TomSimon Samba Member
Posted: Tue Sep 28, 2010 10:39 am Post subject: |
Hi Ronnie,
you might find that 1-3/8" diameter is still too large for a 1200cc 4cylinder. I am no authority on the subject, in fact few are. It seems header selection is more experience meets science meets art But there are several configurations that I have seen work great, so have other VW guys who dyno tune like Geoff.
There are several performance books with section on header selection, you can run through the math, contact Burns Stainless online (they will do the work for you) or just run a simple trend or 'sanity check' against what guys already use with Type 1 engines. (I've done this for you, below).
I think this will get you very close to optimal, rather than relying on what is kinda available, or cutting up and shortening an existing T1 header designed for an engine with a significantly larger displacement. This also works for larger than 1200 (bored and stroked 36hp) Since I've used ratios, you can just divide for you own factor, using whatever new displacement you build or intend to build.
I would also want to use a real 'merged' collector, rather than one of those stubby 'extractor-type' sort of collector things that are cheap to build, but don't look very impressive (inside) in terms of internal flow.
My 'sanity check' methodology: Base header tube diameter on what I know works:
case #1 that works: 1600cc type 1 with dual port heads, 009 dist, Kadrons. Max rpm of 5500rpm, you real basic warmed over street engine. Most tests will lead you toward the optimal header being 32" primary tube length and 1-3/8" diameter. Good low end torque without taking anything away at 5500 rpm. Some will use a 1-1/2" header with sucess, but use a 1-5/8" header and you will see bottom end torque fall off at lower rpms, with little or no gains in torque at 5500rpm. 1-3/8" would work great for a street car.
case #2 that works: 2000cc type 1 with small ports and 40IFD's, W110 cam, max rpm 5500. optimized for low end torque, a great Bus engine. 1-1/2" A1 Sidewinder is perfect.
case #3 2387cc drag engine, high compression, 8000rpm. Most guys will find that 1-7/8" to 2" header with 32" primaries will fit the bill. A 2-1/8" may help, may not.
From the examples above that I know to be true, I would assert that header tube diameter is more a function of engine displacement, and only somewhat dependent on rpm range. Would you agree? BTW, look at the itty-bitty header tubes used on 4 cylinder motorcycle headers.
side note: header tube diameter <more or less> goes by single cylinder volume and rpm, but all my examples are 4 cyl engines, so we can just use total cc's to arrive at a factor (for comparison's sake).
1200cc/1600cc= .75 factor
1200cc/2000cc= .60 factor
1200cc/2387cc= .50 factor
Using some simple ratio math, my estimation is a 1200cc torque monster engine wants a header with primary tubes somewhere between a 1" and 1-1/8" diameter, and a small collector to match. A 1200cc high rpm race engine might like the 1-1/8", but a guy might try a 1-1/4" for giggles and grins. Like putting an 1-3/4" diameter header on a 1600cc engine, I estimate that a 1-3/8" header on a 1200cc 36hp is far too large for a 1200cc, and will sacrifice low end torque without helping torque at high RPM's.
It would still be worth looking at A. Graham Bell's book Performance Four Stroke Tuning and talking to Vince at Burns before building a custom header. _________________ 2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer |
jake74 Samba Member
Joined: February 15, 2007 Posts: 136 Location: Hanceville,AL
Posted: Mon Oct 04, 2010 7:05 am Post subject: |
I've been trying to get one of the 36 hp headers but haven't got a reply from slowanold on getting one.
I have had no luck contacting him.If someone know's how to contact him let me know. _________________ (Looking for Alabama dealer frames and an other Alabama dealer stuff) |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Mon Oct 04, 2010 8:46 am Post subject: |
I do have one new in the box that I bought from him a while back. I bought two, one to use, one to sell. I have some shipping $$ invested in it so I couldn't do $40. If you can't get a hold of him LMK and I'll make you a deal. _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Tue Mar 22, 2011 3:28 pm Post subject: |
NLA
Well I thought so after calling them. I ordered one on line just for the hell of it and low and behold it showed up on Monday but now I see it's off their website _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
The Cheetle Samba Member
Joined: September 01, 2007 Posts: 279 Location: Lake Havasu City, Arizona
Posted: Sat May 28, 2011 12:24 pm Post subject: |
I bought one, bolted right on!! Good quality and only $40! plus shipping. _________________ Save the Salt!! |
Stock Steve Samba Member
Joined: April 10, 2005 Posts: 1963 Location: My Left Nutmeg State
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Tue Feb 26, 2013 6:23 am Post subject: |
CIP1 sells a similiar header for a 40HP...would it fit some modifications?
I'm looking to run J-tubes with it on my 36HP |
txoval Samba Member
Posted: Thu Feb 28, 2013 11:11 am Post subject: |
Can anyone answer this?
txoval wrote: |
RichardinNZ Samba Member
Joined: September 16, 2011 Posts: 280 Location: Auckland, New Zealand
snowbug Samba Member
Joined: June 12, 2005 Posts: 167 Location: Oshawa Ontario Canada
Posted: Fri Mar 01, 2013 3:45 pm Post subject: 40hp header |
txoval wrote: |
The tubes will all line up but will not be a direct bolt on. The top flanges will need modifying. Either cut flanges from a scrap 36 muffler and weld on . The angle of the studs are different. You might be able to file the holes to fit . I might go that route. Jim |
txoval Samba Member
Posted: Fri Mar 01, 2013 7:19 pm Post subject: |
Or better yet (at least for me) I could cut off the new flanges, rotate, and re-weld...
Thanks for the info |
Posted: Sat Mar 02, 2013 1:15 am Post subject: |
RichardinNZ wrote: |
Stock Steve
Does this mean that the Kustom-1 header won't fit any 36hp? I was hoping to get one!
Thanks
Richard |
I wish I had a good answer for you Richard. I need to do some more research on why it didn't seem to fit *mine*.
I am definitely *not* saying that any company's products aren't as-advertised.
I may have some other issues with my own car that may have affected how things appeared to fit or not fit.
Sorry for being so vague, it's just that I need to do more work at my end, and definitely don't want to complain about anyone's product if I'm not sure of all the factors that could be affecting things. If and when I get to the point of having my header modified to fit my engine, I will certainly report back. _________________ Stock Steve
Shoreline Antique Auto Connection
http://www.shorelineantiqueautoconnection.com/
Ich Bin Ein Facebooker: https://www.facebook.com/steve.fromsaac
Join VVWCA: http://www.vvwca.com/
Your source for old school metal tire valve caps: http://www.thesamba.com/vw/classifieds/detail.php?id=1416217
Thanks Veterans |
AirCooledClassics Samba Member
Joined: August 20, 2004 Posts: 294 Location: Saskatoon, Sk Canada
Posted: Sat Mar 02, 2013 12:27 pm Post subject: |
I just fit a 1600 cc oe mexican header muffler to a 40 hp engine .I slipped on the barrels only then slid on the heads .I then bolted up the exhaust to the loose heads then torqued the heads tight .I then took my torch to the head end elbows and watched the tube find its new shape ( no it didnt colapse it moved smoothly)I removed it and It now fits my 1.2 perfectly. I believe this would work on a 36 hp with j tubes and dual carbs. just right 1/3/8 tubing stock tailpipe location. and an atractive price of 70.00. If you want you could re weld the flange for the heat riser for a sock intake manifold. _________________ 2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552 |
Posted: Tue Jun 11, 2013 7:53 am Post subject: |
txoval wrote: |
I just picked up a slightly used 40hp header for $25. It has1 1/14 inch tubes and small flange collector.To fit a 36hp Looks like filing the holes for the studs is way easier and just use a washer under the nuts. Stock 36 j tubes may need to be extented too. Looks like a cip1 header. It is kinda cheap looking, thin flanges and rough welding. The welds will need to be cleaned up. Jim |
