falernium Samba Member
Joined: August 25, 2010 Posts: 34 Location: Dallas, TX
Posted: Wed Sep 08, 2010 12:35 am Post subject: Brake issues in the rain |
Hey folks, did a pretty decent search and couldn't come up with an answer to my issue. I have a 70 standard and when it starts raining outside I have some nifty braking ahead of me. Normally the system is pretty stiff. Then the opposite in the rain, super loose and squishy. I know since they are drum brakes that the overall depression on the brake pedal is going to increase, but this is pretty dramatic. Also, the brake pedal has a nasty habit of sticking down in an engaged position and I have to lean down and manually pull the pedal back out. This only happens in the rain. Is my pedal assembly just old and rusty or are there more sinister forces at work here. Thanks in advance for forthcoming responses! |
JonF Samba Member
Joined: December 16, 2005 Posts: 2030 Location: Oklahoma
Posted: Wed Sep 08, 2010 1:19 am Post subject: |
check and make sure the spring is hooked to the brake pedal. _________________ 68 bug 1600sp 30/31
68 baja 1600sp 010 32ndix |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Wed Sep 08, 2010 3:38 am Post subject: |
In all seriousness, if the pedal assy is pretty grungy, you out to pull it and do a rebuild, which is pretty much just taking it apart, cleaning, painting and regreasing. And while you are at it replace the pedal return spring as mentioned. It's not that hard - the biggest hassles are removing the pin that holds the pedal on the shaft (I don't remember which direction you need to tap it out) and putting the assy back in.
There have been procedures posted on how to do this. Also, a quick tip is to use a zip tie to hold the clutch cable on the arm when you put it back together.
As to why it only does it in the rain, makes no sense to me. Maybe someone else has an idea. The only thing that I would suggest is to bleed the brakes, but when you re doing it, kind of do a flush to replace the bulk of the fluid. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Wed Sep 08, 2010 9:27 am Post subject: |
thanks guys. i figured it was just the old rusty mechanism.... i will pull everything, and clean and take care of the rust issues, which i think is why it only happens in the rain. makes everything sticky. nice tip with the zip ties!!! _________________ Robert
'70 standard, Falernia
PO made her respectable, I'm making her Spectacular
Big-C wrote: |
Shop owners should pay SAMBA a stipend for reducing the number of idiot phone questions. |
Posted: Wed Sep 08, 2010 3:58 pm Post subject: |
I would love to take credit for that, but I think I got the idea from Glenn. In fact find his website and he has a pedal restoration on it. _________________ D-Dubya Manx clone - 63 Short pan,1914.
