I'd expect nothing less from you Nancy.
Great work and nice to see ALL the correct tin on an engine.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
bwaz Samba Member
Posted: Wed Sep 01, 2010 11:03 am Post subject: |
Wow, looks great... great to have a benchmark to try and get to that level!
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed Sep 01, 2010 11:07 am Post subject: |
looks really good! what kind of coating is on your manifold and heat exchangers?
there are two things i would like to point out:
- i don't think the grommet on the oil filler tube (where it passes through the engine tin) is "correct" for a '49.
-i do not see a rubber stopper on your thermostat throttle ring, and the ring does not look properly adjusted. PM me if you want an NOS stopper for it. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1773 Location: Winnipeg
Posted: Wed Sep 01, 2010 1:55 pm Post subject: |
That is such eye candy. Keep those pics coming.
Don |
my65rhd Samba Member
Posted: Wed Sep 01, 2010 2:13 pm Post subject: |
What method was used to clean up the case so well? I didn't think hot tanking alone with give such a nice finish...Kyle |
axel struwe Samba Member
Joined: January 18, 2005 Posts: 288 Location: Germany
Posted: Wed Sep 01, 2010 2:34 pm Post subject: |
hazetguy wrote: |
-i do not see a rubber stopper on your thermostat throttle ring, and the ring does not look properly adjusted. PM me if you want an NOS stopper for it. |
Great engine and good work on it!
But i also think this detail started in 1951....
Suboval Samba Member
Posted: Wed Sep 01, 2010 3:01 pm Post subject: |
axel struwe wrote: |
Yes, it started in 51.
http://www.thesamba.com/vw/forum/viewtopic.php?t=237526&highlight=oil+breather _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
6984vwvanagon Samba Member
Joined: June 11, 2006 Posts: 74 Location: McKinney Tx.
Posted: Wed Sep 01, 2010 3:04 pm Post subject: |
Beautiful!
Thanks for posting! _________________ 84 Vanagon GL van "Horst"
69 Beetle (sold)
73 Beetle (sold, darn it!)
"Ain't this some beautiful mess." - Dude Watson |
Posted: Wed Sep 01, 2010 3:18 pm Post subject: |
Thanks so much...Reading it now.....Kyle |
Posted: Wed Sep 01, 2010 4:42 pm Post subject: |
Yes, I believe you are correct. I added it because I am not happy with how well the filler cover stays pushed into the stand. I didn't want to be driving along and have that thing pop out of the case so I went with the early filler cover and the later spring keeper. I may swap the cover out for the later 25hp one I have since it has the dimple, and use the smaller one for shows.
Thanks for all the comments. I do appreciate the feedback.
Nancy |
Posted: Wed Sep 01, 2010 4:56 pm Post subject: |
hazetguy wrote: |
looks really good! what kind of coating is on your manifold and heat exchangers? |
Both have a color blend of the Eastwood high temp manifold paints as does the muffler.
hazetguy wrote: |
- i don't think the grommet on the oil filler tube (where it passes through the engine tin) is "correct" for a '49. |
You are correct. I added it because I could see where the tub and rear sheetmetal were worn and I know it will only get worse.
hazetguy wrote: |
Not sure what you mean by a stopper. My 1949 spare parts manual doesn't even show a thermostat ring but it has mostly info on eary 1949 parts not later. I'll have to check my 1950 version too. |
