busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jul 31, 2015 10:10 pm Post subject: |
asiab3 wrote: |
So is it not the thin one on the right? ( These pics are from different ads I've saved over the years) |
I was referring to SGK's pic, the one in yours looks like a bus pulley.
I'm not sure but the profile where the belt rides is also a little different, with a fat newish belt it seems to ride lower in the pulley producing higher fan RPM's, but maybe it's just me I recently switched to one I scored at a swap and it seems to run a bit cooler, but maybe it's just wishful thinking on my part _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Fri Jul 31, 2015 10:31 pm Post subject: 38 A generator belt 9.5x900 |
busdaddy wrote: |
I'm not sure but the profile where the belt rides is also a little different, with a fat newish belt it seems to ride lower in the pulley producing higher fan RPM's, but maybe it's just me I recently switched to one I scored at a swap and it seems to run a bit cooler, but maybe it's just wishful thinking on my part |
Colin showed me a factory manual that I had never seen last summer, and it showed a 9.5x900 belt for the 38a generator-equipped cars, and a 9.5x905 belt for 30a cars. Related? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
SGKent Samba Member
Posted: Fri Jul 31, 2015 10:44 pm Post subject: |
Alright so I need to keep my eyes open for 38 amp cast pulleys in good condition. I'll bet places like Interstate have boxes of them without knowing it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Aug 01, 2015 9:27 am Post subject: |
SGKent wrote: |
Alright so I need to keep my eyes open for 38 amp cast pulleys in good condition. I'll bet places like Interstate have boxes of them without knowing it. |
I betcha Jim knows it if you ask him. I walked in and met him one day without calling first... I asked for an early bay jack hold down strap and he found a box of them in less than a minute.
Though I have never seen one at the Pamona Swap Meet I frequent... _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Sat Aug 01, 2015 6:19 pm Post subject: |
asiab3 wrote: |
busdaddy wrote: |
Colin showed me a factory manual that I had never seen last summer, and it showed a 9.5x900 belt for the 38a generator-equipped cars, and a 9.5x905 belt for 30a cars. Related? |
Quite possibly, I went on the hunt for one locally today but they are all 10mm or 7/16" wide (even the Continental supposedly sized for a 71 bus), rides low in the pulley but too fat to snug up the nut against the shims. The 9.5X905 sits almost at the outer edge of the pulley already like it's almost worn out. The belt I have now is an inch sized Gates or something with the teeth and fits much like the 905mm one.
I'm hoping to get my hands on a real 9.5 wide belt so I can do a side by side RPM test on the generator between the 2 pulleys and 2 belts, could be interesting. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Sun Aug 02, 2015 7:46 am Post subject: |
808OvalGreasemonkey wrote: |
Which "tins" are you guys talking about? My newly acquired 71' Westy had the 38A generator with a 30A regulator,however it was missing the special cast iron pulley to offset the belt to make up for the 38A generators longer length,so my belt was offset.
I simply swapped in a new Bosch 30A generator,and used the original tin and it works perfectly now,and the pulleys line up.
The only thing I saw was that the tin had a extra cooling slot or whatever in it (it sits inside the fan housing) and everything bolted right up.
Whay are some here saying "change the tin"? :?: |
You weren't re-using the original tin - the mounting plates for the 30 and 38 amp generators are shaped differently to account for the different length. So I'm guessing your offset pulley was the result of using a 38 amp gen with the 30amp mounting plate. Replace that gen with a 30 amp unit on the same mounting plate and it all lines up.
That cooling slot inside the mounting plate must face downwards so it pulls cooling air through the generator into the fan. _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
GeorgeL Samba Member
Posted: Sun Aug 02, 2015 1:15 pm Post subject: |
To be more specific, the tin in question is the circular piece at the front of the generator, with four bolt holes around its perimeter. the difference is subtle but visible. For a 38A setup the tin is dished inward a bit where the generator mounts. For a 30A or alternator setup the tin is dished a bit outward where the generator mounts This moves a 38A generator about a centimeter further forward than the other setups. The 38A unit is longer, so the pulley ends up in the same place. |
Thomas333is Samba Member
Posted: Sat Nov 26, 2016 9:44 am Post subject: |
telford dorr wrote: |
Don't forget that the two generators use different tin and pulleys, so probably best to replace with what you have, unless you're willing to swap out all that stuff also.
You can use a 30 amp regulator on a 38 amp generator, but you will limit the generator's output. Don't use a 38 amp regulator on a 30 amp generator. (1) It's hard on the generator, and (2) you could ruin a hard-to-get 38 amp regulator. Either get a 38 amp generator to go with it, or give it to someone who needs one. |
I have generator 30amp and regulator 38amp. So I can not use it? |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Sat Nov 26, 2016 10:00 am Post subject: Re: 30 amp generator or 38 amp generator ? |
I would advise against it. It will allow you to overload your 30 amp generator, shortening its life. Besides, 30 amp regulators are EASY to get. 38 amp regulators are rare - save them for use with 38 amp generators. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Sat Nov 26, 2016 10:12 am Post subject: |
Posted: Sat Nov 26, 2016 10:35 am Post subject: |
Thomas333is wrote: |
No you can't, expensive and time consuming smoke will result, don't do it.
There, is that clear enough? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
MusiKaravan Samba Member
Posted: Wed Sep 23, 2020 10:43 am Post subject: Re: 30 amp generator or 38 amp generator ? |
Hi there! I have the opposite: 38V generator and new 30V regulator... Is that ok?.. (Sorry for the dumb question.. |
Posted: Wed Sep 23, 2020 11:29 am Post subject: Re: 30 amp generator or 38 amp generator ? |
MusiKaravan wrote: |
That will work OK, but you'll only get 30A from it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Wed Sep 23, 2020 12:08 pm Post subject: Re: 30 amp generator or 38 amp generator ? |
I can look and see if I have a 38 VR on the shelf when I get home. If you are interested in that send me a PM _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
tweakhx Samba Member
Joined: April 11, 2012 Posts: 156 Location: South Dakota
Posted: Fri Sep 25, 2020 12:01 pm Post subject: Re: 30 amp generator or 38 amp generator ? |
Aeromech,
I would be interested in a 38a regulator if you have one available to sell. I'm also currently moving over to 38amp original stuff while I rebuild my engine. Let me know if you do!
Thanks,
Scott _________________ 1968 Diamond Blue FI Fastback
1969 Diamond Blue FI Fastback Auto
1971 Pastel White Westfalia
2007 GTI
2012 Beetle 2.5L
endle wrote: |
Ever since I bought a vw I have not been able to keep my fingernails clean.
Posted: Fri Sep 25, 2020 12:04 pm Post subject: Re: 30 amp generator or 38 amp generator ? |
Sorry guys,
I checked my stock and did not find a 38 amp version. I spoke too soon _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent Samba Member
Posted: Fri Sep 25, 2020 12:22 pm Post subject: Re: 30 amp generator or 38 amp generator ? |
I am sure these have been posted before in this thread but just in case. Also, according to Google, quite a few places sell the VR part# listed for the 38 amp generator. To me it looks like the market has adjusted to the need for 38 amp parts, other than maybe the better pulleys - although NOS ones are still out there, and VW shows them as still available too.
Tcash wrote: |
Bentley says 69-71 38A in the Electrical section.
You would need
38A generator - 211 903 031 D
38A inner and outer fan covers - 211 119 259 inner / 211 119 259 outer
Fan cover reinforcement flange - 113 119 271
38A gen pulley with hub - 211 903 109
38A voltage regulator - 211 903 803 E
The 38A regulators are getting harder to find.
Good luck
Tcash
Thanks to jerseylooker
http://www.jerseylooker.com/FicheDump/EarlyBaywindow/EarlyBay-Main.html |
Posted: Fri Sep 25, 2020 12:48 pm Post subject: Re: 30 amp generator or 38 amp generator ? |
I do have the Mexican solid state regulator currently. I've read that will handle the 38amp generator fine. Can anyone vouch for this? _________________ 1968 Diamond Blue FI Fastback
2007 GTI
2012 Beetle 2.5L
endle wrote: |
SGKent Samba Member
Posted: Fri Sep 25, 2020 3:02 pm Post subject: Re: 30 amp generator or 38 amp generator ? |
tweakhx wrote: |
I do have the Mexican solid state regulator currently. I've read that will handle the 38amp generator fine. Can anyone vouch for this? |
look it up with Google and see what it says. If it lists this part number then it probably does. 211 903 803 E _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Sep 25, 2020 3:30 pm Post subject: Re: 30 amp generator or 38 amp generator ? |
tweakhx wrote: |
Most likely 30A since those solid state ones are mainly for Beetles, it'll work, but it won't use the generator to it's full potential. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
