Peter - Belgium Samba Member
Joined: December 22, 2003 Posts: 762 Location: Brussels - Belgium
Posted: Tue Sep 24, 2013 7:31 am Post subject: Re: 356 BT6 - an outlaw in the making |
thebucket wrote: |
Peter,
I saw that you were thinking of running 944 brakes out back with a vw trans. Is there a way to do so with a vw swing axle? I'd love to run the set up out back of my 55 with my Berg 5 swing axle! |
Yes, that can be done as well... and I looked at it but it would have pushed out the wheels too much for what I wanted.
It would be a matter of machining the hub so it fits the swingaxle splines + making the carrier for the caliper.
Peter _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
Posted: Sun Dec 15, 2013 8:05 am Post subject: a bunch of stuff done past months... |
trying to get it all together
brakes all hooked up and bled
Converted a drain pipe unblocking tool to a guidance for teh throttle cable
and all hooked up
Fixed the broken bolts and removed all chrome in preparation of paint
speedjeans76 Samba Member
Posted: Mon Dec 16, 2013 2:42 am Post subject: |
Looks nice peter..
can you mail me for a 550 handbrake setup?
thanks
marco
[email protected] |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Tue Dec 17, 2013 5:53 pm Post subject: |
Peter- I read the whole thread and didn't see anything about the motor; can you tell us size and specs? Al _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Thu Dec 19, 2013 10:40 am Post subject: |
ALB wrote: |
Peter- I read the whole thread and didn't see anything about the motor; can you tell us size and specs? Al |
The engine I actually made for my cal look 57Ragtop but changed my mind and figureed it would look a lot better in this outlaw:-)
Specs: 2110cc
- a Forged 82mm SCAT crank
- SCAT 4340 H beam connecting rods
- Steve's VW Shop STAGE II heads
- Raptor cam with lightweight lifters
- 1,4 ratio rockers
- 48IDA's on polished Gene Berg manifolds
- chromoly pushrods
- Modified BAS streetsport exhaust on CSP heaterboxes
a nice little package I think
Lets see what the torque & HP curves will say _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
IMPI Samba Member
Joined: January 19, 2006 Posts: 35 Location: South Africa
Posted: Wed Jan 08, 2014 12:41 am Post subject: |
Hi peter awesome build. Regtig pragtig. I want to ask you why you did not simply fit the left axle tube to right and the right tube to left. this places the shock mount behind the axle and is how Porsche did it anyway?
Armand |
Posted: Wed Jan 08, 2014 1:49 am Post subject: |
IMPI wrote: |
Armand |
damn... to be honest I did not even think of that !!! That would indeed have made it a lot easier (and cheaper)... _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight=
Last edited by Peter - Belgium on Wed Jan 08, 2014 12:04 pm; edited 2 times in total |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Wed Jan 08, 2014 9:00 am Post subject: |
IMPI wrote: |
Armand |
The bolt pattern to the spring plate doesn't really work that way. _________________ Jack Staggs
Actual name |
Posted: Thu Jan 09, 2014 7:04 am Post subject: rear lights |
Of all the sets I saw... there is always an issue with at least one of the sockets for teh bulb, so need to replace some.
On top, i wanted the stop and indicator light split so found new dual filament sockets i could use to replace the original single (and broken) sockets
removed the original sockets
Modified the holders and fixed teh scokets
and some heatshrink to protect
IMPI Samba Member
Posted: Thu Jan 09, 2014 10:26 am Post subject: |
Hi Peter
I have to apologise as a previous poster said "Not everything you read on the net" is true.
I was quoting a post on the 356 registry forum which stated that both axles and tubes are interchangeable this is wrong due to the boltholes but the shock absorber mount also seems at a wrong angle if you ignore the bolt holes which could possible be made to work by re drilling 2 holes and making an adaptor
Sorry about that
Armand |
Posted: Fri Jan 10, 2014 1:04 am Post subject: 356 outlaw |
IMPI wrote: |
Hi Peter
Sorry about that
Armand |
No worries! it sometime can trigger new idea's even if they are not always executable:-)
What can be interchanged - I believe - is the original Porsche gearbox axle tubes onto the beetle gearbox. I have been looking for these for a while, but could not find them around here (and shipping from US was a killer).
Lets see, might still change the set-up based on driving experience...
Thanks,
dsrtfox Samba Member
Posted: Mon Jan 20, 2014 6:07 pm Post subject: |
I always liked the 912 tach in the middle. Super nice build... |
Posted: Fri Feb 07, 2014 10:50 am Post subject: FINALLY |
it was about time to install the temp test engine
And out of the garage she goes!!! this is the first time in momre then 30 years she drives under own power (Original bill of sale is from 1983 and mentions the car as a resto project:-)
With teh standard steeringwheel I still need to restore... and a battery as seat:-)
