solex 30 pict 3
jays
jays is offline
PostPosted: Mon Sep 06, 2010 9:22 am    Post subject: solex 30 pict 3 Reply with quote
is there any adjustment on the 30 pict 3 that would mess with the vacuum advance of a 113 905 205 m distributor?
because i ran my car a could hundred miles on a bad carb and the dist was fine. then when i got my carb cleaned up and fixed now the dist is doing funny things.
Paul Windisch
Paul Windisch is offline
PostPosted: Mon Sep 06, 2010 9:59 am    Post subject: Reply with quote
What kinds of funny things? Does the vacuum diaphram hold vacuum? Has your idle speed changed?
*ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6 (the loser cruiser)
Heidebreicht Chevrolet
http://www.heidebreicht.com/HomePage
Grifter
Grifter is offline
PostPosted: Mon Sep 06, 2010 12:25 pm    Post subject: Reply with quote
The "bad carb" probably required that the timing be set a certain way, and now that you have a "good"? carb you'll most likely need to re-do the tuning and timing.
Greg
1970 Beetle...a work in progress
Yukon Yellow
Stock SP, Bosch vac advance
30PICT-3 swapped to a 30PICT-1
"At least I know that I don't know. Question is are you bozos smart enough to feel stupid? Hope so"
durhamfirecaptain wrote:
Wow, we have VW's in North Carolina?
jlex
jlex is offline
PostPosted: Mon Sep 06, 2010 4:41 pm    Post subject: Reply with quote
Put the metal "shepherd's crook" line back on between the dist diaphragm and the carb... it'll prevent gasoline from traveling down to the diaphragm and destroying it.
jlex.
'70 std. "Elsie"
'88 Carrera
jays
jays is offline
PostPosted: Mon Sep 06, 2010 5:28 pm    Post subject: Reply with quote
well by funny things i mean that the points are starting to get white spots on them which eventually in some wierd way insulates them and doesnt allow a spark. ive changed the condenser the coil and points and they seem to be still doing the same thing. ive changed the ground that connects to the trans. under the car and nothing. ive checked the resistance on the wire that connects to the coil and its all good.
so i was driving home and got one last final idea. and it was that it had something to with the vacuum advance maybe its advancing to much or too little since the carb is good now. and when i recieved the carb the man said he tuned it (which i dont believe) i think he just fucked with it.
so idk i'm lost on this one. this is my last idea before i just completley change the dist for a rebuilt on or something. because idk what else it could be. and for somereason i feel lack of advance or too much would caus ethat white spot.
was i in the rigth or the wrong? this is my first vw guys i dont have alot of experience. and i'd sure like some wise words.
forested665
forested665 is offline
PostPosted: Mon Sep 06, 2010 7:15 pm    Post subject: Reply with quote
every engine is just slightly different. so the carb needs to be re adjusted.
Theres a large screw and a small screw on the driver side (for left hand drive models) passenger for righthand drive.
The big screw is called the airbypass valve. you twist this one back and forth to set your mixture. the small screw is the volume control (how much of the mix the engine gets) if you back the large screw out the gas stays the same and the air increases if you back the small one out the gas AND air increase.
some people will tell you they are gass and air screws but there not and the solex part diagram confirms this.
Hopefully this will help you out some.
You really do need the metal line that goes between the distributor and the carb. if your vacuum advance is working now it wont be for long running it like that.
View user's profile Send private message Send e-mail MSN Messenger Classifieds Feedback
jays
jays is offline
PostPosted: Tue Sep 07, 2010 7:47 am    Post subject: Reply with quote
what metal line o.0 i didnt really know what you were talking about when you had said that earlier.
Paul Windisch
PostPosted: Tue Sep 07, 2010 12:22 pm    Post subject: Reply with quote
The original vacuum line was mostly made of metal. Where it came out of the carb, it went up first to the top of the carb, then bent and came back down to the distributor. This prevents gasoline from draining down into the vacuum diaphram in the event of a flooded carb, which would ruin the rubber diaphram. Perform a gallery search for engine pictures and you will come across it very quickly. As stated above, it looks like a sheppards' hook. As far as the points getting funky, ensure that the coil is good as well, and make sure the spark plugs are in the correct heat range. Also make sure ALL the spark plug wires are good, and make sure grease or oil aren't getting on the points when you put them in and set them. Grease or oil will foul them quickly.
1984 Mexican Beetle
jlex
jlex is offline
PostPosted: Wed Sep 08, 2010 4:46 am    Post subject: Reply with quote
Here's a pic of the shepherd's crook on a 30pict3:
jlex.
'70 std. "Elsie"
'88 Carrera
candymustang65
Banned
candymustang65 is offline
PostPosted: Wed Sep 08, 2010 7:05 am    Post subject: Reply with quote
Just an observation here I dont see Fuel solenoid shut off on this Carb ?
But today is My birthday ?
So what do I know dammn near Dead at 50 ? Go figure !
But wheres the solenoid ?
I dont see it ?
Sean
Paul Windisch
PostPosted: Wed Sep 08, 2010 7:37 am    Post subject: Reply with quote
It's on the right side of the carb, about 11:00 above the generator.
1984 Mexican Beetle
priss
priss is offline
PostPosted: Wed Sep 08, 2010 11:05 am    Post subject: Reply with quote
There is one on jlex's pic. But not all Pict-3's have them.
I have a 70 also, and there is no fuel cut off on mine. There have been a couple times when i was reminded of the reason for them tho.
Please note, this is an as delivered from the PO pic. I used it because of its clarity in showing the carb. I have already fixed, cleaned, rerouted and all that stuff the Samba folks have told others to do since this pic was taken. I blew the motor up last week anyway, but it sure was fun while it lasted.
jlex
jlex is offline
PostPosted: Wed Sep 08, 2010 11:27 am    Post subject: Reply with quote
Yeah, most other models have the shutoff solenoid on the left...
The 30pict3 solenoid is a one year only model, too... supposedly it won't interchange with other solenoids.
jlex.
'70 std. "Elsie"
'88 Carrera
