Peter - Belgium Samba Member
Joined: December 22, 2003 Posts: 762 Location: Brussels - Belgium
Posted: Sun Sep 05, 2010 10:26 am Post subject: 356 BT6 - an outlaw in the making |
AS I bought the project... basically a naked body with the windows and window winders. No mechanics, no interior, no gauges, no switches, no steeringwheel, ... no everything...
You get it
As I went to pick it up
Once at home and on to a dolly
_________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
Posted: Sun Sep 05, 2010 10:27 am Post subject: 356BT6 - an outlaw in the making |
Front suspension works
I wanted to use beetle trailing arms, but ended up buying original Porsche items since I wanted to keep the needle bearings in the front beam
And after some cleaning and paint
CB performance dropped spindles for disk brakes and link-pin suspensions
Drilling the spindles for the dustplate
All rebushed and assembled
and with the dustplate installed
Vented KERSHER disks installed with new wheel studs and bearings. These brake kits are german TUV approved!!
These vented disks work with these modified T3 calipers (they have bigger pistons compared to beetle)
And all installed at the front of the 356
And testing with a FUCHS wheel... looks good!
Posted: Sun Sep 05, 2010 10:28 am Post subject: 356 BT6 - an outlaw in the making |
At the rear I wanted to use a 1303S IRS gearbox due to its long gearing. Coupled to that would be the rear a-arms of a porsche 944 with the vented disks
But after testfitting this seems not to be a good idea... unless some drastic modifications are done to the Porsche undercarriage. I do not mind to slice and dice a bit... but this seems to need too much
This is teh Porsche a-arms mocked up and positionned as high up as possible. It touches the bottom of the rearseat and the rearwards chassis legs
Testfitting with a FUCHS wheels. This sticks out too far although getting this narrowed would not be that much of an issue
This is the look with a full tire on... even on lowest car position, this is still WAY too high! And this is harder to get lower. It would mean sectionning the chassis + a-arms.
So my new plan of attack: a straight axle gearbox with the early narrow torsion tubes. Onto these I would then fit the Porsche 944 rear disks.
Still need to mock this up to see how much this would narrow the rear versus this IRS 944 set-up?
And how low I could make it go to check how much I would still need to section the chassis. stay tuned! _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight=
Last edited by Peter - Belgium on Sun Sep 05, 2010 10:34 am; edited 1 time in total |
Posted: Sun Sep 05, 2010 10:28 am Post subject: 356BT6 - An outlaw in the making |
I'm not sure about front wheels and tyres.
either 4" FUCHS with a 145 tyre
either 5,5" FUCHS with a wider lowprofile tyre just as on my SLAMBULANCE
This is how it would look on the 356
Posted: Sun Sep 05, 2010 10:30 am Post subject: 356 BT6 - an outlaw in the making |
AS interior I really want the ALU speedster steats in there, but as a back-up I bought these SIMCA seats from teh 70's
The little girl likes them (also note the modified 1957 beetle steering coloumn and steering wheel)
BUT if someone knows of a nice set of ALU speedster seats still for sale... let me know! _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
radish Samba Member
Posted: Wed Sep 08, 2010 4:14 am Post subject: |
hey Peter are the link pins carriers from 356 or beetle? |
Posted: Wed Sep 08, 2010 5:10 am Post subject: Re: 356BT6 - an outlaw in the making |
Expect for the 4 trailing arms, all parts are standard beetle items!
The linkpins with their bushings are a new kit you can buy from the VW stores, the linkpin carriers are pre 64 beetle spindle parts.
And everything fits nicely
The Porsche trailing arms are basically VW items (they still have the VW logo!), but with an extra sleeve pressed for the out bearing and a part welded on them for the anti-roll bar on the lower arms.
In my opinion this is the best way to lower your 356 avoiding the hassle with the adjusters so you keep the standard ride quality.
Drawback is if you want to keep the original Porsche drums... not sure if they can (be made to) fit the CB performance spindles? On the other hand a good time to upgrade to diskbrakes _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
Daddybus Samba Member
Posted: Thu Sep 09, 2010 9:38 pm Post subject: Re: 356BT6 - an outlaw in the making |
Peter - Belgium wrote: |
Drawback is if you want to keep the original Porsche drums... not sure if they can (be made to) fit the CB performance spindles? On the other hand a good time to upgrade to diskbrakes |
IRS arms can be swapped left for right and right for left and installed up side down (you remove the shock absorber mount and re-install it). This allows you to go lower without increased camber. You may want to mock it up that way before shelving the IRS idea. |
Posted: Fri Sep 10, 2010 1:30 am Post subject: Re: 356BT6 - an outlaw in the making |
Daddybus wrote: |
Thanks for the thought! I have done this trick on my Slambulance to indeed keep the camber at a nice level, but in the 356 the issue is the back seat area and the rearward chassisssections are just too low!
Raising the seat-area is not really an issue, but if I want to get to the height I want in the back, I need a lot of sectionning done there...
I have soms pics of this, will post them over the weekend.
it is different in the A models, but the B/C models are a pain for that IRS conversion (unless some serious work is done, but I prefer to keep the body as standard as I can in case one day I want to go back to the OG suspension set-up) _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
badsix Samba Member
Joined: November 22, 2007 Posts: 228 Location: coos bay or.
Posted: Fri Sep 10, 2010 7:59 am Post subject: |
cooool, i would get my cutting tools out and make it fit. you'll never want to put it back og after you get it outlawed. keep the pictures comeing |
pancho villa Samba Member
Posted: Fri Sep 10, 2010 9:54 pm Post subject: OUTLAW |
Get em Pete. |
Budcar Samba Member
Joined: September 12, 2010 Posts: 7 Location: The Valley
Posted: Sun Sep 12, 2010 3:33 am Post subject: Outlaw |
I have seen most IRS conversions done with early 911 banana arms. Would they solve your clearance problem? |
Posted: Sun Sep 12, 2010 1:07 pm Post subject: Re: Outlaw |
Budcar wrote: |
I have been thinking about these as well and think they will solve part of the issue, but not sure if they will get me low enough?
And if they would get the car low, not sure on width? Would these be as wide as the 944 arms with disks? Since that did not work...
A friend of mine is checking if he can find a set I could use to mock-up things.
Little downside...I have all 944 parts, disks, calipers, ... and if I would move to the 911arms, I need to buy everything new again _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
Budcar Samba Member
Posted: Sun Sep 12, 2010 5:30 pm Post subject: |
There are a few threads on the 356 registry forum that have info on a 901 conversion. PM Mike Moss he has a Power Point document he will send you that also has a lot of info. |
Budcar Samba Member
Posted: Mon Sep 13, 2010 4:05 am Post subject: IRS conversion |
Hi Peter,
I saw your post on the 356 registry. SWB is short wheel base 911/912 (1960's) the trailing arms (banana) are shorter than the later cars. I'm about to start to do the conversion on a T5. I'm waiting for a piece of 911 torsion bar for the trailing arm/trans mounts. I sent you a PM me on the 356 registry with my email. I will then send you pictures of what you need.
Ken |
Posted: Wed Sep 15, 2010 9:37 am Post subject: |
Before completely shelving the IRS idea, I will try those 911 banana arms. From what I have seen, they should work
But then I should find a way to fit my 944 vented disks and calipers on the arms since otherwise that would look stupid with vented disks up front and solid ones in the rear...
Another of the items for my interior is the Spyder550 e-brake! My first AutoCAD designs before I can have them lasercut shows me I have about 23-24mm pull action on the e-brake cables
Should end up looking something like this, but then without all the holes and in fully polished INOX
Budcar Samba Member
Posted: Thu Sep 16, 2010 3:57 am Post subject: |
It will not look stupid with solid disks in the rear. My 72 911 came from the factory with vented in the front and solid in the rear. Nobody has ever said it looked stupid. Anyway it is just a bolt on with later 911 rotor and caliper if you really want vented. |
Posted: Mon Jul 18, 2011 12:05 pm Post subject: 356 |
I finished the brake lever!!
Main clamp I will use
And after welding the brake assembly to teh clamp
Still needs final polishing and correct length of bolts etc... but the main part is done
Now lets see what this says once it is in the car!
First next step will be to fit that gearbox in the 356... As soon as that one is in its place, I can check to hook up the rear brakes and this brake lever!
lets hope it all works _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
