theDrew Samba Member
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7213 Location: Videbaek Denmark
Posted: Wed Oct 29, 2014 9:12 am Post subject: |
Thatīs the question that was asked |
offrdbus70 Samba Member
Joined: August 23, 2006 Posts: 512 Location: Pine Valley-SD
Posted: Wed Oct 29, 2014 8:11 pm Post subject: |
Northof49 wrote: |
Why not test the pickup to case oil pump inlet with a vacuum test? Followed up by installing the pump, plugging the pump outlet and vacuum testing it too. I'm definitely going to do this on my build. |
Done that. It does not leak at all. I kinda wish it did. At least I would have an answer.
Thanks
MG |
Posted: Wed Oct 29, 2014 8:14 pm Post subject: |
theDrew wrote: |
Alstrup wrote: |
Yes a dry sump sytem should cure the problem |
Yes, throw more money at it |
Ah yes we must spend more money. But a dry sump system is less then a new case. And I am not convinced it is the case.
MG |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Thu Oct 30, 2014 6:14 am Post subject: |
Sorry if this has been covered, but 13 pages is a lot to get through. Have you actually monitored the oil pressure, or are you still relying on the idiot light?
Despite the folklore, deep sumps are actually only needed for race type applications where the engine spends long periods at high revs, or where large pumps are used with overly thin oil. Of course, your long oil lines might be a third reason... but I'm just wondering if you're chasing a problem that might not exist. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Thu Oct 30, 2014 8:51 am Post subject: |
Quokka42 wrote: |
Despite the folklore, deep sumps are actually only needed for race type applications where the engine spends long periods at high revs, or where large pumps are used with overly thin oil. Of course, your long oil lines might be a third reason... but I'm just wondering if you're chasing a problem that might not exist. |
Yes I do have a gauge as well. It falls to zero. This engine is pretty fast and the van accelerates hard. Eliminated the oil lines at one point and it still does it. I do not think the oil is going to the valve cover because the loss of pressure happens so fast. Like it slurps a big air bubble. It will happen in like two seconds flat. Boom no pressure.
Thanks
MG |
Posted: Thu Oct 30, 2014 9:37 am Post subject: |
Thick oil is more likely to exhibit this characteristic than thin oil. I have found that engines with 20-50 (for example), especially if the oil temp is under 220F, take forever for the thick oil to return to the sump. Thin oils do that very quickly.
There can be a lot of thick oil making it's way back to the sump, in the heads and PR tubes, after a high RPM blast if the oil temp is not high enough to get the viscosity down. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Thu Oct 30, 2014 3:51 pm Post subject: |
offrdbus70 wrote: |
Boom no pressure.
Thanks
MG |
That is exactly how uncovering the oil pickup presents. It doesn't seem to matter why the pickup is uncovered. If there isn't enough oil around the end of the pickup, air is ingested ... instant zero pressure.
If the oil just can't get back to the bottom of the sump fast enough (for any reason) this is what happens.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Pat D Samba Member
Posted: Fri Oct 31, 2014 11:34 am Post subject: |
Oil can go many places during acceleration. It gets wound up around the crank shaft like cotton candy, gets pushed up into the heads, moves away from the pick up tube, etc. Buy a 3.5 qt oil sump like I said 13 pages ago and problem solved. _________________ Pat, Im too fast slow me downs! |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Fri Oct 31, 2014 1:45 pm Post subject: |
Like a couple other guys, I notice this thread is still around, but can't wade through 13 pages to see if the following suggestion has been made: Measure the filter mount you are using, and be 100% certain that the holes line up precisely with the filter you are using. Those holes sometimes require widening. This was THE solution for a know-it-all racer I once knew. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
RHough Samba Member
Posted: Wed Nov 12, 2014 9:47 am Post subject: |
offrdbus70 wrote: |
Dont wanna say as he is an important parts connection and truly a nice guy. It is fresh but it had this problem before too. Before I had to have it rebuilt because it sucked a valve due to coil bind.
It is 2014 and the problem is still there? Since it had the problem before this engine was built logic would be that the problem lies in a part that was not changed. |
mark tucker Samba Member
Posted: Wed Nov 12, 2014 12:10 pm Post subject: |
my logic says it's the builder/assembler. also if your hat is too close to your ears it's hard for rain to get in to your brain.ipsofatso your pickup hat may also be to close and the oil not getting back to the sump. in reality that hat is only a mount or stiffener for the tube when you have a deep sump. |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Wed Nov 12, 2014 3:35 pm Post subject: |
Should the hat be eliminated or gutted on a deep sump conversion? Easy enough to do if I am welding a longer pickup tube on. _________________ 1958 Karmann Ghia owner |
Posted: Wed Nov 12, 2014 5:39 pm Post subject: |
I dont think you need it. .think about it this way,not much oil will be thrown right at that hole being covered by that hat.but lots of standing sloshing oil will find it's way to that hole leading to the sump.if the hat is in the way thats just another abstacle or ramp for it to go around...well it isant getting to the sump if it go's around. you can make it somewhat directional & raise the lower edges so the oil can flow better.I will be adding some deflectors to my aluminum cases so the oil is funneled to the sump when axcellerating or breaking.trap doors would be nice too but it's just a vw might add those too along with a drain from the type 3 diphole to the sump.
Ive seen some hats that were about 1/8" off the floor.not very condusive to oil getting back to the sump. I supose you could add one down in the sump if you wanted, but probably not nessasary. |
hooker Samba Member
Joined: October 07, 2004 Posts: 261 Location: Bend, Oregon
Posted: Thu Nov 13, 2014 10:34 am Post subject: Oil pressure loss |
I know it's already been covered but I would look at it again. First aluminum case I built for drag racing the oil pump inlet hole did not match up with the hole in the case. Sucked air at high rpm and acceleration. Everything worked fine till I got on it.
Yes, I had a deep sump also. _________________ 2007 NHRA Division 6 Finals Champion air cooled Rabbit P/U rear engine compact/import class, 13.32 sec 1/4 Woodburn, Oregon
Pauter Big Block VW 2610 cc turbo mid engine roadster 9.69 sec @ 147 mph 1/4 PIR Oregon
I spent most my money on women and VW race cars. The rest I wasted. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Aug 12, 2017 7:52 pm Post subject: Re: So..seems like the 1.5 sump I bought was a waste of money! |
Did this ever get figured out? _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
